4x4's & Chains
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rkoa63, Dec 20, 2015.
  1. Dec 20, 2015 at 8:34 AM
    Rkoa63
    Rkoa63 [OP] Member
    Southern California
    21 4x4 DCLB
    I was planning my road trip next month and was going to purchase a set of chains when I remembered that when I purchased the truck the dealer had me sign a document saying that I wouldn't put chains on the vehicle. What is the reason behind this? Is solely due to the clearance issues with chains on the front tires?
    Thanks!
  2. Dec 20, 2015 at 9:06 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If I had to guess....
    Liability......
    Toyota doesn't want to be responsible for damages that chains can cause for a variety of reasons. I've never run chains myself and know nothing about them - but, I'm sure they can be installed improperly, break apart, fly off, cause all sorts of vibrations & irregular stresses to bearings & seals, yadda yadda.
  3. Dec 20, 2015 at 9:14 AM
    NmBeefTaco
    NmBeefTaco Well-Known Member
    Greg
    New Mexico
    18 TRD Off Road Access Cab
    Toytec Boss lift, AAL, Ride rite air bags, Daystar cradles, Total Chaos UCA, Icon 17 inch Rebounds, 285/70R17 BFG KO2s, Ruff country 30” LED light bar kit, ruff country tri fold bed cover. Interior LED lighting and lic./reverse LED lights.
    ^^^^ This......Yada Yada Yada
    But when installed properly!!! You will feel invincible and won't believe:headbang::mudding: the performance in heavy deep snow or mud:headbang:
    FirstGen Jer and Nickel like this.
  4. Dec 20, 2015 at 10:04 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I don't see how that document could have any legal standing since your state requires chains under certain conditions.
    Maximus likes this.
  5. Dec 20, 2015 at 10:23 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    What conditions would southern Cali encounter that requires chains? Off-roading?
  6. Dec 20, 2015 at 10:26 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    [​IMG] I run these on the back only when I really need them. The way it's snowing this year, I believe I'll use them.
  7. Dec 20, 2015 at 10:33 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    There is no problem with properly fitted chains on the rear. The waiver may be because the preferred location for chains on 4wd trucks is often the front tires. On our trucks there isn't much room at the UCA and they can tear up the sensor cables. There may be chains or cables designed to work with our minimal clearances but Im not sure where to find them.
  8. Dec 20, 2015 at 10:40 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Snow in the mountains ie; Snow Summit, Big Bear, etc...
    Willbeck and Maximus like this.
  9. Dec 20, 2015 at 11:04 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    If you hunt Elk, you run chains!
    midwestisbest and G.T. like this.
  10. Dec 20, 2015 at 11:13 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    You should look at the document you signed, that would be the best way to find out.
    BrettBretterson likes this.
  11. Dec 20, 2015 at 11:21 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Lol no. If the road conditions ever get to the point of 4x4 and chains required the road will be shutdown hours before that occurs. Done countless trips to Mt high etc and unless I got stopped in the middle of a hill id never even need 4x4 let alone chains even in the worst conditions those roads saw.
    I have a good set of legit chains for a just in case moment that I always keep with me in my travels up to mammoth etc. Never needed them and never will need them on any marked road. Only time I could possibly need them is if I was pulling someone out of a ditch on the icyest of roads or got stuck off road.
    Chains will only fit in the rear unless you have skinny tires n wheel spacers in the front.
    agunday21 likes this.
  12. Dec 20, 2015 at 11:35 AM
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    While incredibly rare, I have seen CHP implement R-3 chain controls.
    http://www.dot.ca.gov/dist2/chainup/requirements.htm
  13. Dec 20, 2015 at 11:41 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    I think the chains are pretty useful even if only installed on the back. You don't want to use them at speed - but as mentioned earlier in the thread they can get you moving in deep snow or mud where 4wd can't. Ignore the piece of paper from the dealer - probably not sanctioned by Toyota anyway.
  14. Dec 20, 2015 at 11:55 AM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    In Cali. you have to carry chains even if you are aloud to go without installing them. They want to see them in your possession.
    06yoda and Maximus like this.
  15. Dec 20, 2015 at 12:05 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    I drive a 4x4 with 35s and I carry chains. Tires don't get good traction on ice in the mountains. Ask me how I know.
    BenTheMan likes this.
  16. Dec 20, 2015 at 12:14 PM
    ChesterTaco
    ChesterTaco Well-Known Member
    Chester, CA
    '15 BRM DCSB OR, 1993 Pickup
    Gentex 453 Mirror, Paid-off Mod.
    It is R1 conditions at my house right now. Means 4wd with M&S tires are okay but must carry chains.
  17. Dec 20, 2015 at 12:15 PM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Mostly right, two caveats.
    R1 and R2 require all vehicles, including 4x4 to own, carry and show the CHP officer chains and any manned chain check point. I've run into this more than once in the San Gabriels just north of LA. So while you may never need to put them on, you do need them in your vehicle.
    R2 requires not just 4x4 but also tires that have a snow tread if you want to avoid actually putting on the chains. For CA that doesn't mean true snow tires as a mid-westerner would consider them instead the definition is:
    Most AT tires people run on our trucks already meet this requirement, just check your sidewall. But worth noting that 4x4 alone doesn't get you out of actually putting the chains on in R2 - got to have proper tires too.
  18. Dec 20, 2015 at 12:21 PM
    File IFR
    Central MA
    Even those organic food and brie eatin' SmartCar drivers have to have chains? What is the logic behind that rule for the southern most counties of Cali???
    NVRM, it has to do with Cali laws :D
  19. Dec 20, 2015 at 12:35 PM
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
    Growing up in SoCal (just north of San Diego) I remember Julian (an hour from San Diego) getting slammed a couple of times. Over 4' one time if I remember right (early '90's). It's not east coast or PNW amounts of snow but it's enough to really screw up your day, especially since there are lots of people down there with no winter driving experience.
  20. Dec 20, 2015 at 12:55 PM
    DVexile
    Ken
    I think you misunderstand - no one has to own or carry chains *unless* they are trying to enter a chain control area. Chain controls are only applied when there is snow. In So Cal that is only the mountains and only for a few days a year. So you only need to carry chains if you want to drive in the mountains while there is snow around.
    In most cases R1 is applied and held in So Cal mountains after snow simply as a crowd control measure. Buying chains is your ticket price for entering the winter wonderland...
    Actually when it comes to road laws CA has some of the best in the nation. And besides laws it also has developed some of the best practices in traffic management. The mid-Atlantic and northeast are the fucking dark ages when it comes to common sense road laws.
    Right turn on red brought to you by CA.
    Legally drive into crosswalk behind a pedestrian brought to you by CA.
    Those two laws plus many others have been pioneered by CA and the slowly adopted by the rest of the nation.
    Remove vehicles from traffic lanes immediately for minor collisions without waiting for a LEO to show up. Highway Patrol vehicles equipped to push disabled vehicles out of lanes without need for a tow truck. Officers keeping the rear of their vehicles mostly dark during late night traffic stops (drunks steer towards bright blinking lights and are more likely to hit a lit up cop car the one with just its rear hazards on).
    I made fun of CA laws and the CHP for years until I started living in other states. Now I realize they are actually near the top of the game. They have to be given the number of vehicles being moved around. MD/VA/DC could have way fewer traffic problems if they'd just do a few more things like CA...
    Lord Helmet, Crom, nagorb and 5 others like this.
