4x4's & Chains
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rkoa63, Dec 20, 2015.
  1. Dec 20, 2015 at 1:03 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    That's a better and clear explaination, thanks DV.
  2. Dec 20, 2015 at 1:35 PM
    Rkoa63
    Rkoa63 [OP] Member
    Southern California
    21 4x4 DCLB
    The document doesn't specify a reason. It says, "As equipped this vehicle may not be operated with tire chains but may accommodate some other type of tire traction device."
    I'll be driving from So Cal to Northern Idaho and since I've never made the trip in winter, I wanted to be prepared. It looks like some of the consensus here points to just having chains on the rear tires, if at all. I've never needed chains up to this point in my life living in So Cal, but going to Idaho could be a completely different story.
  3. Dec 20, 2015 at 4:17 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I agree - forget the scrap of paper, get a pair of chains for the rear, get familiar with installing them before needed - try in your driveway for example - this also confirms proper fitment before you need them. If you need to use them after that, get 'em tight, re-check tightness after a few hundred feet of travel, and you'll have no issues with chains on the rear. In all likelihood you won't need them, but better to be prepared as you say - I commend you for that. I've had the jewelry on the rear of my tacoma half a dozen times this season myself, but that's venturing away from civilization more than you're talking here. I still carry them September to May every year - you never know.
  4. Dec 20, 2015 at 4:26 PM
    tomwilson74
    tomwilson74 Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
    I almost died in a car wreck during a huge snow storm while stationed in Victorville. Even the Mohave desert gets snow!
  5. Dec 20, 2015 at 4:47 PM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Just in case it hasn't been mentioned, don't go to oversized tires if you plan to use chains. This is the reason I stay with the OEM tires; clearance with chains.
  6. Dec 20, 2015 at 4:48 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I could clear chains on the rear with my 275/70/17's no problem
  7. Dec 20, 2015 at 5:17 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I carry a set of vbar chains for the rear and am considering trying a pair of Peerless class S low clearance chains or cables for the front. They obviously wont be as effective as real chains but having a traction aid on the front tires can be the difference between getting out of the mountains and the front tires leading the truck off the road or into a canyon.
    http://www.peerlesschain.com/brands/traction/technical-information/limited-clearance-issues/
    DoorDing likes this.
  8. Dec 20, 2015 at 5:21 PM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    I'm at 4300 ft. I just keep them in the truck until winters over. I haven't needed them for the last two years but winters back this year. Looks like it's the wests turn for winter.
  9. Dec 20, 2015 at 7:10 PM
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Without a 2" lift ?
  10. Dec 20, 2015 at 7:41 PM
    OZ-T
    Peter North
    British Columbia
    Probably
  11. Dec 20, 2015 at 7:47 PM
    Pigpen
    Dan
    Northwest Montana
    I can run v bar chains on my 33s. No problem.
  12. Dec 20, 2015 at 8:08 PM
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    That's worth noting.
  13. Dec 20, 2015 at 8:24 PM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    Those of us that have run chains and know the drill, can tell you - try them out, fit them once in the driveway before you need to do it while wet with frozen fingers. It also avoids finding out you got the wrong size. When I was driving Wyoming, Montana, and Idaho in a full size 4x4 it was a necessity to have four chains and be able to get them on and functioning without too much drama. Carry a couple of pieces of 2x6 to lay in between the cross bars when you lay them out to drive onto the chains. Pull onto the blocks and that will keep the truck from pining them tight to the ground - leaving them loose to pull into place and buckle up. I also learned to add weight to the truck when the rear needed some bite. Wallyworld and many box stores sell water softener salt in 40 lb plastic sacks that are easy to load, handle - and cheap.
    Crom likes this.
  14. Dec 20, 2015 at 11:15 PM
    kingk0ng
    kingk0ng Well-Known Member
    11 TRD OR AC
    just a few things.
    What brand of chains do you guys recommend? For 265/75/16 on k02?
  15. Dec 21, 2015 at 9:26 AM
    #35
    Shelf Life
    Rob
    Central Oregon
    I had KO's on my truck until they wore out. I just used Z chains when the tread got low. With deep tread just air them down if you have to.
  16. Dec 21, 2015 at 9:31 AM
    #36
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Anybody have a link for some good chains that they would recommend?
  17. Dec 21, 2015 at 10:00 AM
    #37
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    security chain company V bar with the cam style tensioners and add on the rubber bungie tensioners.
    If you are getting "chains" for the rear... dont skimp out on meh cable chains.
  18. Dec 21, 2015 at 1:24 PM
    #38
    ChesterTaco
    ChesterTaco Well-Known Member
    Chester, CA
    '15 BRM DCSB OR, 1993 Pickup
    Gentex 453 Mirror, Paid-off Mod.
    Also remember that the speed limit for chain control in Cali is 25 or 35 MPH so you shouldn't tear the chains free.
  19. Dec 21, 2015 at 3:42 PM
    #39
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    I did the best I could to take measurements this afternoon and think I am screwed for now. There is an odd (useless?) bump on the knuckle that is only 1/4" +/- a cunt hair from the sidewall protrusions on my Duratracs. The tighest sidewall spec Peerless shows is 1/4" for their Super Z6 cables. It sure looks like that bump could be ground off without harm but I would want to be damn sure before doing it. Its hard to imagine the engineers just put it there randomly. I remember a thread here somewhere where a guy asked about grinding off that bump. Will have to see if the thread contained any useful info or if it was just the usual chorus of opinionated monkeys.
    Crom likes this.
  20. Dec 21, 2015 at 3:46 PM
    #40
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    For reference what size are your Duratracs? Stock rims, or at least stock spacing? Thanks!
