5,000 Mile Oil Changes Really Necessary?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tmz1m, Dec 26, 2015.
  1. Dec 26, 2015 at 12:18 PM
    #41
    jr49
    jr49 Well-Known Member
    California
    2015 SR5 PreRunner Double Cab
    i just took my '15 for the 10,000 mile oil change via Toyota care package. i'm pretty sure the 5,000 mile one is just a tire rotation and inspection. that one took about 25 minutes if i recall correctly.
  2. Dec 26, 2015 at 12:37 PM
    #42
    SDTaco4x4
    SDTaco4x4 Well-Known Member
    San Diego
    2016 Black TRD Sport 4x4
    Uhh...the 2016's call for 0W20. That is synthetic.
    CusterFan likes this.
  3. Dec 26, 2015 at 12:38 PM
    #43
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I buy 5 qt. at jugs of Mobile 1 at Walmart along with a filter for under $30 and change my own at 10,000 mile intervals. I do spin on a clean filter at 5,000. I'm at 160,000 miles and going strong. I figure to double that easily with the same routine. A 10,000 mile oil change with synthetic is already being conservative. There is a guy here that recently posted that his 2006 had just rolled over on 400,000 miles and he changed oil every 8,000-12,000 miles.
  4. Dec 26, 2015 at 12:48 PM
    #44
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Yep, already addressed that IF you actually read through. here ya go, post #16
    There, I even put it in bold for you to see. I also stated 0w20 is also ONLY available in synthetic
  5. Dec 26, 2015 at 1:06 PM
    #45
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There is some misinformation in this post. The 4 stroke modern day engines of today and yester-year are no different than the ones which were in usage 100 years ago. The technology minus emissions control add ons to them is no different or better. The only thing we have improved upon is machining and closing the gap on tolerances within the engine, valvetrain and etc. That is still nothing to yell home about due to the fact that the combustion engine is only 10-15% efficient. Oil technology has improved, but it's only as good as the engines ability to isolate and seal it from other fluids.
    The reason why 3K interval changes are recommended but are now being dragged out to 5k (eh, that's not too too bad) 7.5k (pushing it) and 10k (downright stupid if you ask me) is because manufacturers:
    A. Want that beautiful new engine to not last you as long, so you can replace either it or the car sooner
    B. Make it look like they are improving on their engine tech (even though they really have not)
    C. Maintenance wars with other manufacturers
    In all truth, synthetic oil or not, there is something a lot of people don't and usually never will factor into their oil change intervals. Fuel dilution. That combustion chamber is not creating a perfect seal and after x amount of miles, the chances that some fuel is escaping past the combustion chamber and mixing into the oil pan with the rest of the oil is high. Fuel is an excellent oil cutter. Let it do that long enough and you lose all the protection necessary to keep that engine clean and healthy internally. That is why it is great preventative maintenance to flush out that oil sooner than later to keep that oil pan and ultimately all of those rotating internals clean and properly lubricated.
    Take this post for what you will, but that is my reasoning behind 3-5k oil changes at max REGARDLESS of synthetic oil in use or not.
  6. Dec 26, 2015 at 1:25 PM
    #46
    gottaToy
    JJ
    1985 Moped
    ^But explain how an old 80's engine would need a rebuild around 100,000 miles(if lucky to get that) and many modern engines can go 150-200,000 with regular maintenance? regardless, 10,000 with even full synthetic is too much.
    Now given these are way underpowered and you either drive like a granpa or run the piss out of them, I wouldn't go 5,000 with synthetic in my Toyota.
  7. Dec 26, 2015 at 1:31 PM
    #47
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Simply put, sloppy machining and tolerances allowed for much faster wear of internals, lubricated properly or not.
  8. Dec 26, 2015 at 2:21 PM
    #48
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    2021 TRD PRO 6MT Midnight Black
    Some misinformation, here as well.
    I totally agree on the fuel dilution being an oil killer, and we'll need to see how this 3.5L V6 engine does over time. But the only way to gauge this is to GET THE OIL ANALYZED. UOAs on the 2nd gen. 4.0L V6 show no such issues, so the 3-5k oil change is absolutely unnecessary given "normal" driving habits when taking fuel dilution into consideration.
    Warranty needs aside, people change oil WAY too often. It's not cheap insurance, and it's a waste of resources.
    Now, people that own a GDI car/truck...fuel dilution is a problem.
    smitty99 likes this.
  9. Dec 26, 2015 at 2:24 PM
    #49
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  10. Dec 26, 2015 at 2:29 PM
    #50
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    Take a look at this UOA on a 2006 4.0L V6. 300,000+ miles on the truck, and 11,000+ miles on the M1 5w-30. Fuel less than 0.5% where the values should be less than 2.0%.
    You can't just categorically say fuel dilution is a problem in increased OCIs.
    http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2921817
    I believe this looks like the '06 truck here that just turned 400k miles.
  11. Dec 26, 2015 at 7:51 PM
    #51
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    I've rebuilt several engines from the 60s. I'm not sure what to say if you think todays engines are the same.
    As I said in my first post, old habits die hard. It's cheap and easy to have your oil assayed at 7500 to see how good it is. No speculation involved, but then what would we argue about, eh?
    smitty99 and 12TRDTacoma[QUOTED] like this.
  12. Dec 26, 2015 at 8:04 PM
    #52
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Stop wasting your money changing your oil at 5K miles. That's like drinking half a bottle of beer, throwing it away, and grabbing a new bottle to drink.
    specter208 and smitty99 like this.
  13. Dec 26, 2015 at 8:13 PM
    #53
    melikeymy beer
    melikeymy beer Hold my beer and watch this
    2019 Tundra
    Give up dude. Seriously. :frusty:
    Code Black likes this.
  14. Dec 26, 2015 at 8:14 PM
    #54
    Plain Jane Taco
    USA
    It has begun.
  15. Dec 26, 2015 at 8:19 PM
    #55
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    Remember that oil is only part of what you replace. The filter also has to be replaced, so even if your oil is good to go you may still have a filter that needs replacement.
    Just trust the engineers who spent years designing this stuff.
  16. Dec 26, 2015 at 8:22 PM
    #56
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'm not proud of it but when I was younger I put over 300k on a 1984 Nissan 720 KC 2wd, gas and I think I changed the oil maybe 4x (and trust me, the oil looked it) I eventually just got tired of driving it over 10 years and was the only reason I got rid of it. I sold it to my Cousin for $75. He drove it 5 more years then gave it to a farmer who drove it another 5 years until the motor finally croaked. Now, I try my best to keep the engine clean by changing the oil when it smells of fuel or getting quite dirty. I do try to let it drain for 45 minutes or so. Don't know if any of it really matters. Do what you like, I guess.
  17. Dec 26, 2015 at 9:09 PM
    #57
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I meant more so the theory of operation, and the way they work, not so much the way they are assembled. The way they are put together these days are much better than before as assembly plants have modernized and standards have as well.
  18. Dec 27, 2015 at 4:42 PM
    #58
    Northwoodshyun
    Northwoodshyun Well-Known Member
    St. Paul MN
    Of course, you are correct. I work at a nursing home and do clean people as long as I get my hourly wage. Cleaning (or the smell) does not get better with age but my time is not too far away. BTW: I was talking about the Toyota 25K mile complimentary service.
  19. Dec 27, 2015 at 4:49 PM
    #59
    Stags863
    Stags863 Bye Felica!
    Florida
    2014 DCSB TRD Off Road 4x4
    - Bilstein 5100's set at 1.75 - 265/70/r17 Goodyear Wrangler Authorities - 6000k headlight and fog light bulbs - NiLight off road LED rear lights - Light bar mounted behind front bumper - White LEDs in dome, map, and sun visor - Tint (5% around / 35% front) - Universal 13 inch metal antenna - Beer bottle opener in bed - Organizer storage box in center console and glove compartment - Mounted MagLite to top of center console storage box - MGM grille - MGM rear bumper - CamLocker toolbox - Rubber floor mats - 2 USB and Cig lighter chargers in rear of center console - Headrest mounted iPad holders for rear seats
    When I got my 2014 Tacoma I planned on getting all of the oil changes done at my local Toyota dealership......until they left a empty 16 oz Mt Dew bottle in my engine that got lodged on the belt. F*ckers!! I'll never take my truck there again. Plus I I switched over to 0w 20 anyways. Even with 0w 20 I change my oil every 5k.
  20. Dec 27, 2015 at 6:04 PM
    #60
    Boot879
    Boot879 Well-Known Member
    Boot
    South Carolina
    2016 Taco Off Road
    OEM Predator Steps, Katzkin leather (black), Bed Mat, Salex Console Organizer, Loving and good looking crossfit wife, Loving and smart daughter
    I'm torn. I want to take advantage of the "free" oil changes... But on the other hand I want to be sure they are done right (oil filter changed, proper oil used, etc).
    Trust issues I guess.
    Code Black and CusterFan like this.
