4x4 TRD Off road vs. 4x4 TRD Sport vs. 4x4 SR5
Discussion in '2nd Gen. Tacomas (2005-2015)' started by simcoetacoma, Feb 22, 2011.
  1. Feb 22, 2011 at 5:12 PM
    simcoetacoma
    simcoetacoma [OP] Member
    If you were in the market for an all round nice truck which option would you choose and why--4x4 TRD Off road vs. 4x4 TRD Sport vs. 4x4 SR5? Insight would be greatly appreciated. I am looking for something between built between 2009 and 2011.
    Thank-you.
  2. Feb 22, 2011 at 5:14 PM
    jandrews
    '09 FourDubDee TRD OR
    What do you want the truck to do? The clues are in the names.
  3. Feb 22, 2011 at 5:16 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    To see the option packages, your best resource is the Toyota webpage. Depending on what you want to do with it will dictate which model best suits you. I've got an SR5 4x4 and, for what I use it for, it works well. I don't off road really to speak of. To me, it's a daily driver, a toy hauler and a camper.
  4. Feb 22, 2011 at 5:23 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Those are second generation Tacomas... otherwise, I was about to tell you there was no Sport TRD before 2005 (this question is in the First Generation forum)...
    Now that that is out of the way, I would get the Off Road TRD (and have), because for the money, I want my truck to have the maximum traction ability to get as far off the highway as possible... and never need to be pulled out by anyone else!
    Only the Off Road TRD has a locking rear differential... and '09 + 4WD Off Roads have A-TRAC.
  5. Feb 22, 2011 at 5:42 PM
    simcoetacoma
    I probably will not do too much offroading, but I will do some. I want a truck that will maintain its value and be as reliable as possible over time. It seems as though I can get a used TRD off road for about $1500 more than an SR5. Based on the range of options offered in the TRD offroad it seems as though it is worthwhile to spend the extra 1500...?
    I'm not sure if I understand you right--If you plan on adding lockers the SR5 is the best bang for your buck. Can you please elaborate.
    I appreciate the comments.
  6. Feb 22, 2011 at 5:45 PM
    jandrews
    If that statement confuses you, you should probably just go with the SR5 or the Sport.
  7. Feb 22, 2011 at 9:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Well, since you are here....
    The 1st generation Tacoma's ('96 thru '04) have proven to hold their value way beyond expectations. The newer ('09 thru '11) models are as yet unproven in this regard. There is some evidence the 2nd gens are not as durable as the 1st gens which may impact their ability to hold value long term.
  8. Feb 23, 2011 at 4:37 AM
    jandrews
    2nd gens hold their resale just as well as 1st gens.
    There's anecdotal evidence, which is worthless. Please read:
    http://en.wikipedia.org/wiki/Anecdotal
    Everything statistically valid says Tacoma quality is as good as it's ever been.
  9. Feb 23, 2011 at 5:02 AM
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts
    Nick
    Pooler, Ga
    2003 taco TRD off road 4x4 dbl cab.
    255/85-16 BF goodrich km3's, modified trail gear Bumpers front and rear, 10k winch, ranch rear lift shackles, Rancho coilovers in the front, grey wire mod, aftermarket stereo, camper top on the back.
    get an off road sr5!!
  10. Feb 23, 2011 at 5:27 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    I love my I4 SR5.
  11. Feb 23, 2011 at 5:38 AM
    poynter
    poynter Well-Known Member
    Tony
    Somerset, KY
    2019 Cement TRDOR
    Isnt SR5 just power windows/locks? I have a TRD sport SR5 so not sure what came with what.
  12. Feb 23, 2011 at 5:38 AM
    SargeSlapnuts
    Nick
    Pooler, Ga
    me too and i have the off road package just no elocker:(
  13. Feb 23, 2011 at 8:24 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    why are we discussing 2nd gen trucks in the 1 gen forum??? this seems to happen quite a bit
    mods need to monitor this more and move these threads to the correct forums
  14. Feb 23, 2011 at 8:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    With 40,000 members, and as many posts per day as there are, the Moderators also rely on the members to help by reporting threads that may be in violation, or in the wrong place. We cant see everything.
  15. Feb 23, 2011 at 8:35 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    all TRD's will also have the SR5 package but not all SR5's have the TRD.
    TRD is the top of line for tacomas.
    in your case I would go with either the sport or just SR5. the Sport has color matched grill, door handles, and rear bumper and hood scoop. it will have better seats, steering wheel controls for the radio, overhead temp and compass, power outlet in the bed. 17" wheels
    the sr5 is pretty basic but has keyless entry, cruise control...chrome grill and rear bumper
  16. Feb 23, 2011 at 8:43 AM
    TacoMal
    TacoMal Well-Known Member
    California
    09 TRD Off Road Dbl cab
    Wet Okole's, Relentless Sliders, Plasti Dipped badges and wheels
    :frusty::annoyed:Everyone is so angry this morning!!
  17. Feb 23, 2011 at 8:43 AM
    stevenstaco
    stevenstaco B A N N E D
    steven
    sacramento ca
    o7 trd sport sr5 4x4/06 4runner sr5 4x4
    1.5 aal,Tacomaworld sticker,Blacked out tail lights,bhlm,.dumped exhaust,relocated 7 pin ,rear diff breather mod,bed lights,hella 500s behind the grill,plastidipped lower vallance,mag light mod,debadged,black billit grill,bedmat mod,airaid intake,vynil armrests and back rests,tailgate theft mod, ipod interface,backseat cargo mod,front 5100s
    i have a trd sport sr5 4x4 i am happy with it but kinda wish i got the trd offroad 4x4 it has more functional features like the skid plate and rear locker the sport is more for looks
    TAC1 likes this.
  18. Feb 23, 2011 at 8:43 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Also some SR5's can come with more options. Mine came with LSD, Auto Dimming Mirror, etc.
    TAC1 likes this.
  19. Feb 23, 2011 at 9:45 AM
    crazyman
    crazyman Not bothered....
    Crystal Beach, FL
    '11 4x4 DC/SB TRD/OR V6 Auto, Magnetic Gray
    Does Plasti-Dip count as a mod ?
    I bought my TRD OR because of all the features. I might not use all of them, but I was fortunate to be able to get the most truck for the money.
  20. Feb 23, 2011 at 10:19 AM
    bonfire
    bonfire Well-Known Member
    Seattle WA
    TRD Sport LB
