4x4 worries
Discussion in '1st Gen. Tacomas (1995-2004)' started by Streettaco, Jun 26, 2016.
  1. Jun 26, 2016 at 8:28 PM
    Streettaco
    Streettaco [OP] Member
    Erik
    96 4 cyl
    N/A
    I put my Tacoma into four wheel drive and the wheel radius and acceleration were more restricting than usual so I took it out of four wheel drive and when the steering wheel is all the way over it makes a screeching noise anyone have this problem before and know what's going on?
  2. Jun 26, 2016 at 8:38 PM
    Bbqtaco1
    Bbqtaco1 Active Member
    2004 Tacoma TRD OR 2WD
    Not to be a smartass, but what kind of terrain where you on ? And when was the last time you used your 4wd ?
  3. Jun 26, 2016 at 8:43 PM
    Streettaco
    Erik
    96 4 cyl
    N/A
    It was on a back road and I came up to a bumpy and muddy section and last time I used my 4x4 was about 2 weeks ago going on other back roads.
  4. Jun 26, 2016 at 9:37 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Does it screech while you are moving or just turned? Where approximately is the noise coming from? Is the driveline still binding like you are still in 4wd?
  5. Jun 26, 2016 at 9:42 PM
    Streettaco
    Erik
    96 4 cyl
    N/A
    Just turned and sounds like it's from the front and no it doesn't
  6. Jun 26, 2016 at 9:48 PM
    memario1214
    Colton
    Missoula, MT
    If you can't be troubled to at least give me a detailed response I am not going to help... If you are out in the sticks, limp it home in 2wd and take a look at it in the morning and give us some good info. Have someone else help you to isolate the noise if you need to. There's a very good chance that you will not be able to address the issue in the field.
  7. Jun 27, 2016 at 9:53 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    You are binding your transfer case and your tires are trying to grab the pavement, therefore the screeching. Don't use 4wd on dry pavement. Problem solved
  8. Jun 27, 2016 at 9:58 PM
    eon_blue
    Azusa, CA
    Not that this is your issue but I was out wheeling with a guy in an older 4runner a few weekends ago, toward the end of the trail his rig started to make the same sounds you describe (though it's a little hard to say for sure without hearing it in person or seeing a video). Turns out his front diff had no fluid in it, it had sprung a leak awhile back and he neglected to service it.
    Again, not saying this is what you're dealing with but it reminded me of his situation. His was so bad it blew up his front diff (didn't help that he was out wheeling all day when it happened). He had to limp off the trail several miles in 2wd but fortunately he was able to do that. Might want to check your fluid level and see what it looks like. Hope it's nothing that serious but can't hurt to rule it out.
