4x4 Snow Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by S1njin, Sep 26, 2012.
  1. Dec 28, 2012 at 11:25 PM
    #261
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    guess i need to go find steeper ice rinks then:)
  2. Dec 29, 2012 at 12:46 AM
    #262
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    You pay extra for 4WD... so USE it if the road isn't warm and dry!
    The only issue to not using 4WD on good roads is steering.. IF your tires can't slip, then there will be binding... and you will feel it when you steer... specially when you park, even on dirt. I will take it out of 4WD to make a tight turn when I am not moving very fast, like parallel parking because the steering wheel (and tires) will be difficult to turn.
    The difference between AWD (full time 4WD) and our Tacoma 4WD (part time 4WD) is a center differential in the AWDs that allows the front and rear drive shafts to rotate at different speeds (as what happens when turning). A 4WD has the front and rear locked together without any middle differential... so you need to be on soft or wet roads so the tires can slip as they roll at different rates when steering.
    In a nutshell, you could physically drive 70-80-90 mph in 4WD (High)... as long as the road allows slipping in a turn, or you don't turn. The instructions are for 100 kph (62 mph) +/- limit to engage the shift-on-the-fly 2WD to 4WD-HI.
    Seriously, I don't think you need to be going into 4WD at those speeds... but if so, just go in at a lower speed first. Your fuel mileage will go way down when using 4WD, so use it but don't waste it!
  3. Dec 29, 2012 at 8:37 AM
    #263
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    ^This! The right mindset my friend.
    Its always better to get the knowledge and absorb it beforehand, rather than being that guy coming to the forum complaining about how Toyota is releasing inferior products.
    4X4: Use it or lose it! Just remember to activate it occasionally at lower speeds to ensure its properly lubricated and all of the parts aren't binding up!
  4. Dec 29, 2012 at 3:11 PM
    #264
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    i use 4WD all the time at highway speeds in the rain and snow for 45k miles with no issues. You'll be fine. The system wont let you engage 4wd above 60 MPH so if you want to use it in the rain, you have to slow down to engage then you can go faster then 60
  5. Dec 29, 2012 at 3:13 PM
    #265
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    4x4 in rain is totally unnecessary but meh
  6. Dec 29, 2012 at 3:25 PM
    #266
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I use it all the time :)
  7. Dec 29, 2012 at 4:20 PM
    #267
    OZ-T
    Peter North
    British Columbia
    your a meathead than
  8. Dec 30, 2012 at 8:22 AM
    #268
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    I bet he was giving all kinds of mustache rides in his day:D
  9. Dec 30, 2012 at 8:30 AM
    #269
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    This.
  10. Dec 30, 2012 at 3:22 PM
    #270
    XXXX
    sKiP
    05 Prius
    I'm in 4wd right now. Vroom Vroom
  11. Dec 30, 2012 at 3:35 PM
    #271
    David K
    Sweet!
  12. Dec 30, 2012 at 3:37 PM
    #272
    OZ-T
    Peter North
    British Columbia
    No you're not
  13. Dec 30, 2012 at 3:40 PM
    #273
    XXXX
    sKiP
    05 Prius
    If it snows I'll take it out for a rip to test the KM2's. Local pit is 2 miles away. If it blows it blows.
    I'm working on an engine now. Super low miles.....like not broken in yet miles :)
  14. Dec 30, 2012 at 3:42 PM
    #274
    OZ-T
    Peter North
    British Columbia
    Go diesel
    FAP FAP FAP
  15. Dec 30, 2012 at 3:48 PM
    #275
    XXXX
    sKiP
    05 Prius
    meh... I got a healthy 5.0 V8 in the Explorer with only 114k on it. Vrooooom Vroooooom
