5.5 quart Engine, 5 quart Oil Jugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kbp68, Oct 3, 2011.
  1. Oct 3, 2011 at 2:37 PM
    kbp68
    kbp68 [OP] hey...I can change this!
    B.C.
    TRD Off Road DC/SB
    3" Pro Comp Lift/Level, ARB Winch Bumper, Superwinch UT3000,White Sport Grille, Bedliner'd rocker panels, Draw-Tite brake controller
    When I do an oil change on my truck I usually buy the 5 quart jug of Mobil 1 from Wal Mart. I know the engines capacity is 5.5 quarts but I usually forget to by an extra quart and besides, after I dump in the oil an run the engine to operating temp., the dipstick reads at least halfway between the two dots anyways. It doesn't burn oil and reads almost exactly the same at the next oil change. Am I hurting my engine by not filling it to maximum capacity?
  2. Oct 3, 2011 at 2:39 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    No. More likely to do harm overfilling rather than under.
  3. Oct 3, 2011 at 2:40 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    No hurting at all. I only use 5 as well. It's still haflway when I change it again.
  4. Oct 3, 2011 at 2:49 PM
    korslite
    korslite Well-Known Member
    Justin
    Bellingham, WA
    DCLB Sport
    FOX 2.5 RR's, TC UCAs, TC Spindle Gussets, Allpro Expedition leaf pack, Fox 2.O RR w/ Comp adjusters, 17" ATX Artillery, BFG AT 285's, de-scooped, custom sliders, custom bedrack, Brute Force Fab bumpers, Smittybilt XRC8 winch, ARB locked Rear diff
    My god who is that!?... I'm sorry you were saying?...
  5. Oct 3, 2011 at 2:53 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    What is the question again?
    I do 5 and seem to do alright. knock on wood.
  6. Oct 3, 2011 at 3:17 PM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    Wait for sale on singles (quarts) at your local autoparts store and stock up. I got six Mobil 1 quarts for $3.50 each a while back. I still have 10 "half quarts" left.
  7. Oct 3, 2011 at 3:42 PM
    arrrghhh
    arrrghhh Well-Known Member
    Denver, CO
    09 TRD Off-Road
    Custom Front Bumper, Smittybilt XRC-8, 3" OME lift, 33" Falken A/T tires
    Uh... what?
    Sorry, I got distracted there. Dayum.
    Anyhoo, you should be fine. Like others said, more likely to damage it overfilling the oil. So long as you're above the 'min' line, you're fine.
  8. Oct 3, 2011 at 3:46 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i will tell you the answer if you post more pics, and trust me i know the answer to your question
  9. Oct 3, 2011 at 3:49 PM
    WildWolfy
    WildWolfy Assitant Trainer/ Supervisor
    Just South of Dallas
    09 TRD 4x4 SR5
    Just Startin Stock TRD with Locking Rear and SR5 package
    well, it depends on what dipstick your checking... but ya, 5 quarts should be enough to fill...
  10. Oct 3, 2011 at 4:02 PM
    J4RR
    J4RR Well-Known Member
    The OC
    07 DC LB TRD SPORT 4X4
    Huh? What was the question?:p
  11. Oct 3, 2011 at 4:40 PM
    pinktaco808
    pinktaco808 Hot Steppa
    wowow.......
  12. Oct 3, 2011 at 4:57 PM
    auburn taco
    auburn taco Well-Known Member
    kevin
    Athens GA area
    2021 SR5 Tacoma
    Homelink Mirror, mud flaps and interior LEDs. so far
    actually there are a number of brands that sell 5 liter bottles that should work just fine. I know I have bought a number of them, in my case valvoline
  13. Oct 3, 2011 at 5:00 PM
    drtydru
    drtydru Well-Known Member
    Dru
    Oakland
    08 4x4
    Bucket seats, Variable speed wiper switch, 09 led Tail Lights, Satoshied front grill, DDM HIDs, Fog light install, Mud flaps removed, 1.5'AAL, Billie 1552, Toyotec front coilovers w/Billies, B.A.M.F welded sliders w/kickout,
    who the FBOMB is that chick?!?
  14. Oct 5, 2011 at 12:14 PM
    WildWolfy
    09 TRD 4x4 SR5
    our luck she is lesbo
  15. Oct 5, 2011 at 12:34 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  16. Oct 5, 2011 at 12:50 PM
    TacoSport
    TacoSport opinions are like assholes; everyones got one.
    NE
    2011 TRD SSM Sport DCSB w/Tow
    All I can say is I hope those are Hena's
  17. Oct 5, 2011 at 12:53 PM
    OffroadToy
  18. Oct 5, 2011 at 1:11 PM
    WildWolfy
    09 TRD 4x4 SR5
    Yea, the piercings in the lip kinda ruined it for me, but she would be a excellent back door candidate!, o and did I mention 5qts is ok? got ot keep it related to the thread
  19. Oct 5, 2011 at 1:36 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Less oil is usually not good. Hot roads has added bigger oil pans just to hold more oil.
    More oil running on a bigger size oil pan equals cooler running temperatures.
  20. Oct 5, 2011 at 1:47 PM
    wlmuncy
    William
    Knoxville, TN
    Running more oil then required is known to be much worse then running less oil. Running half quart lower that the maximum the oil pan can take is not harmful. Even if your assumption of hotter temps was accurate in a non-high performance motor it would be small.
