5.5 quart Engine, 5 quart Oil Jugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kbp68, Oct 3, 2011.
  1. Oct 10, 2011 at 3:24 PM
    #41
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  2. Oct 10, 2011 at 7:01 PM
    #42
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Wow obsess much? Press On :thumbsup:
  3. Oct 11, 2011 at 8:13 AM
    #43
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    Only in providing information that I can find evidence that is correct. I would feel real bad if I said something and it caused damage to someone else's car. You can call it obsessive.
  4. Oct 11, 2011 at 9:42 AM
    #44
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    I dump in five and button it up. I'll check levels the next day and top if needed. this weekend the five was at the top tick.
  5. Oct 11, 2011 at 12:24 PM
    #45
    BUZZCUT
    Georgia
    Wrong.....
    Where do you get this crap from?:rolleyes:
  6. Oct 11, 2011 at 12:27 PM
    #46
    BUZZCUT
    Georgia
    Yea good for you want a cookie? :cookiemonster:
    Next you probably believe everything you read on the internet is true.:cool:
  7. Oct 11, 2011 at 12:40 PM
    #47
    BUZZCUT
    Georgia
    This is for those like you to what you have no knowledge to what you speak. This is a cobra oil pan but it doesn't matter they all fill the same way. They made a movie...hmmm what was it? Oh yea dumb and dumber Jim Cary was funny just like this thread is becoming.
    http://www.svtperformance.com/forums/new-edge-cobras-51/413036-oil-pan-capacity-test-pics.html
    I fixed your failed quote post. UR Welcome ;)
  8. Oct 11, 2011 at 12:45 PM
    #48
    wlmuncy
    William
    Knoxville, TN
    That is excellent for a cobra oil pan. They are not all the same size. So sorry try again. Why don't you go home take your Tacoma oil pan off the truck and perform the same test. Then post your results. It might be believable at that time.
    No cookie right now. I just some some of these
    http://www.fates.org/moc/wp-content/uploads/2010/01/reeses_peanut_butter_cups.jpg
  9. Oct 11, 2011 at 1:08 PM
    #49
    ee1284
    ee1284 Well-Known Member
    Louisiana
    05 Prerunner Sport
    After seeing that info a few years ago I used to fill my cobra up with 6.5 quarts in between the 6 and 7 quarts recommended on svtp. However, this is a tacoma.
    I dont see how bringing up some information about a totally different make and model has anything to do with our trucks. Just because it works on one vehicle doesnt make it safe for another.
  10. Oct 11, 2011 at 5:45 PM
    #50
    BUZZCUT
    Georgia
    If I can find one I would do that. Unfortunately they aren't the easiest to find.
    Ah so it was ok for your stang but not your taco? Thanks for being irrelevant. :cool:
  11. Oct 11, 2011 at 8:31 PM
    #51
    ee1284
    Louisiana
    05 Prerunner Sport
    So next time someone asks what size tires they can fit on a stock tacoma should i bring up the tundra? Or maybe the cobra?
    Next time someone asks what gains an intake and catback will make on a tacoma i'll just post some pics of a cobra dyno sheet.
    By your argument if its good for one totally different vehicle it must be good for a tacoma correct. Who needs actual tests or proof?
    Im not saying your opinion is wrong however, the only evidence we've seen so far is that as stated in the owners manual, overfilling may cause damage.
  12. Oct 12, 2011 at 5:11 AM
    #52
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    You just proved my point. The pan is open. When you overfill the level rises above the pan. The Tacoma pan doesn't hold 9 quarts.
  13. Oct 12, 2011 at 9:23 AM
    #53
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    I've got two guns for ya!;) ooohh forgot what was this thread about?:D
  14. Oct 22, 2011 at 9:04 AM
    #54
    DixieDog
    DixieDog Member
    2010 Tacoma
    2010 Tacoma 4 cyl. The manual calls for 6.1 quarts. I run Amsoil and take the oil to the dealership for changing. In order these are the amounts the dealership has used after each changing. 5 quarts, 5 1/2 quarts, 6 quarts, 5 1/2 quarts. The dealership cannot/will not give me a direct answer for the discrepancy. Yesterday I had the oil changed at a local garage. They used only 5 quarts. Other posts have mentioned "dip stick" problems. Evidently that must be the case with my Tacoma.
  15. Oct 24, 2011 at 8:43 AM
    #55
    WildWolfy
    WildWolfy Assitant Trainer/ Supervisor
    Just South of Dallas
    09 TRD 4x4 SR5
    Just Startin Stock TRD with Locking Rear and SR5 package
    Thats the dealership being lazy. oil is ordered in the parts section and pumped at the stall, sometimes multiple mech use the same oil line. we do not have that problem because we only have 2 guys dedicated to oil changes. that would explain the different amounts at your dealership. as far as charging for that, it would be them guessing hte amounts vs looking it up. We have print outs for years and engine sizes so we dont have to guess, or memorize to save time.
  16. Nov 7, 2011 at 5:34 AM
    #56
    xpert1111
    xpert1111 Well-Known Member
    Central NJ
    2018 DCLB Sport
    Anything wrong with using a 1/2 quart of full synthetic Walmart Super Tech oil? I use Mobile one 5qt bottle but threw in the 1/2 quart supertech at $2 and change as opposed to $6 and change for name brand.
  17. Nov 7, 2011 at 5:52 AM
    #57
    upcountry
    upcountry Active Member
    Seattle
    07 Tacoma
    So....is this one thread where it is not only OK, but actually a good thing if I quote the WHOLE OP?
