4x4 speed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jar-sr5, Mar 1, 2009.
  1. Mar 1, 2009 at 3:55 PM
    jar-sr5
    jar-sr5 [OP] Active Member
    Manitoba, Canada
    tacoma SR5
    Grille Craft, 245/75/16 Wrangler Duratracs
    Sorry if this question has been asked before but I did a search for it and I couldnt find anything.
    I got a 09 taco sr5 4x4(non TRD)
    What is the top speed a person should go in 4x4 hi and 4x4 low?
  2. Mar 1, 2009 at 4:02 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    It's net recommended to exceed 65 in 4Hi. If you need to go faster than 15mph in 4Lo then switch to 4Hi.
    These are just my personal guidelines for how to use them; it should say on the sunvisor over the drivers head.
  3. Mar 1, 2009 at 4:05 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    60mph in high and 5mph is low I believe.
  4. Mar 1, 2009 at 4:09 PM
    nighthawk87
    nighthawk87 Well-Known Member
    Incorrect...you shouldn't engage 4HI until pass 62 MPH. You can drive as fast as you want in it but likely shouldn't be doing really high speeds in areas where 4WD is needed.
    In 4LO, I don't think you should be exceeding like 10 MPH max, otherwise shift into 4HI as previously stated.
    Hope this helps. It also should be in the owners manual. :D
  5. Mar 1, 2009 at 4:10 PM
    nvdeserted
    Reno, NV
    I think you're mostly right, I think you can't engage 4hi unless you are going 60mph or less, but once you're in 4hi you can go as fast as you want.
    OOps, you beat me to it. But like he said, if you're going 75 in 4hi you probably are going much faster than you should be.
  6. Mar 1, 2009 at 5:22 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    OHHHH COOLLL! I thought you couldn't go over 60. Thats cool. I probably won't ever go over 60 but good to know. Thanks for the correction.
  7. Mar 1, 2009 at 7:44 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    When it's raining hard, I'll have my truck in 4hi going 65mph on the highway.
    I don't use 4lo much in the truck. The last time I used 4lo was in a snow storm on my way home from work. I put it in 4lo just for the hell of it (because I never use it). I have an AUTO - and 35mph was about as high as I wanted to go because the engine was revving up pretty high.
  8. Mar 1, 2009 at 7:46 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Just wondering, do you see any notable differences in MPG?
  9. Mar 1, 2009 at 7:57 PM
    MGRS
    MGRS Well-Known Member
    08 6spd TRD 4x4
    You definitely would, but I have never ran 4hi for any amount of time on high-traction surfaces. Good way to destroy a T-case, or at least that is what happened to several Colorado fleet trucks where my father works. The drivers would put them in 4hi going down state roads in real light snow or rain. Eventually, they started blowing up.
  10. Mar 1, 2009 at 8:20 PM
    nvdeserted
    Reno, NV
    I got stuck on a stretch of snow/iced highway about 2 weeks ago, had it in 4hi and on cruise set at 60 (so I was probably going about 56mph) for about 2.5 hrs and the gas gauge didn't seem to drop any faster than normal. I'm sure it lowers MPG but it won't cut it in half or anything.
  11. Mar 1, 2009 at 10:36 PM
    wawireguy
    wawireguy Well-Known Member
    I've done 70 or so in 4 Hi but in slick conditions. Snow and ice. I wouldn't use 4 Hi for wet weather but that's just me. I try to engage 4wd when I'm at a stop and disengage it like that also. Mechanics told me was better for it.
  12. Mar 1, 2009 at 10:47 PM
    DanGer
    Did they tell you anything about using it going 70 in slick conditions?
  13. Mar 2, 2009 at 2:05 AM
    Janster
    Jandy
    Lancaster, PA
    MPG differences when in 4WD?
    I haven't used it enough to calculate all that. I'm lucky if I use it once every several weeks.
  14. Mar 2, 2009 at 5:45 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Over the years I've got about 3K in 4hi. In this truck lose only about 1 mpg, maybe little more in bitter cold, short trips, a little less on long trips when everything is warmed up.
    Truck can hit the governer (109) in 4hi, 4l0 is redline in top gear, I'm guessing about 50-55.
  15. Mar 2, 2009 at 5:54 AM
    freesample
    freesample Well-Known Member
    Newfoundland, Canada
    09 Tacoma Double Cab TRD Sport LB
    Visors, Deflector, Husky Liners, too expsensive for good ones :(
    i use 4wd hi all the time.. any speed.. lots of snow here. if you dont have a heavy foot and use it when you should i find its a gas saver. but once you get stuck and have it in 4wd and start stamping it to get out.. the needle drops lol.
  16. Mar 2, 2009 at 7:15 AM
    Munkey
    Munkey Well-Known Member
    Paducah, KY
    2008 Radiant Red 4X4 Double Cab Sport
    OEM Tube Steps, Bed Extender, Pioneer Avic D3 with Bluetooth and XM Radio modules
    Probably not. But I bet there's a tree or power pole out there that will get the point across someday.
  17. Mar 2, 2009 at 7:23 AM
    chaser_corax
    chaser_corax Member
    Tyler, TX
    Revtek 3" Leveling Kit, HID Hi-Lo Bulbs
    hey guys i got a weird situation going on. when i engage the 4H from 2H, the truck will go well in a straight line, but as soon as i make a turn it feels like the wheels get locked up. especially at 5mph and below (like, when parking), when make a tight turn, the truck will stop almost completely. it feels just like the parking brake gets engaged or something.
    again, this is only in 4H. havent tried 4Lo at all yet. does anyone have an explanation?
  18. Mar 2, 2009 at 7:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Yes....Your drive train is binding because the front and rear are locked together. 4x4 should only be used in slippery conditions. Not on pavment.
  19. Mar 2, 2009 at 7:26 AM
    freesample
    on high traction (asphalt) or low traction (loose gravel/snow) ?
  20. Mar 2, 2009 at 7:28 AM
    khaos5407
    khaos5407 Work in progress
    Reisterstown, MD
    08 SR5 Tacoma Sport Edition Silver
    rd the visor above you haha it says 60 ish lol i think the fastest ive gone in 4HI is 65 but thats pushing it as well, dont wanna mess anything up
