4x4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dax, Jan 1, 2016.
  1. Jan 1, 2016 at 8:18 PM
    Dax
    Dax [OP] Member
    Daz
    2005 long wheel base 4x4
    Hi all ,
    I just bought a 05 taco and am new to using 4x4 ( and feeling a bit stupid ) I switched on 4x4 hi going up the mountain the other day but conditions were just icy. I done it again today and have just recently learned that I shouldn't use the 4x4 hi when on roads especially dry. Is there any chance I have done damage?
    Thx
  2. Jan 1, 2016 at 8:22 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You're fine
    Rock Lobster likes this.
  3. Jan 1, 2016 at 8:23 PM
    medic2230
    Murph
    Bama! Roll Tide
    ^^This
    Dax[OP] likes this.
  4. Jan 1, 2016 at 8:25 PM
    RedRed
    RedRed TACO TUESDAY!!!
    Red
    Lake Norman NC
    15 taco with stuff & things
    1.75" Billy's plus 1/4 spacer on both sides. 1" block in rear. 265/70/17 nitto g2 SCS matte dark bronze 6s
    ^^^ no worries
    Dax[OP] likes this.
  5. Jan 1, 2016 at 8:26 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    4 HI is ok to use on any road conditions, but below 60mph. Right?
    Dax[OP] likes this.
  6. Jan 1, 2016 at 8:28 PM
    OZ-T
    Peter North
    British Columbia
    There is no top speed with 4WD engaged , just a top speed at which you can engage it
  7. Jan 1, 2016 at 8:29 PM
    RedRed
    Red
    Lake Norman NC
    Honestly I wouldn't use it useless you are in slick road conditions. No point. Also read owners manual. If it didn't come with one used then get one off of eBay.
    Dax[OP] likes this.
  8. Jan 1, 2016 at 8:34 PM
    Dax
    Dax [OP] Member
    Daz
    Thx for your replies - relieved newbie :) love my Tacoma :)) thx
    RedRed likes this.
  9. Jan 1, 2016 at 9:00 PM
    gazingwa
    gazingwa Well-Known Member
    Slower Lower Delaware
    15 PreRunner Doublecab 2.7
    OEM: Backup Camera, Bed Mat, Wiper Switch. Aftermarket: Fog Lights, Pop and Lock, Truxport, MS2's Debadged
    Please note this doesn't mean you should use it on a dry road. Just that since there is no noise or transfer case explosion this time you didn't hurt it. They need to be engaged every once and a while. As long as your tread depth is similar you can engage it on a dry road if you don't turn. It's the turning on high grip surfaces with 4wd engaged that causes binding which can destroy u joints and transfer cases.
  10. Jan 1, 2016 at 9:02 PM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    your fine just don't make a habit of using 4WD in dry conditions. Going straight won't hurt it, It's the sharp turns that can bind your center diff
  11. Jan 1, 2016 at 9:03 PM
    OZ-T
    Peter North
    British Columbia
    Tacomas don't have a centre diff
  12. Jan 1, 2016 at 9:08 PM
    723rdCAT
    723rdCAT Well-Known Member
    Kentucky
    15 SR5 4x4 access cab mgm
    Just dont turn hard on a hard top road with 4Hi engaged or it will bind. For example turning 90 degrees. I dont see why one would want to use 4x4 on a slick road rain on a hard top road is not a reason to engage 4x4.
    The only time I engage 4Hi on a paved surface is if I need to get the monthly 10 miles to lube the gears and I dont have the chance to actually drive on an off road surface. That being said if you did bind a few times(you will know if you did) it shouldn't do any damage. On snow or thick ice it would be useful to run 4Hi in rain or mild ice Id just slow down and drive more carefully in 2WD.
    Our trucks have part time 4WD which means that there is not a computer sensing the road surface and adjusting the power.
    Engage 4Hi below 60 MPH but you can go past 60 afterwards. In 4Lo dont go much past 35 MPH but honestly you wont want to anyway because your tachometer will be near 5000 anyway if you go much past 25 in 4Lo.
    asuchemist likes this.
  13. Jan 1, 2016 at 9:09 PM
    OZ-T
    Peter North
    British Columbia
    In the OP it says the roads were icy
  14. Jan 1, 2016 at 9:11 PM
    RedRed
    Red
    Lake Norman NC
    :thumbsup:
  15. Jan 1, 2016 at 9:13 PM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    transfer case... whatever
    RedRed likes this.
  16. Jan 1, 2016 at 9:24 PM
    Dax
    Dax [OP] Member
    Daz
    I did park at the top of mountain with the 4 hi on and it didn't feel good - I know now not too just hope I didn't damage :) all advice makes sense
  17. Jan 1, 2016 at 9:30 PM
    723rdCAT
    Kentucky
    What does it didnt feel good mean? The steering is going to feel much tighter than it does in 2WD that is normal it will feel even tighter on a softer less firm surface. You can actually break your fingers or thumbs on the steering wheel on the right surface and conditions if the wheel snaps suddenly and they are in the way.
    Better explanation required.
  18. Jan 1, 2016 at 9:42 PM
    Dax
    Dax [OP] Member
    Daz
    Yes just tighter and locking up ( as if the e brake was on) - I'm new to 4x4 as I said so it is prob normal for areas that aren't slippy enough for 4x4 to be engaged . Lesson learned
  19. Jan 1, 2017 at 3:49 PM
    Rooblik
    Rooblik Taxation is Theft.
    Grey 2009 Tacoma DCLB SR5 V6 TRD Sport
    This thread was worth reading. Thanks y'all.
  20. Jan 1, 2017 at 3:59 PM
    Pigpen
    Dan
    Northwest Montana
    All of ten posts and already copping a 'tude...
