4x4 vs 2WD: differences in mpg, size?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TheSeaward, Jan 25, 2009.
  1. Jan 25, 2009 at 9:30 PM
    TheSeaward
    TheSeaward [OP] Member
    Hi. New here and looking to find out some information about Tacoma's. I'm looking for a 1st gen Tacoma to use for commuting and to move things around on some land. The trails are pretty tight so I want to go with a smaller 1st gen Tacoma. I'm not going to be towing anything and want to use it as a daily driver so I'm thinking I need the 2.7L. I'm considering getting the 4x4 (snowboarding, light trail use) and have a few questions:
    1. What kind of MPG hit will I take with the 4x4 over the 2WD model (when driving in 2WD mode)?
    2. Is the Xtra cab model physically longer than the regular cab? Is the bed size different? MPG difference?
    Thanks!
  2. Jan 25, 2009 at 9:47 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    '13 MGM AC 4x4 TRD OR
    Husky front mud flaps, OEM bed mat, 3D floor mats, Wet Okole seat covers, fog lights anytime mod, rear diff breather extension, aluminum Relentless tailgate reinforcement, NWexpo corner gussets, 265/75-16 Hankook Dynapro ATM
    Xcab is longer than the reg. cab by the length of the room behind the front seats, so is longer overall. They both have the same bed dimensions. The double cab is the same overall length as the xcab, because the bed is shorter.
  3. Jan 25, 2009 at 9:50 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Welcome to TW!
  4. Jan 25, 2009 at 9:53 PM
    glwood6
    Gary
    Albuquerque, NM
    What HE said^^^!
  5. Jan 25, 2009 at 10:12 PM
    Dustin03
    Dustin03 The Cooler King
    Arizona
    Expeditionary vehicle in training.
    Old Man Emu 2.5" lift, brush guard (about to be changed), grey-wire mod, custom bed mounts for 4 jerrycans, custom survival box, maglite mount, KC Dayliters.
    Like they said, welcome to the forum! As for fuel mileage, between the 2WD and 4x4, the difference should be slight--maybe two or three MPG, depending on how heavy your foot is.
    The decision is yours to make, but I'd recommend the 3.4L over the 2.7L if you can find it, because even the V6 doesn't have all that much power, if we're all being completely honest. But both engines are solidly built, and they'll last as long as you want them to.
  6. Jan 26, 2009 at 7:06 AM
    TheSeaward
    Thanks for the warm welcome everybody! I'll probably go take a look at some in the next few weeks (and some Ford Rangers too haha... sorry) and see how they drive. If I'm taking people and gear up to the slopes, I don't want to be stuck on the mountain...
  7. Jan 26, 2009 at 7:23 AM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    i have the 08' 2.7 4x4 im averaging out about 20-21 but thats on very hilly terrain also, and a lot of time under 30 mph going through fields and stuff.
  8. Jan 26, 2009 at 9:21 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    the rangers have transfercase proublems so if i were u id stay away from the rangers (or any ford for that matter)
    go with a tacoma u willl be happier
  9. Jan 26, 2009 at 9:33 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    for what its worth...........on my double cab with the 3.4v6.....im averaging around 20/21 mpg.................was a little better in the summer when we didnt have the "winter blend" gas from the gas station. i think you will be very grateful if you got the 4x4, and the 3.4 isnt bad on gas at all.
  10. Jan 26, 2009 at 11:41 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    (1) When you say "4X4 versus 2WD", are you meaning comparison of 4X4 mpg estimates against 5-lug 2WD Tacomas ('minis'), or againt 6-lug 2WD PreRunners?
    To give an example ... In the 2001 - 2004 generation, a 2WD PreRunner (on the same 6-lug suspension, etc., as the 4WD models) only gets about 1 mpg more than the equivalent 4X4 model for both city and highway.
    (2) In the last pre-2005 generation (2001 - 2004), 4X4 Regular and XtraCab models were rated as follows:
    4-cylinder manual: 18/21
    6-cylinder manual: 17/19
    4-cylinder auto: 18/21
    6-cylinder auto: 17/19
  11. Jan 26, 2009 at 11:42 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    really my 98 taco gets like 24-25 mpg
  12. Jan 26, 2009 at 12:16 PM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    What one gets mileage-wise will naturally depend on the driver, etc.
    The figures I cited are the official EPA mileage estimates for the listed models.
    On a good day I can typically expect to get 10 - 15% better mpg than the EPA estimates.
  13. Jan 26, 2009 at 4:37 PM
    daward
    daward Member
    West Chester, PA
    99 Tacoma 4wd
    stock.
    My '99 Std Cab Manual 2.7L 4x4 gets 20mpg with mixed driving.
    When using the 4wd, it has dropped down to ~17mpg. I have seen as high as 26-27mpg on highway trips when keeping the speed ~65mph.
    I bought mine for basically the same reason you're looking. I was driving my 96 Impala full time, and was averaging 14mpg on premium. I also ride 1-2x's per week in the cold season, and was working regularly on my house (trips to Home Depot) so I could use the utility. I've also since found a new hobby--wheeling! If I could go back and do it again, I'd get an extended cab. I don't care for the look, but I sure could use the interior space!
    Buy a Taco, you'll never regret it. :D
  14. Jan 26, 2009 at 5:04 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    im 16 and have a 2 ton right foot
  15. Jan 26, 2009 at 7:30 PM
    TheSeaward
    Hmm they do look nice with the bigger tires so I guess I would be wanting that. Mileage be damned.
    Also interesting that the xtracab and 4x4 are rated the same MPG (guessing this is due to added weight).
    Too many options making my head spin! I think I would be more than happy with daward's setup, getting 25mpg on the highway.
    tempting...
    http://sandiego.craigslist.org/nsd/cto/1004357662.html
  16. Jan 26, 2009 at 9:30 PM
    glwood6
    Gary
    Albuquerque, NM
  17. Jan 26, 2009 at 10:23 PM
    TheSeaward
    I do live near it... might go check it out over the weekend.
    What's this I hear about 95.5-2000 Tacoma's having frame rot?
  18. Jan 26, 2009 at 10:44 PM
    TheSeaward
    Dumb question: Do regular cab tacoma's have room for people to sit behind the front seats (sideways folding seats in the back?). I kinda like the idea of the shorter wheelbase but it would be nice to be able to move people as well.
  19. Jan 27, 2009 at 4:28 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    no
    i can fit three people in my extended cab but thats with the front seats moved all the way foward and there still cramped
  20. Jan 27, 2009 at 4:19 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    i hate u all mine were dudes and 1 girl:(
