5.56mm on sale cheap
Discussion in 'Guns & Hunting' started by Rmodel65, Oct 25, 2011.
  1. Oct 25, 2011 at 4:49 PM
    Rmodel65
    Rmodel65 [OP] Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
  2. Oct 25, 2011 at 4:49 PM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    bump for a hell of a deal
  3. Oct 25, 2011 at 4:57 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    ordered a case :cool:
  4. Oct 25, 2011 at 4:58 PM
    TacticalBacon13
    TacticalBacon13 Sorry for party rockin'
    Dunk
    Beech Creek
    2014 tundra platinum
    baby seat and a muffler
    Ive been waiting on the 1000 rd to come back into stock. Good find btw :thumbsup:
  5. Oct 25, 2011 at 4:59 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Wonder if they have .223?
  6. Oct 25, 2011 at 5:00 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Hawaii: No sales.
    :pout:
  7. Oct 25, 2011 at 5:03 PM
    TacticalBacon13
    Dunk
    Beech Creek
    Pretty much the same thing, I shoot both with no probllem out of all my ars
  8. Oct 25, 2011 at 5:07 PM
    Rmodel65
    Jawja
    1996 Yota 4x4
    Viper Red paint
    yea as long as its rated to do so then you can go with the 5.56
  9. Oct 25, 2011 at 5:11 PM
    t4daddy
    North Alabama
    Was always told that .223 in 5.56= fine, but not the other way because of thicker brass walls in the cases of the mil. stuff creates higher pressures.
  10. Oct 25, 2011 at 5:27 PM
    davestaco
    David
    Schofield Barracks
    this is correct. the gun will still shoot if you run 5.56 in a .223 but expect more malfunctions
  11. Oct 25, 2011 at 5:32 PM
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    Street, MD
    11 Tacoma TRD DCLB 4X4
    Fox 2.0 Coilovers cranked up with JBA UCA, Rear OME 2" leaf pack with Ride Rite air bags, SCS Steath 6 matte black rims wrapped in 285/75/17 Cooper ST MAXX, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 5% up front and 40% on windsheild), Retro color matched HID headlights with Amber Halo, Projector LED Foglight, Custom LED Taillight and 3rd brake light, T-Rex 2 eyelids color matched, Fog light anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, 20" LED bar and 2 LED Pods behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Outlaw Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns, Pedal Commander
    Do they only have 55 grain?
  12. Oct 25, 2011 at 7:53 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
  13. Oct 26, 2011 at 9:42 AM
    t4daddy
    North Alabama
    I know most (if not all) reloading manuals state you should reduce max-charge loads by at least 10% when using mil-spec brass.
  14. Oct 26, 2011 at 10:27 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  15. Oct 26, 2011 at 5:52 PM
    TonkaToyTaco
    Louie
    Street, MD
    This is a 223 caliber and one HELL of a deal! Im stocking up on these
  16. Oct 26, 2011 at 6:23 PM
    t4daddy
    North Alabama
    This is a copy and paste, of course, but explains the difference. Seems a 5.56 can over pressure "some" .223 chambers/guns by 20,000 psi per measuring styles. That's something I don't want to play with, have fun.
    While the 5.56 mm and .223 cartridges are very similar, they are not identical. Military cases are made from thicker brass than commercial cases, which reduces the powder capacity (an important consideration for handloaders), and the NATO specification allows a higher chamber pressure. Test barrels made for 5.56mm NATO measure chamber pressure at the case mouth, as opposed to the SAAMI location. This difference accounts for upwards of 20,000+ psi difference in pressure measurements. That means that advertised pressure of 58,000 psi for 5.56mm NATO, is around 78,000 psi tested in .223 Rem test barrels (SAAMI .223 Rem Proof MAP is 78,500 psi so every 5.56mm round fired is a proof load, very dangerous). The 5.56 mm chambering, known as a NATO or mil-spec chambers, have a longer leade, which is the distance between the mouth of the cartridge and the point at which the rifling engages the bullet. The .223 chambering, known as the "SAAMI chamber", is allowed to have a shorter leade, and is only required to be proof tested to the lower SAAMI chamber pressure. To address these issues, various proprietary chambers exist, such as the Wylde chamber[2] or the Armalite chamber, which are designed to handle both 5.56 mm and .223 equally well.
    Using commercial .223 cartridges in a 5.56-chambered rifle should work reliably, but generally will not be as accurate as when fired from a .223-chambered gun due to the excessive leade. [3] Using 5.56 mil-spec cartridges (such as the M855) in a .223-chambered rifle can lead to excessive wear and stress on the rifle and even be unsafe, and the SAAMI recommends against the practice.[4] Some commercial rifles marked as ".223 Remington" are in fact suited for 5.56 mm, such as many commercial AR-15 variants and the Ruger Mini-14, but the manufacturer should always be consulted to verify that this is acceptable before attempting it, and signs of excessive pressure (such as flattening or gas staining of the primers) should be looked for in the initial testing with 5.56 mm ammunition.
  17. Oct 26, 2011 at 6:28 PM
    TonkaToyTaco
    Louie
    Street, MD
    Well I dont think it will over pressure an AR-15 so im good
  18. Oct 26, 2011 at 7:59 PM
    YayAreaTaco0311
    YayAreaTaco0311 Motivator
    California
    '09 TRD 4x4 O/R Supercharged
    OEM TRD supercharger, OEM wheels painted black by me, yellow sidemarkers, arb bumper, LED interiors, roll-n-lock, 5% rear windows, mudflaps removed, protector alarm, mobile trace, blacked out front Toyota emblem, debadged, & tree air freshener.
    Damn it, I live in San Francisco. Fail.
  19. Oct 27, 2011 at 5:55 AM
    Apricotshot
    Apricotshot Well-Known Member
    Henry
    Tampa, FL
    TRD Sport
    TRD CAI
    I placed an order yesterday. I have a class coming up in December 1500 or so rounds in three days. Should be fun.
