4x4 wont engage
Discussion in 'Toyota Trucks & SUVs' started by brendeze23, Dec 17, 2012.
  1. Dec 17, 2012 at 8:18 AM
    brendeze23
    brendeze23 [OP] Member
    DAN
    2008 4X4
    I have 2008 4x4 double cab manual...it wont engage the 4 wheel when i flip the switch,, i hear the clicking behind glove box.. and when truck isnt on i can hear what sounds near the driver wheel.. but the flashing on indicator doesnt go away.. any ideas?
  2. Dec 17, 2012 at 8:29 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    Did you try going forward or backwards a bit while the switch was on 4h??
  3. Dec 17, 2012 at 8:33 AM
    barker14
    barker14 sexual ninja
    Adam
    Nova Scotia, Canada
    05 Tacoma TRD Off Road
    Complete OME suspension with Dakar leaf pack. Clarion touch screen Sport hood Tri fold Tonneau cover
    Rev to about 6 grand and side step the clutch.... No don't actually do that. Sometimes you have to rock the truck a bit. Try slowly driving forward and backwards. The more you use the 4x4 the easier it is to engage I find. Most people recommend putting it in 4wd and driving down a dirt road if possible a few times a year.
  4. Dec 17, 2012 at 8:34 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Make sure the clutch pedal is all the way down to the floor.
    edit... thats ^ for getting into 4L.
  5. Dec 17, 2012 at 8:48 AM
    brendeze23
    DAN
    2008 4X4
    i have pushed clutch all the way to the floor.. i have tried switching it sitting still.. and going form fwd to rev...
  6. Dec 17, 2012 at 9:03 AM
    barker14
    Adam
    Nova Scotia, Canada
    Drive forward slowly on a gravel road and zig zag from side to side. Just go slow and don't turn from lock to lock. It should engage.
  7. Dec 17, 2012 at 10:03 AM
    brendeze23
    DAN
    2008 4X4
    nope that didnt work either..
  8. Dec 17, 2012 at 11:06 AM
    barker14
    Adam
    Nova Scotia, Canada
    Sure you don't have a pre runner? Check for front axles... You might have something wrong electronically. I have heard of actuators going bad. Not really sure where to start when troubleshooting these. Might be a dealership thing unfortunately... As a last thing you could try, if you can put the truck up on stands and engage the 4 wheel drive then rock the front tires until the diff engages. This worked for me with my rear wheels when my diff lock wouldn't engage.
  9. Dec 17, 2012 at 11:09 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    As long as your engaging it correctly it could be actuator issues...
    search for "4x4 actuator issues" and tons of info should pop up.
    It's a pretty easy part to replace if need be, but it's expensive. To the best of my knowledge the way to keep 4x4 working is to use it. Lack of use seems to make "using" it problematic. I'm pretty sure the manual tells you to use it for 10 miles per month.
