5.29 Gear swap and oil leaks
Discussion in 'Technical Chat' started by Yoduhhh!!!, Feb 11, 2022.
  1. Feb 11, 2022 at 8:59 PM
    Yoduhhh!!!
    Yoduhhh!!! [OP] Member
    I have a 2021, 4x4 off road taco and recently did a gear swap to Nitro 5.29 gears in the diffs, My rear diff keeps leaking and ive had to take it to the shop 3 time in 2 weeks to have the seals fixed. Is there anything that could cause the diff to leak oil like this.
  2. Feb 11, 2022 at 9:00 PM
    Bishop84
    Bishop84 Well-Known Member
    Where is it leaking? Too much freeplay in the pinion can cause this. Damage to the diff housing possibly. Who knows.
  3. Feb 11, 2022 at 9:11 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Did you get an air locker? Are they using a new OEM gasket? Are they coating the OEM gasket in the red FIPG? Are they giving that 24hrs to cure?
    TartanEagle likes this.
  4. Feb 11, 2022 at 9:12 PM
    Yoduhhh!!!
    It looks to be coming out of the top of the pumpkin. with the 5.29's and stock 31inch tires, could it be spitting oil out of the breathers
  5. Feb 11, 2022 at 9:15 PM
    Yoduhhh!!!
    no air locker just the standard e-locker that came with the truck, yes they tried a new OEM gasket dont know if they used red FIPG, and i know for a fact its not waiting for 24hrs to cure
  6. Feb 11, 2022 at 9:17 PM
    Key-Rei
    Key
    Florida
    If it's coming out of the breather, it's probably just overfilled and it's possible that the new gears wearing in is generating extra heat which is pressurizing the axle.
    HiFire and Yoduhhh!!![OP] like this.
