4x4 Tacoma conversion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Brice, Aug 4, 2015.
  1. Aug 4, 2015 at 7:56 PM
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    So i wanna convert my prerunner to 4x4 my only question is, is that what is the difference between an add front diff and a regular front diff. they both seem to have some sort of vacuum pump... If im converting whats better a a.d.d diff or a regular manual diff?
  2. Aug 4, 2015 at 9:03 PM
    trx125
    trx125 Well-Known Member
    Manual has no vacuum pump. The ADD does. If you go manual, you'll need the hubs, spindles, front and rear axles, diff, transfer case. If you have an auto, you need the computer and wiring also. Almost the same if you go ADD, you'll need different spindles, vsv's, pump and relays for the switches.
  3. Aug 4, 2015 at 9:06 PM
    Brice
    Brice
    Texas
    Lol I'm going with the j-shift style transfer case I'm not even gonna touch the ECU (except for the spedo). So if I use the j-shift I guess I'll go manual hubs is what it sounds like, because if i do manual hubs and a manual transfer case i should be able to skip by any sort of wiring.
  4. Aug 6, 2015 at 12:18 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Do your self a favor and buy a complete donor vehicle instead of getting it one piece at a time.
  5. Aug 6, 2015 at 8:51 AM
    Brice
    Brice
    Texas
    I guess that would be cheaper huh...hmm i could get a hold of one for about 700 bucks on ebay with all the parts...Thanks wyoming ill look into that
