5-20 oil?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MTGunner, Jun 15, 2025.
  1. Jun 15, 2025 at 12:15 PM
    MTGunner
    MTGunner [OP] Well-Known Member
    Tom
    2023 Tacoma TRD
    Sliders, bull bar, tonneau cover
    Anyone running 5w-20w synthetic on an on going basis. All the time? MTG
  2. Jun 15, 2025 at 12:31 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  3. Jun 15, 2025 at 12:43 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I run other oil than that but you can certainly run 5W-20 around the clock just fine. There is nothing needing to be known to do so, if you want to just do it. It will still be fine in even the coldest of climates.
  4. Jun 15, 2025 at 1:32 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    The FSM allows everything from 0w20 to 15w40 depending on your driving conditions and operating temperature range.
    I switched to 5w30 when I did the oil and filter change at 900 miles and haven't looked back. If I was towing a lot or lived in the south where 90+*F was common, I'd probably use an even heavier weight oil.
    I haven't noticed a fuel economy impact running 5w30. Still averaging about 16.8mpg with mixed driving in hilly areas with a bumper, winch, sliders.
    bowpete and BLtheP like this.
  5. Jun 15, 2025 at 2:01 PM
    Bishop84
    Bishop84 Well-Known Member
    There's no benefit, 5W20 is simply thicker when its cold, which is not good.
    5W20 is obsolete to 0W20 like 10W30 is obsolete to 5W30.
    Run 5W30 if you're in a really hot climate, but otherwise stick to 0W20 per manual.
    pdxTacoSR5, Chew, RustyGreen and 3 others like this.
