4x4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Srichard, Nov 3, 2020.
  1. Nov 3, 2020 at 2:06 PM
    Srichard
    Srichard [OP] New Member
    Sarah
    Toyota Tacoma 2013 off road
    So I am having problems with my 4x4 working lights blink. I have replaced front actuator and transfer case also replaced 4x4 main control board. At the dealer now and they can’t figure it out either they have been working on it for 4 hours with no answer and 400 in the hole. Any suggestions?
  2. Nov 3, 2020 at 2:26 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Wait a minute, they charge you 400 and said they don’t know and can’t fix it?
    Gunshot-6A likes this.
  3. Nov 3, 2020 at 2:36 PM
    Srichard
    Sarah
    They are still working on troubleshooting but as of now they don’t know what’s going on.
  4. Nov 3, 2020 at 2:47 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    My Highlander lost half of the instrument panel (stuff went to zero), vehicle still ran. I was $160 in the dealer hole (they couldn’t fix it). The Mechanic apparently had never seen a speaker with an external x-over (he was complaining that could be the issue) and they wanted $600 for a full electrical troubleshoot (with no guarantees). I told them no thank you and took it home.
    I was in it about 45 minutes when I found that the ground wires need cleaning. There were 3 ground wires going to the block. Saved myself $$.
    TRDSport10 likes this.
  5. Nov 3, 2020 at 3:16 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Wow!
  6. Nov 3, 2020 at 8:34 PM
    Taco'09
    Taco'09 Well-Known Member
    OP, you indicated that you replaced a couple of components. Did you do this yourself or have the dealer do them? I'm trying to determine if you are a DIY type, and if so and have a VOM meter I can send you some diagnostics.
  7. Nov 4, 2020 at 12:08 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Just replacing parts until maybe you fix the problem $$$$$$$$
  8. Nov 5, 2020 at 2:47 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    In theory there are only 6 things that could be wrong: the front diff actuator, transfer case actuator, transfer case limit switches, 4wd ECM, 4WD selector switch, and any associated wiring. If you’ve replaced two of those with known working parts, that leaves 4 potential options. Have at it.
