4x4 wont engage.
Discussion in '1st Gen. Tacomas (1995-2004)' started by tanner56, Dec 18, 2011.
  1. Dec 18, 2011 at 4:30 PM
    tanner56
    tanner56 [OP] Member
    99 tacoma trd 4x4
    im new to the world of tacoma's and im looking for some help. a few weeks ago i picked up a nice 99 tacoma. its a sr5 trd 3.4 with standard transmission and manual transfer case.
    everything has been going flawlessly until last week when i was wheeling. i had it in 4x4 and stalled after i got to the top of the hill, when i started the truck the 4x4 would not engage. now the next day i tried to use it again and it worked. now it only works every so often. when i put it in the 4h position the light will not come on the dash and i can hear a clicking sound coming from the passenger side of the dash. if anybody has any suggestions or could help me figure out the problem that would be great!
    thanks Tanner.
  2. Dec 18, 2011 at 5:21 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    Two things pop into my mind here could be problems why not working.
    First one is the valve under the hood drivers side just right behind the battery are you valves They could be going out or bad on you. Check with a volt meter to confirm you are getting voltage to one. ( blue if i remember right) IF you hear that valve (CLICK) odds are its good.
    Second look for are leaks or cracked rubber hoses going down to the actuator. Also check the hoses going from the valves to the engine make sure they are not cracked also. there is a few under the truck where the actuator is at also.
    One more There is a (one way valve) on the lines from the engine to the valve make sure its working If the engine is running and you take the hose from one way to valve you should hear air going into the tub(suction). If not pull the oneway valve off see if you have suction there.
  3. Dec 18, 2011 at 5:25 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    by standard transmission do you mean manual?
    the click might be the light in the dash board or the transfer case clicking into 4 hi or 4 low.
    I know with mine every now and then you have to move the truck a little bit(to get the gears to match up) and it will go right in.
    when you try to switch from 2hi 4hi or 4 low try moving a little bit
  4. Dec 18, 2011 at 5:30 PM
    tanner56
    99 tacoma trd 4x4
    hayabusa - i did notice a little mess underneath it.
    tacomaboss - the transmission is manual and i have tried moving it but nothing happens.
  5. Dec 18, 2011 at 5:31 PM
    TACOMABOSS
    96 SR5 4x4
    meaning the shift lever doesnt move or it moves and nothing happens?
  6. Dec 18, 2011 at 5:34 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Same shit happens with mine, I dont even have a 4wd light anymore, don't need it. Put it in 4wd and DRIVE forward a few inches, or backwards, seems to work better.
  7. Dec 18, 2011 at 5:36 PM
    tanner56
    99 tacoma trd 4x4
    i mean the 4x4 doesnt engage when i move forward or backward when the lever is in 4hi
  8. Dec 18, 2011 at 5:38 PM
    TACOMABOSS
    96 SR5 4x4
    huh. how much do you move forward or backword? a few inches or a few feet?
  9. Dec 18, 2011 at 5:42 PM
    tanner56
    99 tacoma trd 4x4
    ive tried it 20 feet each way and get no results.
  10. Dec 18, 2011 at 5:44 PM
    TACOMABOSS
    96 SR5 4x4
    :confused: Then i have no idea. Thats not what I thought you were talking about
  11. Dec 18, 2011 at 6:59 PM
    Supra TT
    Eric
    Indiana
    My truck and several other people I wheel with stall everyday when wheeling. Sometimes 4 times in a minute haha. Never had an issue.. Something doesn't seem to be adding up.
  12. Dec 18, 2011 at 9:45 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Can you clarify this? When I read this, it makes me wonder why you would disengage 4wd (move the lever from 4hi to 2hi) siimply to restat the engine after a stall. Did you actually move the lever just to restart? If you did not, then 4hi was still engaged...
  13. Dec 19, 2011 at 6:32 PM
    hayabusa3303
    florence sc
    95.5 taco 4x4
    the actuator is not getting a vacuum to engage 4wd why the light is off. Or the actuator has failed.
