4x4 tow ratings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sqdqo, Sep 15, 2011.
  1. Sep 15, 2011 at 6:13 PM
    sqdqo
    sqdqo [OP] Member
    I understand the 2005 and up 4x4 Tacomas had 2 different tow ratings, 5000lb and 6500lb. Is there any way visually to know which your looking at?
  2. Sep 15, 2011 at 6:48 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The tow ratings are 3,500 and 6,500. 3,500 is w/out the tow package, 6,500 with the tow package. Factory tow package comes with a hitch, 7-pin plug, HD alternator and an oil cooler for autos. You can tell by visually looking at them by the sticker on the door jamb. The tow package equipped trucks will have a GCVWR of around 11,000# and non-tow package equipped will be around 8,000#. Also, you can just look to see if it's an OEM receiver but that can be added after the fact.
  3. Sep 15, 2011 at 9:35 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    just a question like that, since it's anti-freeze passing through that ''oil cooler'', how the hell water at 200degF can really cool down oil since it's about the same operating temp..?
  4. Sep 16, 2011 at 1:16 AM
    JKD
    JKD Well-Known Member
    Engine oil tends to run 220 to 250 degrees in normal op conditions. If it doesn't reach at least 212 degrees, moisture isn't as effectively removed from the crankcase. See the "oil fill tube mayonnaise' people see in the winter, especially on trucks used for short trips.
  5. Sep 16, 2011 at 5:56 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The cooler is on the return side it's been through the radiator and the water has been cooled. It's the same reason a transmission cooler works it's in the bottom of the radiator where it's cooler.
  6. Sep 17, 2011 at 2:35 AM
    supralight
    Dan
    Earth
    Thanks for the quick info about this guys, using hot water to cool down oil was bugging me, but it is now clear :)
