4x4 troubles
Discussion in '1st Gen. Tacomas (1995-2004)' started by yotabra, Dec 1, 2022.
  1. Dec 1, 2022 at 6:18 PM
    yotabra
    yotabra [OP] Member
    98 Tacoma white
    I got stuck in some ice/snow the other day and needed help getting out. I had 4x4 engaged and the dash light was on. I was pretty sure my 4x4 works ok, It has helped me get out of mud years ago and when I use it on dry pavement and turn tight the truck skips a bit (I make sure not to do this but I know it is a sign it is engaging.)
    Anyways while I was stuck in the snow only my rear wheels would spin out, no spinning up front. Does this mean there is something wrong with my 4x4? Also, I believe I have the open differential, not limited slip differential.
    Thanks
  2. Dec 3, 2022 at 4:19 PM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    If you have a jack and some jack stands you can lift all the tires off the ground and check. If not working check the vacuum lines.
  3. Dec 3, 2022 at 4:22 PM
    eon_blue
    Azusa, CA
    How do you know the fronts weren't spinning? The front diff is open so if one wheel has less traction then the other, the one without traction will spin while the other doesn't move.
    If you looked out from the seat and didn't see the driver wheel spinning the other one may have been, depending on how you were stuck.
    LearningToFly likes this.
  4. Dec 4, 2022 at 6:01 PM
    yotabra
    yotabra [OP] Member
    98 Tacoma white
    I think Eon Blue mentioned my situation. It turns out the passenger hub wasn’t locked so I guess the open diff would send power there? It feels a bit better now. I’ll look into how to check vacuum lines I haven’t done that before.
