5.29 on 2018 TRD off Road
Discussion in 'General Tacoma Talk' started by mgraham5872, Jun 8, 2025.
  1. Jun 8, 2025 at 1:08 PM
    mgraham5872
    mgraham5872 [OP] Member
    Michael
    2018 Tacoma TRD OFF Road
    Wondering why truck dose t make it out of 4 th gear automatic so is 5/6 obsolete with 5.29’s? Truck pulls back at 83mph tops out nothing left gas pedal like auto pulls up. Just wondering if 5.29s were right choice
  2. Jun 8, 2025 at 1:20 PM
    Clearwater Bill
    Billy
    Largo Florida
    Tire size?
    RPM when it lays down?
  3. Jun 8, 2025 at 5:16 PM
    mgraham5872
    Michael
    Tire size 33 rpm redlines and drops
  4. Jun 8, 2025 at 5:48 PM
    Blucuss
    Blucuss Well-Known Member
    Texas
    2018 Super White Tacoma TRD OR
    • RAVELCO ANTI THEFT DEVICE with Three Plugs • 285/75/16 BFG KO2s on Stock TRD PRO Wheels • King Front Coilovers, 700lb Front Springs, Extended Travel, Remote Res with Comp Adjusters • King Rear Shocks with Remote Res and Comp Adjusters plus DOBINSONS TACOMA HEAVY DUTY LEAF SPRINGS • Total Chaos UCAs & LCAs • 5.29’s & ARB Air Locker • ARB Twin Air Compressor on SLEE Mount • Switch Pro 9100 • North Star NSB-AMG27F Battery • OGE Machined Aluminum Battery Tiedown • Upgrade Sound System - KENWOOD DMX706S / XR9015 KENWOOD Reference Fit 5 Channel Power Amplifier/ Custom Box 10" Single Sub Ported / KFCXW1000F KENWOOD 10" Shallow Subwoofer, 1000W Max / RSE165 FOCAL 6.5” 2-Way Component Kit Door Speakers • Custom Front & Rear Viewing Cameras • Sound Dampening Mat 4 Doors, Floor, and Rear • Redline Toyota Tacoma Hood QuickLIFT ELITE - Carbon Fiber • LRA 34 Gal Fuel Tank • BAMF High Clearance Rear Bumper with Rub Rails & Dual Swing out with Tire Carrier plus dual Squadron Pro S1 Baja Designs lights • C4 Fabrication Overland Series Front Bumper with Full Center & Headlight Hoops plus Front Bumper Frame Supports / Squadron Pro, Pair, LED Driving/Combo Cubes (Amber) Fog Lights / Center LED Bar Baja Designs - S8, 30" Driving/Combo Amber,LED Light Bar • CASCADIA 4X4 FLIPSTER V3 WINCH LICENSE PLATE MOUNTING SYSTEM • WARN® ZEON 10-S Platinum Winch • GOAT - CUSTOM Go Off-road Armor Tech • Ditch Lights - Squadron Pro LED Driving/Combo Cubes • Cali Raised 25 Degree Rock Sliders • Cali Raised Bed Channel Supports • ShrockWorks High Clearance Full Belly Skid Plates All Steel Construction • High Clearance TRD Exhaust Modification • Custom Horn from American Auto Horns • upTOP Alpha XL Roof Rack with Baja Deigns 30" S8 & Squadron Pro, Pair, LED Driving/Combo Cubes Facing the Rear • Weathertech Front & Rear Floormats • G-Tec Fab Door Sill Protectors • TRD Pro Front and Rear Leather Seats • MOLLE Panel, Double Cab Subwoofer w/power window • TheTacoGarage Dashtop Multi-Mount • MESO Gas Hole • MESO Custom Fuse Cover • MESO Coin Holder • SDHQ Built Billet ABS Guards • Multimount Panel - Seat Jacker Mount • MAXTRAX MKII FJ Red Traction Boards
  5. Jun 8, 2025 at 5:53 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The problem is the automatic trucks govern top speed based on expected driveshaft speed. That speed is around 112 mph in stock form, but the 5.29s now make it to where you are achieving that driveshaft speed at 83 mph.
    You need to load a tune file that raises the governor so that you can resume driving up to higher speeds. You can edit a stock file or buy an actual tune from one of the tuners. I prefer to DIY, so if it was me I would probably buy VF tuner and just edit the stock tune.
    ChessguyTaco likes this.
  6. Jun 8, 2025 at 6:00 PM
    ChessguyTaco
    ChessguyTaco Well-Known Member
    L
    I went 488's as I didn't want this limitation on the rpm and the higher speeds, but as others have said it can be fixed with tuning and you should be ok with 529's.
