4x4 Won't Engage - Brand New Tacoma - Looking for answers - Please Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TLTPhotography, Jan 5, 2019.
  1. Jan 5, 2019 at 11:39 AM
    #41
    Mack7n
    Mack7n Well-Known Member
    Josey
    Old Town, ME
    2018 Tacoma TRD Sport DCSB 6M BBP/2018 T4R TRD Pro Calvary Blue
    Is no one else concerned with the fact, they replaced only 1 tire on a 4WD system? 4WD/AWD, should never have just 1 tire replaced, unless it's extremely low mileage when the damage happens. Having that much difference in tire size isn't good, at all.
    Back to the original issue, tire size shouldn't make a difference at all with the 4WD system engaging/disengaging. You could have 4 different size tires, and it shouldn't be an issue (aside destroying your xfer case/CVs in the process). Tell dealer to go pound it, and go to a different dealer.
    xxTacocaTxx likes this.
  2. Jan 5, 2019 at 11:41 AM
    #42
    SCJeffro
    SCJeffro @Voodoo_Blu_Taco
    2021 Voodoo Blue TRD Sport
    Yeah, I could see tire size being an issue if it was a significant difference like 2 different sizes entirely.. But when you are talking about 3/32 difference, that is crazy talk.
    tcjacado and JStarr[QUOTED] like this.
  3. Jan 5, 2019 at 11:47 AM
    #43
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
  4. Jan 5, 2019 at 11:49 AM
    #44
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    Well OP has already posted a "Buyer Beware" video to YouTube before even knowing what is actually wrong.
    xxTacocaTxx, hiPSI and NickleCityTaco like this.
  5. Jan 5, 2019 at 11:51 AM
    #45
    su.b.rat
    su.b.rat broken truck
    stu8319, 02Duck and SCJeffro like this.
  6. Jan 5, 2019 at 11:55 AM
    #46
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    The ABS wheel speed sensors (which I’m assuming the truck has, most do) would be showing different speeds due to different diameter tires. If the computer was programmed to check those and only engage within a certain tolerance window it would not function. I’m not saying the Tacoma does or can do this, but it is easily possible with the electronics on most vehicles.
  7. Jan 5, 2019 at 11:55 AM
    #47
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
  8. Jan 5, 2019 at 11:56 AM
    #48
    su.b.rat
    huh? well, ok. thanks for the news on Subarus then?
  9. Jan 5, 2019 at 12:02 PM
    #49
    Mack7n
    Josey
    Old Town, ME
    He wasn't giving us news on Subaru, he was saying he understands the different tire sizes due to experience on the Subaru AWD System. So, his meme is still valid. And yes, our Tacomas aren't AWD, they're 4WD, which still has the same Tire Size rules that are applicable.
  10. Jan 5, 2019 at 12:06 PM
    #50
    su.b.rat
    he was recommend
    gawd. :alien:
    so which Tacoma owner here uses a tire shaving service? I'll wait.. sorry i dislike being sarcastic but no communication is happening so nevermind and no problem.
    stu8319 and 02Duck like this.
  11. Jan 5, 2019 at 12:07 PM
    #51
    Mack7n
    Josey
    Old Town, ME
    Honestly never heard of Tire Shaving services until just a few weeks ago. It's something I would never consider doing either. Either buy new, or take the highest depth tread tires, stick em on the back, and tear em up to wear em down. ;)
  12. Jan 5, 2019 at 12:10 PM
    #52
    Odi412
    Odi412 Well-Known Member
    PIttsburgh
    20 pro
    Last year, my new 18OR just off the lot. Stopped in gravel, engaged 4lo, heard actuator make loud clunk switching to 4hi. Was blinking like yours, and would not disengage 4lo. Eventually I went into neutral and drifted downhill (steering wheel straight) while turning to 4hi and it worked. It’s also done it, and I’ve had to go in reverse, and then to neutral drift to get it to disengage from 4lo-4hi and from 4hi-2wd. And then restart vehicle to reset sensor.
    That was only the first few days. Initially, I assumed it was the actuator, so I called the dealer I purchased from and they said they’ve noticed that on numerous new Tacoma’s and tundras, but they had no explanation. I didn’t push it with them bc, for now, the issue has stopped. At this point Ive chalked it up to the 4x4 system just needed circulated and lubed.
    While I wouldn’t drive in 4wd for an extended period of time on different tread depths, your slight tread depth difference is obviously not what caused the problem you’re having. That’s absurd. If the neutral or reverse trick and restarting the truck to reset it doesn’t fix your problem, it’s absolutely your actuator, imho.
  13. Jan 5, 2019 at 12:12 PM
    #53
    famof5taco
    famof5taco Well-Known Member
    Shelton
    VA
    17 TRDORDCSB
    pro grille, raised vinyl "TACOMA" letters on tailgate, de-badged, tint, ARE truck cap, BFG KO2s waterport, vinyl Tacoma inserts in dash, red "TRD Engine"push button start, MTF!!!
    OP, I think you got your answer on the tire size. That isn't the issue, it's absolutely insane they even tried that claim.
    Secondly, your video has proven your competence and reposnes to previous statements that you've both used the system and manipulated while driving and reversing etc.
    Let me respond to the "claim" ofweak, unreliable truck for the other 2 issues. You're mad that you had a tire go flat with low mileage? Really? This side Toyota quality, it doesn't matter if you run bfgs, toyos, Cooper's etc, NY one of them can get a flat not a real "quality" issue. (though I think we'd all appreciate a more off-road friendly tire).
    Next, you mentioned your sensor in your bumper getting scratched. Well these are sensitive items that measure sensitive space and simply can't be tough by design. Possible?maybe ,but unlikely and unnecessary for VAST majority of usages. That's one reason I opted to NOT getthat package.
    They are reliable trucks, but with more technology comes more issues, not reliability.
    Go smash the dealership for lies and good luck with the truck .the 4wd not engaging might be a legit issue that you DO deserve to have fixed .
    02Duck likes this.
  14. Jan 5, 2019 at 12:22 PM
    #54
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    IMO all 4x4s should have lock out hubs and a manual transfer shift. This push button shit is bound to fail...But hey...that's how it is these days. "Push button" this and "touchless" that...
    Newfiebruh, Speed Nut, JCOOR and 3 others like this.
  15. Jan 5, 2019 at 12:25 PM
    #55
    Mack7n
    Josey
    Old Town, ME
    Exactly. The only thing I love most on my T4R Pro vs my Tacoma Sport. The Level 4WD, vs this shit Turn Knob. :( Why they only added the lever to the Pro's on the Tacomas, upsets me dearly.
  16. Jan 5, 2019 at 12:26 PM
    #56
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    Not much more to add... I’m disappointed in some of the dealership experience stories on this forum. Yours is certainly worth telling to corporate. When the service manager started explaining issues that seem like an unusual situation (like your differing tire size causeing 4x4 failure), I would start a video of that explanation in real time and tell the representative I’m just documenting the explanation for corporate claim submission. They shouldn’t object to the documentation if what they’re saying is reasonable and more likely correct than not. I use my smartphone video all the time for such record keeping purposes... that action normally gets special attention to my issues.
    Tacoma2020 and oconnor like this.
  17. Jan 5, 2019 at 12:36 PM
    #57
    Flatout110
    Flatout110 Well-Known Member
    Tony
    Long Island, NY
    2019 Tacoma
    Engine oil By-pass filtration system. B&M transmission cooler Rustproofed
    Yuppie trucks
  18. Jan 5, 2019 at 12:46 PM
    #58
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    You are going through a lot of trouble without needing too. It’s already been said tire size is not the issue. Go back, have them put it in writing that the tires are causing your truck not to engage 4wd. If they won’t stand in front of them and call Toyota cooperate and file a claim. Also if they said it was fixed then why not make the tech/advisor go with you on a drive and prove it’s fixed. YouTube videos and this thread are not fixing your truck. If you have another Toyota dealer near I would see what they say.
  19. Jan 5, 2019 at 2:19 PM
    #59
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    Don't be dense. The comment was about tire shaving.
    NickleCityTaco likes this.
  20. Jan 5, 2019 at 2:21 PM
    #60
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
