5.29 gears and pulling a travel trailer.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PainterVern, Jun 7, 2020.
  1. Jun 7, 2020 at 9:49 AM
    PainterVern
    PainterVern [OP] GoatRoper
    Vernon
    Reno Nv
    19’OR
    A few things….
    I want to get a little travel trailer to drag the kids out of the house. What are the opinions on trailer weight?
    I was thinking around 3000 lbs 21ft ish camper trailer.
    I have a 19 taco with 5.29, aal in the back, 31” tires, rock sliders (extra weight).
    I will need to add trailer brake box and rear airbags for sag.
    Does anyone have a similar set up pulling a trailer this size?
  2. Jun 7, 2020 at 9:51 AM
    TheRealSlimTaco
    TheRealSlimTaco Well-Known Member
    Why do you have 5.29 gears on 31’s? How does it ride?
    Boxerocks and Junkhead like this.
  3. Jun 7, 2020 at 9:55 AM
    PainterVern
    Vernon
    Reno Nv
    19’OR
    A few things….
    Miss type, 285/75 16 so it more like 32.8 (33)
    Junkhead, Skydvrr and TNToyo79 like this.
  4. Jun 7, 2020 at 10:00 AM
    soggyBottom
    soggyBottom Well-Known Member
    The difference from 31s to 35s is not really that big. 1700 rpms vs 1500 rpms.
    synaps3 and CocaineAndCreatine like this.
  5. Jul 20, 2020 at 12:15 PM
    TNToyo79
    TNToyo79 Just a Dude...
    Josh
    Georgia
    2019 SR5 2WD : 2016' 4 Runner
    5.29 Nitro Gear, JBA Offroad UCAs, Rough Country M1 Coilovers, Rear: Bilstein 5100's with 2.75"in. Blocks, 20" Fuel Assault on Atturo: Trail Blade XT's, Stereo that will make you go deaf.
    I have 32's......drives like a dog. Just ordered the 5.29 ring and pinion to fix the issue.
    I did a lot of reading and research....everyone that went 4.88 regrets not going 5.29 or most say they would have went 5.29 if they had the option when changing.
    https://youtu.be/9DA2M3G7pqs
    Mojlnir and deuceb like this.
  6. Jul 20, 2020 at 1:30 PM
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    I'm on 33s right now - the same size (285 75 16) Pathfinder AT light truck tires. I tow a lot.
    I have stock gearing, and my truck is really heavy from armor and mods. My camper's around 4k lbs, it's a lifted and modded Forest River Wolf Pup 16BHS on 31s.
    I just send it with the skinny pedal, flooring it to pass or get on onramps. Keep it in ECT mode on S4, manually downshifting to S3 when needed. You'll get 8-12mpg depending on your speed and how many hills there are.
    You'll have more than enough power with stock gearing, let alone regeared.
    If you want to save money, skip the airbags and do Sumosprings. If you do airbags OR Sumosprings, you don't need a WDH for a camper under 4k lbs. I don't have one on mine and have never felt the need for one.
    HD1911 and Junkhead like this.
  7. Jul 20, 2020 at 1:55 PM
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    I just pulled a 4000 pound 20ft long pop up across Alaska behind my Taco on 33’s, 2” lift with a single AAL and stock gears and did just fine but I would want more gear ideally. I think it’ll be great with 5.29’s. I got 14mpg on the trip from Fairbanks to Valdez, but our highways are more like 2 lane meandering moose paths with 65mph speed limits. I have a WDH, no bags or sumo springs. Handles and rides fine, but stock gears are no fun on the hills.
    HD1911 and Mi2CaMatt like this.
  8. Dec 5, 2024 at 10:12 AM
    AvocadoTaco
    AvocadoTaco Well-Known Member
    Cal
    Army green 2022 Tacoma TRDOR
    Old thread, but relevant location. I'm more curious about 5.29 gear durability while towing. I'm sure it's mentioned in the mega thread, somewhere. Lol
  9. Dec 5, 2024 at 11:56 AM
    Dorf510
    Dorf510 Well-Known Member
    Tyler
    Vista, CA
    18 TRD 4x4
    Dayton wires, flux-capacitor, port-a-potty
    There’s no mechanical disadvantage going to 5.29s. The only people who have had issues with gearing was due to improper install(incorrect backlash). I run 5.29s and skinny 33s(255s), full armor(bumper/skids), camper shell and full racks, and tow trailers occasionally. I wouldn’t want to exceed 3500lb towing due to factory leaf springs being trash(for load capacity and handling), and you’ll want a tune for better shift points too. But the 5.29s should not be a worry for “durability”, tacos make minimal HP numbers so gear fatigue is negligible.
    AvocadoTaco[QUOTED] likes this.
  10. Dec 5, 2024 at 12:54 PM
    AvocadoTaco
    Cal
    Oh dude I towed my racecar to thunderhill on factory leafs once... granted the last owner put a 1" spacer and 33s, and the uhaul auto carrier is not an optimized trailer at all by putting most of the weight on the tongue. I was tapping bump stops the whole way.
    Now I've got RXT leafs, a proper drop hitch and brake controller so I'm not worried about using the full towing capacity.
    Yes yes it's true what they say, get a big truck if you're going to tow lol. I'm not complaining, taco does just fine :) just wanted to check other's experiences towing with 5.29s. Thanks for the input!
  11. Dec 5, 2024 at 6:11 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    The rule of thumb for tongue weight is 10% of trailer weight. Applied to a 3500 trailer that is 350 lbs. The stock leaf springs are plenty capable to handle that weight.
    AvocadoTaco and Schlappesepple like this.
  12. Dec 6, 2024 at 7:01 AM
    Dorf510
    Tyler
    Vista, CA
    18 TRD 4x4
    Yes, you are correct per manufacturers spec these trucks have a tongue rating of 650lb(with empty bed and solo driver)…i was referring to real life towing experience with these trucks. Tow whatever load youd like, but id still recommend new leafs or at minimum AAL(will droop within a year) if towing over 4k lbs, as the factory suspension on these trucks is better suited for a minivan and does not have good load handling properties(undersprung from factory).
    Chew and AvocadoTaco like this.
  13. Dec 6, 2024 at 9:40 AM
    gudujarlson
    Minnesota
    I think you are underestimating your taco.
  14. Dec 6, 2024 at 10:24 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I'm with @Dorf510. My pre TSB leaf springs couldn't hold up to my 350lb quad. Adding another 60 or so pound tongue weight of a small utility trailer with another 400lb quad and they sagged fast. I was able to get the TSB springs done, which became the norm going forward on Tacos, and those started sagging FAST when towing around 4000 pounds of open car hauler with SxS and ATV on it. My nose started pointing at the sky anytime I loaded up the trailer. Usable up-travel was practically non-existant in the rear of the truck which made towing really rough, and I'd say borderline unsafe. Once I got a new HD leaf pack, no more issues. Unless I'm unloaded, and now my headlights are pointed at the ground and I have zero rear suspension travel cause they're so stiff, lol.
    Dorf510 and Chew like this.
  15. Dec 6, 2024 at 1:16 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    OE Leaf springs are car-like. My fiberglass topper and Decked (330#) had me bouncing off the stops with regularity on the highway,,, that’s with just me driving, otherwise empty cab and bed. Bridge expansion joints on a curve had me biting small holes in the seat cover:D
    YF_Ryan likes this.
