4x4 tight turns on gravel
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lt.kerrnal, Jun 10, 2022.
  1. Jun 10, 2022 at 5:48 PM
    lt.kerrnal
    lt.kerrnal [OP] New Member
    22 TRD off road
    Hello all
    I am experiencing some odd feelings while making tight turns in 4x4. I only engage the 4x4 on gravel roads and my extremely steep tight switch backed driveway (no where CO). When turning around the switchbacks in 4x4 I feel resistance and like the tires are moving laterally. Is this normal?
  2. Jun 10, 2022 at 5:50 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Definitely. First 4x4? It’s the driveline binding because the front wheels are moving at different speeds than the rear wheels. Don’t try it on dry pavement
    mosccat likes this.
  3. Jun 10, 2022 at 5:55 PM
    lt.kerrnal
    22 TRD off road
    Thanks for the response. i assume this will cause normal wear and isnt something i am doing wrong to prematurely wear my truck.
    Edited for 4x4 not 4wd
    musicisevil likes this.
  4. Jun 10, 2022 at 6:00 PM
    musicisevil
    Alaska
    2019 TRD Sport
    I’m sure someone more knowledgeable than me will have better responses/a better explanation of what is happening, but on gravel it’s not something I would worry about personally. As long as the front wheels can slip and skip without a ton of resistance (like dry pavement of a parking lot) it alleviates the bind.
    In a perfect world you’d only ever use 4x4 when traveling in a straight line, but I lived in the mountains and drove up a driveway with 3 tight switchbacks for 10+ years, and my first gen never had any issues. Try and take the corner as wide as you can and power through it
  5. Jun 10, 2022 at 6:14 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Even off road traction can be good enough to cause binding in 4X4. It will bind worse in reverse than going forward. If you feel resistance disengage 4X4 temporarily. If it's binding you don't need 4X4.
    Anytime there is any binding in the drivetrain you are over stressing components and will cause premature parts failure. But if kept to a minimum you should get a lot of life out of them. It is when people drive on surfaces with good traction by design while 4X4 is engaged that break stuff.
    mosccat and musicisevil like this.
  6. Jun 10, 2022 at 6:19 PM
    05 4x4
    05 4x4 Well-Known Member
    agreed, if your binding like that you probably shouldnt be in 4x4.
    mosccat likes this.
  7. Jun 10, 2022 at 6:21 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    As others have said, if you feel the binding you have lots of traction and could really be in 2WD. On tight switchbacks, or when parking, off-road, I switch into 2WD, if I have lots of traction to avoid the binding.
    tcjacado likes this.
  8. Jun 10, 2022 at 6:24 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    This will even happen in snow, and is very normal. Avoid tight turns in 4wd, or avoid 4wd on tight turns.
  9. Jun 10, 2022 at 6:35 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Normal. Your front and rear axles are locked together and must turn at the same speed, but the can’t when you are turning. On surfaces like gravel it’s an annoyance but not something to be super worried about. Use 4wd when you really need it. Gravel roads unless minimum maintenance and water soaked don’t count, but can be fun
  10. Jun 10, 2022 at 6:46 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    That's the same thing
    landphil likes this.
  11. Jun 10, 2022 at 6:55 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    But is it though? One is four wheel drive and the other is a square 4” piece of lumber
  12. Jun 10, 2022 at 7:01 PM
    Wyckedan
    Dan
    Woodinville WA
    But is it though? Or is it a square 3.5"x3.5" piece of lumber? Wild
  13. Jun 10, 2022 at 7:02 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Hit me with a 4x2. :D
    TireFire[QUOTED] likes this.
  14. Jun 10, 2022 at 7:11 PM
    TireFire
    Olympic Peninsula
    Gawd damn
  15. Jun 10, 2022 at 7:13 PM
    lt.kerrnal
    22 TRD off road
    Thanks for the replies. yall rock. Just tryin to make my baby last as long as possible
  16. Jun 10, 2022 at 7:22 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Have you ever drove at Moab?
    It has good traction. It will bind. It needs 4wd. It will not break.
    lt.kerrnal[OP] and musicisevil like this.
  17. Jun 10, 2022 at 7:28 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    This is about the 4th or 5th time I’ve said this:
    “Marshall R bought a 4x4 and is afraid to use it.”
    hiPSI[QUOTED] likes this.
  18. Jun 10, 2022 at 7:42 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol.
    Geezus. When are people going to realize that making turns with full traction won't break shit?
    And please... Don't show me that one failed transfer case of a Jeep that drove thousands of miles locked in 4 low. It deserves to break.
    skiploder and musicisevil like this.
  19. Jun 10, 2022 at 7:52 PM
    Sharpish
    Brian
    I don’t often agree with you but in this case all I gotta say is “Amen Brother.”
    musicisevil and hiPSI[QUOTED] like this.
  20. Jun 10, 2022 at 7:57 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I make a habit while in 4WD not to make too tight of turns period... i've even experienced binding making tight turns on dry snow.
