4x4 Smell?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BSP4x4, Dec 4, 2009.
  1. Dec 4, 2009 at 6:09 AM
    BSP4x4
    BSP4x4 [OP] Guest
    Put the truck into 4x4 for the first time yesterday (for an extended period of time)…I tried the 4x4 for about 30 feet at the dealership before I bought it. But yesterday I actually used it in the heavy rain we had up hear in the NE. I never made any sharp turns, and went mostly straight at about 30-50 MPH. After about 5 mins I noticed what was almost like an electric burning smell? It went away after a while. Was it the clutch?
  2. Dec 4, 2009 at 6:16 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    key there is "for an extended period of time" and first time in 4x4 for that period. all that happened was the gear oil got warm and some came out of the overflow/diff breather.
    edit: man I cant type this morning, had to edit up there.
    to add, a little of that overflowed gear oil most likely got on your exhaust (the front diff breather is kinda close) and that was your burning smell.
  3. Dec 4, 2009 at 6:38 AM
    Dark Knight
    Jeff
    NC/SC
    also take a look at the driver side frame rail below and a little back of the UCA. you may be able to see remnants of the overflowed gear oil.
  4. Dec 4, 2009 at 7:35 AM
    BSP4x4
    BSP4x4 [OP] Guest
    What should I be looking for when checking the 4wd ecu? and what is it?
    I also did the rear diff breather mod....but that does not have anything to do with the front diff and 4wd right?
  5. Dec 4, 2009 at 7:41 AM
    Dark Knight
    Jeff
    NC/SC
    correct, check out under the driver side front fender first, if you see some gear oil you know right off about what happened.
  6. Dec 4, 2009 at 7:50 AM
    cameraperson
    cameraperson TIM HUS shows Nashville how it's done correctly.
    Cameraperson ADK
    DC and Lake Ozonia in the ADKs
    07 Tacoma 4x4 TrD sport
    Roof Rack, Auto Ignition, Full-time switchable camera over the rear tag, steering wheel cover, light floor mats, Gravimetric torpedoes
    The dealer I got mine from said you should use 4x4 at least 10 miles a month to keep the parts lubed properly. Just an FYI.
  7. Dec 4, 2009 at 7:51 AM
    BSP4x4
    BSP4x4 [OP] Guest
    Thats what i was doing when this happened :)
  8. Dec 4, 2009 at 2:03 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    I never had this smell at all in my 09. It goes into 4wd quite often.
  9. Dec 4, 2009 at 3:48 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    i never heard of this.dont think its normal.
