5,000 Mile Oil Changes Really Necessary?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tmz1m, Dec 26, 2015.
  1. Dec 29, 2015 at 3:43 PM
    #121
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    and make sure it's gold for maximum insulation LMAO
    Silver02Taco likes this.
  2. Dec 29, 2015 at 3:44 PM
    #122
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    You're not aware of how electricty works? Thats a dead short.
  3. Dec 29, 2015 at 3:55 PM
    #123
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Look up maintenance-induced failures (MIFs) :devil:
    https://www.maintenanceassistant.com/blog/poor-maintenance-cost-lives/
    http://www.avweb.com/news/savvyaviator/savvy_aviator_53_dark_side_of_maintenance_196909-1.html
  4. Dec 30, 2015 at 8:21 AM
    #124
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
    Be better if it was a cockring:D
  5. Dec 30, 2015 at 2:26 PM
    #125
    tgear.shead
    tgear.shead Well-Known Member
    So.... every 50 miles?
  6. Dec 30, 2015 at 2:33 PM
    #126
    tgear.shead
    The problem with your claim is the way people interpret the break-in procedure. Most people don't understand (a) physics, (b) instructions.
    At the end of the day, there are two sets of instructions; the instruction manual, and the "internet hard" break-in. Yet those who actually read and understand the instructions will actually notice that the two "opposing" sets of instructions... are actually the same.
    The instruction manual will say to keep the rpms down, yet varied, with frequent starts and stops. I.e., LOAD it, but briefly, so you don't burn the rings. People read it and misinterpret it as "soft". The "internet hard" instructions say to give it everything, let off, give it everything, let off. People read it and misinterpret it as "hard". **** BUT THEY ARE ACTUALLY SAYING THE SAME THING!!!!
  7. Dec 30, 2015 at 2:35 PM
    #127
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    new truck, every 3000mi, until out of warranty. after that every 5000mi., i sleep better. 3rd toyota truck, sold previous two with over 200000mi. both sold trucks didn't burn a drop.
  8. Dec 30, 2015 at 2:46 PM
    #128
    tgear.shead
    And this is precisely the kind if bad information that people should be able to recognize in a second, in order to dismiss certain people as a source of bad information.
    0w defines the lowest temperature at which the oil can **be pumped**. The second number, 20, 30, 40, etc., is the number that tells you how thin or thick the oil is at OPERATING TEMPERATURE.
    The only one that matters *AT* operating temperature, is the second number.
    The lower the FIRST number, the more easily the oil is pumped through a cold engine. I.e., easier to start, less startup wear.
    In addition to the low temperature pumping point, the 0w also provides a hint about the viscosity curve. In other words, yes, it will be a thinner oil... WHEN IT IS BELOW OPERATING TEMPERATURE.
    ** but it will be PRECISELY the same viscosity, AT operating temperature.
    The ideal oil is one that maintains a constant viscosity at ALL temperatures. The lower the first number (i.e. 0w), the closer it is to that ideal.
    busticator likes this.
  9. Dec 30, 2015 at 2:49 PM
    #129
    Markc1024
    Markc1024 Well-Known Member
    The logic here eludes me. Most would say comply with mfg requirements while in warranty, and then do what you want after that. 3k OCI will do nothing to improve your warranty support - might as was well just do 5k now.
  10. Dec 30, 2015 at 2:51 PM
    #130
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    ocd?
  11. Dec 30, 2015 at 3:00 PM
    #131
    Jasper
    Jasper New Member
    Fair Play, SC
    Tacoma 4X4, Sport TRD
    I have 15K on my 2014. I let Toyota do the first one at 5K then I did the 2nd one at 10K with Amsoil Signature series. I will take it to 20K then do it again. (with a filter change at 15K). I have a 2003 Suburban with 165K and a 2003 4 Runner with 226K miles. I go 25K between oil changes and neither one will burn more than 1/2 quart in that time. But do change the filter more often. The Chevy gets 18mpg & the 4 Runner gets 23 mpg. I obviously am a believer in this oil. Been doing this for almost 40 years. I own 4 vehicles and it's nice not having to worry about oil changes all the time.
  12. Dec 30, 2015 at 3:40 PM
    #132
    tgear.shead
    Silver02Taco: obviously, you do not. What he was getting at, is that electricity does NOT blast out radially into anything it contacts. Electricity takes the path of least *resistance* from a high potential to a low. That means that it will only go from prong to prong. The path through finger, body, boot, ground is very high resistance. Anybody wearing such a ring wouldn't feel a thing, except possibly for a brief moment while plugging it in, if it contacts the hot terminal before the neutral. Then in far far less than 5 seconds, it would pop the breaker.
  13. Dec 30, 2015 at 3:42 PM
    #133
    tgear.shead
    The logic that always eluded me, is the people who do things to their truck that might break things... always suggesting that you should wait until the warranty expires. The reason this logic doesn't make any sense, is that you're doing something that might break something. If you are under warranty, you *might* have to pay to fix it. If you are OUT of warranty, you *definitely* have to pay to fix it.
  14. Dec 30, 2015 at 3:45 PM
    #134
    Markc1024
    My point was why shorten OCI's beyond requirements while under warranty and then extend them (still within requirements) afterwards. I get the part about doing things that might break something.
  15. Dec 30, 2015 at 3:48 PM
    #135
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    You can get 1 gal bottles of synthetic at WalMart for like $23-$28 a pop. Great deal.
  16. Dec 30, 2015 at 3:50 PM
    #136
    tgear.shead
    I got that actually.
    I think you actually mean *decrease* OCI during warranty coverage. Decreased interval means more frequent changes. Aside from minor benefit from the first one or two oil changes on a brand new engine to get the manufacturing dirt and break-in particles out of the engine, I can't possibly imagine a reason to decrease the OCI, except if the engine is possibly out of spec and in need of some extra maintenance, i.e., the oil isn't actually lasting through the full interval.
  17. Dec 31, 2015 at 3:18 AM
    #137
    Aussiek2000
    2016 Offroad AC
    I'm going to send my next oil change out to be analyzed. I know the first GM DI engines were very hard on oil, be interesting to see how the toyota's fair.
  18. Jan 1, 2016 at 8:28 PM
    #138
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I'm going to piss you off again. I change mine every 3,000 miles using Mobil 1 and the oversized Mobil 1 filter. I can afford the extra ~$68 more a year vs. 5,000 change for the peace of mind. Is does absolutely no harm at all.
    (Here comes the poop storm)
  19. Jan 1, 2016 at 9:16 PM
    #139
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    [QUOTE="(Here comes the poop storm)[/QUOTE]
    :crapstorm:
  20. Jan 1, 2016 at 11:20 PM
    #140
    KenLyns
    Belly of the Beast
    I keep things simple with 6-month calendar intervals, once in Sept and once in March. Typical usage puts me at just under 4500 miles. I spend my money on car washes so the frame doesn't crap out before the engine...
    I use whatever 5W30 synth that happens to be on sale - Quaker State, Mobil 1, most recently Pennzoil PurePlus. I use the same oil in my Subaru and my lawn mower.
