5.5hr to cool the transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by soggyBottom, Dec 22, 2018.
  1. Dec 22, 2018 at 11:20 AM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    I dropped my 2018 off at the dealer to check the transmission. It's shifting hard (mainlymwhen cold) and I suspect it's low on fluid. They said the transmission needs to cool off to diagnose it.
    Dropped it off at 1130am, got a call 2hr later saying they may not be able to do it today because it may not be cool enough.The high today 9c (48f). Sounds a little fishy to me but I'm not transmission cooling expert.
  2. Dec 22, 2018 at 11:28 AM
    GasPowered
    GasPowered Well-Known Member
    OK
    2016 DCSB TRD OR 4x4 SSM
    Not fishy at all. They usually let it sit overnight.
    Cheers
    StayinStock likes this.
  3. Dec 22, 2018 at 11:29 AM
    soggyBottom
    I'm amazed that they couldn't tell me that before I waited in the waiting area for 90min
    Rockefelluh and SandyTaco4x4 like this.
  4. Dec 22, 2018 at 11:36 AM
    BlueTacoTRD
    BlueTacoTRD Active Member
    2017 BBP TRD OR DCSB w/JBL
    OEM mud guards, American soft tri-fold tonneau cover
    I have the same hard shifting when cold and sometimes downshifts hard into 1st at any temp. I've had the dealership check the fluid level before, they said it was fine. Then again my dealership (Berglund Toyota of Lynchburg VA) is kinda salty when it comes to doing any work so they might not have checked it at all.
  5. Dec 22, 2018 at 11:40 AM
    B33
    B33 Well-Known Member
    2017 tacoma TRD Sport
    theres a bunch of info on this I seem to remember that the temp ha to be 107 to like 115 ? or something close to that.
    I did mine and used my scanGage II for a temp reading Hope this helps
  6. Dec 22, 2018 at 11:55 AM
    soggyBottom
    Temp has to be that to check the fluid level?
  7. Dec 22, 2018 at 12:05 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Yes temp needs to be in a narrow range to check but given the cold ambient temp where you are that’s bullshit. I had my second gen transmission fluid changed in Phoenix, AZ when it was 80 degrees outside (dropped off truck first thing in the morning and it was done by mid afternoon).
    kahanabob likes this.
  8. Dec 22, 2018 at 12:09 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    If they want to drive it with a cold transmission to diagnose the cold transmission shifting problems it makes sense that they’d want it to cool off completely first.
    Wulf likes this.
  9. Dec 22, 2018 at 12:12 PM
    B33
  10. Dec 22, 2018 at 12:43 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    . . . . which is why these things should be designed to test hot, with a dipstick!!
    G.
  11. Dec 22, 2018 at 12:50 PM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    Truth
  12. Dec 22, 2018 at 12:52 PM
    LoMa
    LoMa Well-Known Member
    2016 Tacoma TRD Sport AT MGM
  13. Dec 23, 2018 at 5:33 AM
    cwdog
    cwdog Well-Known Member
    Asheville, NC
    2017 Tacoma Limited
    Meguiars Ultimate Wax, Rain-X, Dog Bed, Undercover Tonneau Tri-Fold, Debadged.
    Hemlocktherm78 likes this.
  14. Dec 23, 2018 at 5:40 AM
    salvesg
    salvesg New Member
    Is your Scan Gauge II capable of reading your Transmission fluid temperature?
  15. Dec 23, 2018 at 7:05 AM
    B33
    it gets the same reading you would see if you plugged in a scan tool to the OBDII I get 2 readings
    one from the torque converter and the other from the pan so yes. I used the pan reading
  16. Dec 23, 2018 at 9:30 AM
    dasvis
    dasvis Member
  17. Dec 23, 2018 at 9:33 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Cannot pressurize something with a dipstick lol, which is why your transmission does not have one.
  18. Dec 23, 2018 at 9:37 AM
    My Name is Rahl
    Pressurize? Why would our trans be pressurized?
  19. Dec 23, 2018 at 10:17 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Improved flow through all the internal passages, especially the smaller ones. Not talking about 3000 psi, just several psi due to the heat.
  20. Dec 23, 2018 at 10:28 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Toyota AC60F Auto Transmission Fluid Adjust doc:
