5" lift spindles
Discussion in '1st Gen. Tacomas (1995-2004)' started by houndsmen, May 19, 2011.
  1. May 19, 2011 at 2:09 PM
    houndsmen
    houndsmen [OP] Well-Known Member
    Hello I currently am running the toytec coilovers and they are set at around 3" because of my heavy bumper and the front of my 01 tacoma double cab was starting to sag. Well my cv axle boots have been tearing within a few thousand miles. Can I put spindles from a 5" lift to level out my axles or what can I do?
  2. May 19, 2011 at 2:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    No. You may be too high. See if you are actually at 3" lift. Idealy, you should be about 2.5"
  3. May 20, 2011 at 1:19 PM
    houndsmen
    So I am at 2.75 is there anything I can do to make my axles a little straighter? I was looking at total caos and they have some tacos that have coil lifts and there truck is lifted around 3 1/2 inch but there angles is not that bad.
  4. May 20, 2011 at 3:21 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Do you have a diff drop installed?
  5. May 26, 2011 at 9:48 AM
    houndsmen
    yes I have the diff droppers installed...
  6. May 26, 2011 at 9:54 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    That's because their running modified tundra CVs. The only reason they can do that is because their extended LCAs push the hub out about 3.5"
