5.5 quart Engine, 5 quart Oil Jugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kbp68, Oct 3, 2011.
  1. Oct 5, 2011 at 1:50 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    As long as it's between the low and high marks on the dip-stick it's fine. Everytime I checked it the recommended 5 1/2qts slowed up a bit over the high mark. Last oil change I went to 5 1/4qts and it's right on the high mark now.
    As far as the tattooed chick check out the link in post #18...I think they found her. Google 2 guns and a sword girl.
  2. Oct 5, 2011 at 4:43 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    I will have you read my post again, I said running more oil in a bigger oil pan. More oil takes longer to get contaminated, bigger pan and with integrated cooling fins in the bottom of it, keeps oil cooler longer.
  3. Oct 5, 2011 at 4:47 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    Yes here is your original:
    Less oil is usually not good. Hot rods (fixed) has added bigger oil pans just to hold more oil. More oil running on a bigger size oil pan equals cooler running temperatures.
    Can you show me where the OP asked about adding a bigger oil pan and more oil? If not then the only part of your input was the Less oil is usually not good. Less oil than what, the the recommended 5.5 or less than 4.5 which would be 1 quart low. If it is the 4.5 you are correct if it is the 5.5, you are not.
  4. Oct 5, 2011 at 10:16 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I've always added just the 5 qt jug and, as mentioned, it's always about dead in the middle of the range on the dipstick. I always assumed there was a half quart of oil hanging out somewhere but who knows.
  5. Oct 5, 2011 at 10:45 PM
    Wallygater
    Wallygater Well-Known Member
    USA
    '11 SR5 DBL Cab 4x4 6 speed
    Softopper, All-pro bolt-on sliders, Tom Wood's drive shaft, Goodyear 235/85/16 Dura-trac's, SG, USA-Spec I-pod adaptor, Amsoil in everything
    Well I just put 5.5 in mine after I let it drain for an an hour and a half. It ended up being too much and I had to let some out. After I got it below the top fill mark when the engine is warm, the truck ran way better. When I had too much oil in it, it was sluggish. Maybe it was just me?:cool:
  6. Oct 5, 2011 at 11:00 PM
    DCtaco05
    DCtaco05 Well-Known Member
    dustin
    petaluma
    05 tacoma trd
    bone stock.. not for long
    how much time do you have on your hands to let your oil drain for an hour and 1/2? haha 5mins is more than quite enough
  7. Oct 5, 2011 at 11:14 PM
    WhiskeyDeltaTango
    WhiskeyDeltaTango Resident Redneck
    Will
    Braselton, Georgia
    Dirty Black Taco
    ARB Bull Bar, ProComp 9" lights, Dual Hella aux backup lights, WARN VR10000, OME 886x, Dakar Leafs, UWS Low Profile Toolbox, Kicker CVT10, Kicker 750.1
  8. Oct 6, 2011 at 7:32 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Hell you could run 6 quarts and be fine. As long as the crankshaft isnt slinging it around you are good yo go. Less oil than recommended is a fail move. Motor oil is a coolant as well as a lubricant.
  9. Oct 6, 2011 at 7:44 AM
    wlmuncy
    William
    Knoxville, TN
    Don't ever run any car above the maximum level marked on the dipstick unless the manufacture has told you to make a change. It can cause engine damage.
    http://www.virginiaengines.com/maintenance.htm
  10. Oct 6, 2011 at 8:03 AM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    I actually buy extra qts every now and then, usually when I need to put more in my classic I will buy an extra for the truck. Keeps from having to spend $ if I decide to do an oil change at an oddball time.....
  11. Oct 6, 2011 at 8:21 AM
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    sub'd so i can check out more pics of her later
  12. Oct 6, 2011 at 8:32 AM
    Wallygater
    USA
    No shite? Really? Thanks captain obvious. Since you think it's your business I will tell you, I was busy with a home project at the time, cracked the drain plug and came back to it after working on the home. :cool:
  13. Oct 6, 2011 at 9:14 AM
    BUZZCUT
    Georgia
    Baloney.
    How is it going to get damaged? I'm all ready for this :cool:
    There was zero to back up your ridiculous claim in the link posted. Just Saying:rolleyes:
  14. Oct 6, 2011 at 9:33 AM
    DCtaco05
    dustin
    petaluma
    05 tacoma trd
    hey man you can calm down, my bad, i didnt know that. you just stated in your previous post that you let it drain for that long. and i thought it was like your usual procedure or something.
  15. Oct 6, 2011 at 9:34 AM
    #35
    wlmuncy
    William
    Knoxville, TN
    Here is some reading for you to do:
    http://www.slkworld.com/ask-dansslk/4221-reduce-oil-level.html
    http://www.ehow.com/way_5908704_do-overfilled-car-oil.html
    http://www.saturnfans.com/forums/showthread.php?t=64967
    http://www.jeepforum.com/forum/f11/engine-oil-overfill-root-my-problems-741313/
    http://www.quora.com/Oil-Changes/Wh...er-filled-and-started-Where-do-I-go-from-here
    Now once you are done reading, please post all the places where overfilling the engine is a benefit to the engine.
  16. Oct 6, 2011 at 9:40 AM
    #36
    BUZZCUT
    Georgia
    The crank center line is above the pan rail. Keep trying. I don't have to prove shit. You made the claim it causes trouble. All I see is opinions and folklore.
  17. Oct 6, 2011 at 9:47 AM
    #37
    wlmuncy
    William
    Knoxville, TN
    You win man. Keep overfilling it up. I'll take the word of folklore from those BMW and MB mechanics that have seen failure. Plus those two guys are car talk that you have shown their ignorance. To the OP there again is no issue with keeping the oil between the two levels Toyota thought best to keep it between. But those engineers need to go to BUZZCUTS University to do it right.
    Also from page 360 from the owners maual: Avoid overfilling, or the engine could be damaged
    Page 396 is capacity
    Oil capacity (drain and refill),
    L (qt., Imp. qt.):
    2TR- FE engine
    With filter 5.8 (6.1, 5.1)
    Without filter 5.1 (5.4, 4.5
  18. Oct 7, 2011 at 12:29 PM
    #38
    Wallygater
    USA
    It's all good. :p Just a little misunderstanding. Didn't mean to come off so abrasive. No I usually don't let it drain that long. However, after all that time, it was still dripping out of the drain plug. I put 5.5 qts in it and it was too full. Next time I will start with adding only 5 qts back and go from there.:cool:
  19. Oct 10, 2011 at 12:47 PM
    #39
    WildWolfy
    WildWolfy Assitant Trainer/ Supervisor
    Just South of Dallas
    09 TRD 4x4 SR5
    Just Startin Stock TRD with Locking Rear and SR5 package
    ok, to help with this, too little oil = over heat, not enough oil to lubricate parts.
    to much oil slows the rotation of the crank, causing performance issues not to mention all those cool breathers that allow the pressure to stabalize in your heads saturate with oil then throw it thru your intake eventually fouling out your plugs and causing some damage. also the oil pressure will be to high causing pump failure.
    Sooo, the lesson here is keep it on the dip stick, your engine was designed to carry a certain amount of oil for a reason. Unless you change the design, I.E. a new pan or oil cooler, no need to put more than 5.5 in at a time, and make sure its above the fill dot.
    and there is a reason some directions say, 5.5 wet fill and 5.8 dry fill per the Tech data on T.I.S. ( Toyota Informational System)
  20. Oct 10, 2011 at 2:33 PM
    #40
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    That is meaningless. The pan is open at the top...when you add more oil the level of the oil rises above the pan.
