4x4 wheel drive not smooth on turns
Discussion in '3rd Gen. Tacomas (2016-2023)' started by colbychristner, Jan 11, 2021.
  1. Jan 11, 2021 at 10:48 AM
    colbychristner
    colbychristner [OP] Member
    Colby
    2019 Quicksand Tacoma TRD Off-Road
    Hey all, I have a 2019 TRD OR LB. it finally snowed and I was in 4 wheel drive and every time I would turn, the turn wouldn’t be smooth at all. Like a jumping of skipping feeling, I’m not to sure how to explain it. I know it wasn’t because I was slipping in the snow because I just tested it on completely drive ground. Has anyone else had this issue?
  2. Jan 11, 2021 at 10:49 AM
    81shark
    81shark Well-Known Member
    Read the owners owners
    wolf2600, 0xDEADBEEF and FlyingWolfe like this.
  3. Jan 11, 2021 at 10:49 AM
    Tttacodan
    Tttacodan Well-Known Member
    Dan
    This is normal. Front and rear wheels travel at different speeds around corners, and some slippage needs to occur.
    Chew, zoo truck, RedWings44 and 2 others like this.
  4. Jan 11, 2021 at 10:50 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Don't use 4wd on dry ground unless you go straight, you are binding up the drivetrain. Part time 4wd is only meant to be used on loose surfaces.
  5. Jan 11, 2021 at 10:50 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    thats normal for 4x4. Its meant for loose ground and tight turns you will get binding at lock and tight turns especially on driveways or not loose gravel. This very different than an AWD if you are used to that.
  6. Jan 11, 2021 at 10:50 AM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Bindage woo! Love me a good bindage thread!
  7. Jan 11, 2021 at 10:52 AM
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    Show a pic of the snow you were driving in. My bet is it wasn't deep enough to allow the tires to spin when turning. It's not going to feel like an all wheel drive SUV when driving on dry pavement or on minimal snow. If you're getting that sensation, you likely shouldn't be in four wheel drive anyway.
  8. Jan 11, 2021 at 10:54 AM
    colbychristner
    Colby
    Okay that makes sense Bc it was more of slush than anything
  9. Jan 11, 2021 at 10:54 AM
    WHITE LONGBOI
    WHITE LONGBOI Well-Known Member
    White 21 DCLB OR 4x4
    Yes, as others have stated, 4WD is only to be used on loose surfaces to allow the wheels to travel at different speeds. When in 4WD your wheels are travelling at the same speed which becomes an issue when turning if you maintain traction, and results in hopping or chirping as the drivetrain binds from the wheels being unable to slip.
  10. Jan 11, 2021 at 10:54 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Yes, as explained... the front and rear are locked together in 4WD but rotate at different speed. You are feeling the 'binding' because you are on a semi-firm surface. If you were in slushy snow, mud, or sand you won't notice the binding as it won't happen. Save the 4WD for when you actually need it (slipping tires).
  11. Jan 11, 2021 at 10:55 AM
    colbychristner
    Colby
    Bc when I’m on dirt or off-roading I never had the issue so I guess tires were gripping just find and didn’t need 4x4
    eon_blue likes this.
  12. Jan 11, 2021 at 10:56 AM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Read the section of your manual on the 4x4 system. This is normal when the wheels cannot slip a bit.
  13. Jan 11, 2021 at 10:57 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Never turn with 4WD on dry pavement. Good chance you’ll snap an axel
    zoo truck likes this.
  14. Jan 11, 2021 at 11:04 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Yes, but the dirt can provide more slip, depending on what kind of snow you're driving in. You mentioned slush. It is possible that your tires were gripping good enough to bind up the 4x4 system when turning. However, you'll always have some degree of binding the sharper you turn. You'll just mitigate it far more by allowing for slippage.
    shakerhood and zoo truck like this.
  15. Jan 11, 2021 at 11:04 AM
    CRSTRD
    CRSTRD Well-Known Member
    2020 Tacoma TRD Off Road
    The reason you have the 2 designations of 4WD and AWD. My definition may be overly simplistic but, in general, 4WD is a part-time system intended for use in specific, low-traction situation. AWD vehicles are designed to be driven in any traction conditions, including dry roads.
  16. Jan 11, 2021 at 11:11 AM
    Tehkoema
    Tehkoema Well-Known Member
    Ottawa, ON
    2024 TRD Sport 6MT
    do not use 4WD on high traction surfaces. This isn't a fulltime 4WD system.
  17. Jan 11, 2021 at 12:54 PM
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    Plus look at slip button..wave lines on the switch...turning on or off might help? read owners Manuel...and yes ..in 4x4 ..it will bind on harder turns, on any hard surfaces, this is normal.
    You can go up to 60-65 miles in 4high...
    Try not to make any turns ? ..um.
    Going straight..is better than going crooked..quote by 4high...
    Aloha
  18. Jan 11, 2021 at 2:02 PM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    The wheels were binding because they weren't slipping. You need to have some slippage when in 4WD.
  19. Jan 11, 2021 at 2:06 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    You won't snap an axle. Higher levels of component wear (joints, bearings, etc) will happen but if it were possible to snap an axle doing that rock crawling would never be possible. These trucks are way tougher then that.
    Tttacodan likes this.
  20. Jan 11, 2021 at 2:06 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    No, you can hit the speed limiter in 4HI if you want. The only speed limitation is for the act of doing 2HI to 4HI shift.
    As for the VSC Off button, it won't do a thing for his problem.
    Tttacodan and ZColorado like this.
