5" lift questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lscates03, Sep 29, 2016.
  1. Sep 29, 2016 at 6:26 PM
    Lscates03
    Lscates03 [OP] Active Member
    Luke
    2002 Red Tacoma TRD & 2018 Cement Gray TRD OFF ROAD
    so initially I had a 2.5 inch rough country lift. Then I bought the bilstien 3" inch lift. My question is can I put both of them on. And would I be putting any stress on any components. Or would I need to replace any parts going this high?
  2. Sep 29, 2016 at 6:34 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    No. You can not and should not stack any lift kit with another lift kit.
  3. Sep 29, 2016 at 6:47 PM
    Lscates03
    Luke
    I would just be adding a 1.5 inch strut extension to a 3" coil
  4. Sep 29, 2016 at 6:55 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    That will ride like crap!
  5. Sep 29, 2016 at 8:19 PM
    Broke Okie Ty
    Broke Okie Ty Well-Known Member
    Ty
    California/Oregon/ Now in Montana
    01 trd with some stuff
    Armor, winch, other stuff
    No don't do it. First off, you will run into alignment issues, also steering would suck with that much of angle. That's why they make drop bracket lifts starting at 4 inches. Second, like sicyota04 said, it would ride and drive like crap. If you want 5" inches of lift without a DB lift, do 3"suspension and a 2" body lift, that way you the 5" lift without being a mechanical time bomb.
    Sicyota04 likes this.
