5.3ls into 96 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Toyo6969, Dec 25, 2019.
  1. Dec 25, 2019 at 3:04 PM
    Toyo6969
    Toyo6969 [OP] Member
    Ty
    1996 Toyota Tacoma
    Eco cage, rock lights, light bars, bumpers, sliders
    Hello, I have a 96 Tacoma sas with a full exo cage on 37s and my stock 2.7l 3rz blew a rod bearing and keeps blowing em. For starters it was gutless as hell and I found a 5.3l ls for cheap with ecm and harness and all accessories, how hard is it to swap a 5.3l ls vortec into my 96 Tacoma 5spd?
  2. Dec 25, 2019 at 3:11 PM
    02hilux
    Planet: EARTH
    They'll tell you "anything is possible with enough know how and $$$"
    Wyoming09 and PennSilverTaco like this.
  3. Dec 25, 2019 at 3:19 PM
    Bishop84
    Bishop84 Well-Known Member
    Best to switch it to auto, then stand alone ecu, custom exhaust, custom drive shaft, custom rad/cooling, custom power steering, custom harness. Big bucks, big time.
    G59 likes this.
  4. Dec 26, 2019 at 2:17 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Far easier to swap your cab and bed onto a Chevy Running gear !!
    Now if you drive slower then My Mom at 70 years of age The Toyota drive train might hold up .
    We kinda know you can`t keep your foot out of it
  5. Dec 26, 2019 at 5:33 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    :worthless:
    Wulf and 03_taco_IN like this.
  6. Dec 26, 2019 at 9:51 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I thought the whole point of rock crawlers was to break them?
    otis24 and Wyoming09 like this.
  7. Dec 28, 2019 at 9:57 PM
    G59
    G59 Stock af
    Torres
    SoCal
    03’ Long Travel DC
    Look up Timmy The Toolman on youtube. He has a series of videos showing him swapping out a 3.4 with a 2uz. Its not a vortec and you dont have a 3.4 but you’ll get the idea. It takes a lot but imo worth it
  8. Dec 28, 2019 at 10:22 PM
    TacomaJunkie8691
    TacomaJunkie8691 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    Wow,
    It is quite a bit of work to swap a small block LS 5.3 Chevy into a first generation Tacoma. The first thing you might want to do before you start doing surgery is take a look at the width clearances of a 3.4 liter V6 in a first generation Tacoma. This will give you an idea of what a wider engine is going to look like in your engine compartment. A 5.3 LS engine is going to be even wider than a Toyota 3.4 so you will have an even bigger beast to make fit than a 3.4 Toyota engine. Remember, first generation Tacomas are small trucks without a lot of width so the engine compartment is not ideal for housing a small block Chevy LS series V8. This does not mean it can't be done, but it is certainly not a Sunday afternoon job. The small block V8s before the LS series were not as physically big as the LS series V8s so you might want to look at the older Chevy V8s if you want a little easier project.
    Good Luck,
    Paul
  9. Dec 29, 2019 at 8:21 AM
    1997tacomav6
    Denver
