4x4 with rear diff locker, aftermarket/stock/rare???
Discussion in 'New Members' started by Kattech17, Feb 19, 2021.
  1. Feb 19, 2021 at 11:25 AM
    Kattech17
    Kattech17 [OP] New Member
    Kat
    06 Tacoma off-road
    Nada
    Okay I had a 2006 access cab with 4x4 and the rear locker and the 6 ft bed. That is bought used. Unfortunately that truck got totaled. I have now finally gotten to a point where I want to buy another Tacoma. I want the same truck but a different cab size. Now the long bed and double cab size with 4wd is easy enough to find but I have noticed that most 4x4s do not have the rear locker button. Before I get into the questions, I gotta say with this truck I usually just used the 4wd when off-roading but a friend told me to try off-roading and playing with just the rear locker. It was totaled before I really got to use it to the point where I can figure out what the performance difference is and when to use rear lockers over 4H.
    so is having both 4x4 and rear locker normal or rare? is that something that could be ordered in 2006? because I think when this truck was new it was "loaded" because it also had the long bed and rear power outlet. I bought it used.
    do I really need a locker or can I just be in H2?
    performance wise what is the difference?
    will I even miss not having the locker button/feature?
    If I wanted to could I install this... I have general automotive knowledge but I am confused if I would need a new rear differential that is made for 4x4 system and also for rear locking. or if I can add a kit that adapts to the existing rear differential.
    I realize either way is expensive.
  2. Feb 19, 2021 at 11:28 AM
    eon_blue
    Azusa, CA
    The rear locker is available on the TRD Offroad package, 4x4 and 4x2
    If it's a 4x4 with no TRD Offroad package then there will be no locker, was the same way on 2nd gen Tacomas from 2005+ as well. Only TRD Offroads get the e-locker
  3. Feb 19, 2021 at 11:32 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
  4. Feb 19, 2021 at 11:50 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW
    :hattip: :cheers:
    buckhuntin-tacoma and TnShooter like this.
  5. Feb 19, 2021 at 11:59 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Your 06’ had an open differential. (So does my 07’)
    In 2009 all the trucks went at a break actuated limited slip differential.
    While the differential is still technically “open” it preforms much like a limited slip differential.
    2005-2008 trucks w/locker don’t preform as well in 2WD as the trucks with LSD differentials.
    I guess my point is, don’t let the locker keep you from buying the truck you want.
    If you find a 2009+ truck with Auto-LSD it will preform better than your 06’ in 4H and 2WD.
    Yeah, it won’t be “as good” as locked truck. But most people don’t really need the locker. (Me included)
    buckhuntin-tacoma likes this.
  6. Feb 19, 2021 at 12:01 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Welcome to the TW
    TnShooter likes this.
  7. Feb 19, 2021 at 12:16 PM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    If you want a locking diff, I suggest a Detroit Tru Track for a DD. As far as install, if you have to ask, you probably can’t do it yourself. It requires a few specialized tools and some experience. If you are doing this on anything but a new vehicle, change out all the bearings and seals while you are at it. It’s also a good time to re-gear. I have run Tru Tracks before and really like them for a DD. Mechanical, no clutches, reliable, none of the issues you have with an aggressive locker, less expensive than an e locker or air locker, and no maintenance or friction modifiers like with a clutch pack limited slip.
    A guy I know did gears front and rear, bearings, seals, a Tru Track, installed at a local shop for 2200. Straight axel truck with Dana’s. Not sure if a Tacoma might be more or less, but it’s a baseline figure. I’ve done a few straight axel installs before and it’s a little bit labor intensive. That’s where a good part of the cost comes from. Just FYI, if you did choose to re-gear, aftermarket gears tend to make a little noise. However, it’s less of a problem with a truck than say a 4 Runner or FJ.
    Welcome to TW, you will be dazzled, you will be amazed, you will spend lots of money.
  8. Feb 19, 2021 at 3:53 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  9. Feb 19, 2021 at 5:03 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    welcome! Its on all TRD Off-Road and TRD Pro trim levels.
