5 Lug 2 wheel drive Lift...Ideal ideas
Discussion in '5 Lug' started by Street, Jan 8, 2012.
  1. Jan 8, 2012 at 3:55 PM
    Street
    Street [OP] Well-Known Member
    jon
    Brevard
    Tacoma
    Looking to Lift my 2wd 99 Tacoma I have an idea......
    FRONT:
    Changing the Stock Spring and Shock with The Strut set-up and putting the spacer in
    REAR:
    Simple Blocks
    Ideas On This :confused:
    I'm not looking to go mudding just want a the truck to set high
    I have 17's and was thinking 31x10.50's on them
    I just haven't found info on a CHEAP LIFT not looking to drop $400 buck into a $1000 truck thats all it cost me and I know there wroth more LIFTED:p and look damn good !!!
  2. Jan 8, 2012 at 7:25 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    buy yourself some v6 coils daystar coil spacers and some lift spindles. too much work to try to convert it to coilovers or struts
  3. Jan 9, 2012 at 6:59 PM
    Street
    jon
    Brevard
    Tacoma
    How much lift from just the coils? and would I have to change anything but just the coils?....b/c even just sitting as high as a SR5 prerunner or stock 4x4 would be fine.
  4. Jan 9, 2012 at 7:08 PM
    TRDChris
    TRDChris Well-Known Member
    La Puente
    5 lugger
    H.I.D 6000K, 5% tint all around, black on blacked out rims(sprayed stock rims), fog light mod, deckplate mod, plastidipped bumper and interior, self made eyelids, window visors, clear corners, Billet grille, trd grill emblem
    You'll get 3 inches with the lift spindles and an additional 1.5 inches with the Daystar coil spacers....that should get you the amount of height you want and I agree with joel....that's a lot of money to convert to coilovers
  5. Jan 9, 2012 at 10:06 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    v6 coils are supposed to give another inch but you might need ucas so stick to the spindles and spacers if your on a budget. wont be as tall as a prerunner but definitely wont be low and fyi blocks for the rear will lower it. get yourself an aal or some shackles
  6. Jan 10, 2012 at 3:04 AM
    Street
    jon
    Brevard
    Tacoma
    Thx Guys, I just wish they would have stuck to one set-up for the front, there is almost no info on coils and I'm not a fan of taking them out.
    I'm on a big budget now but with tax time maybe just lift spindles really easy to replace and i never did the bearings or tie rods and i like to replace everything...while its apart.
    Thx guys its just with 90K on this truck and how cheap I got it, I rather not make it just another mini with a crappy ride, Jon Street
    P.S. what tire do you think i can run after the spindles I got 275 / 75's R15 B4 would like to keep the 17's on it with a nice lower pro AT
  7. Jan 10, 2012 at 6:39 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    what the backspacing on your wheels?
  8. Jan 11, 2012 at 2:37 AM
    Street
    jon
    Brevard
    Tacoma
    thx Backspacing dooh i had some jeep/ranger 15x8 but these aren't all that off-set ? dont think 31x10.50 will work...........
    but i am running 245 45 17's and i think its close but for now i think tires are the least of my worries when the spindles are $400 maybe i can find some used one's?
  9. Jan 11, 2012 at 2:39 AM
    Street
    jon
    Brevard
    Tacoma
    At this piont I might just try to sell this one or trade it in on a 4x4 or newer one with the easy strut spacer
  10. Jan 24, 2012 at 10:12 PM
    Street
    jon
    Brevard
    Tacoma
    Not sure if you guys are still there but if so....
    Bought some 2001 SR5 extd. cab springs for the front you think these will give me a lift up front ? The SR5 's seem to sit much higher?:confused:
  11. Feb 5, 2012 at 8:00 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    Could be the age of the springs too. V6 5 lug coils give some lift but not much id say 1 to1.5?
  12. Feb 5, 2012 at 8:00 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    Where are you located?
  13. Jun 15, 2015 at 2:38 PM
    samisim0
    samisim0 Member
    Sam
    2000 5lug
    hey guys if your around still, where can I find the V6 coils ? ... i want to do this to get my 4 cyliner 5 lug a little higher in addition to the fabtech spindle kit ... any ideas?
  14. Jun 15, 2015 at 10:16 PM
    tacomatt602
    tacomatt602 Well-Known Member
    Phoenix, AZ
    1997 5 Lug Regular Cab 2.4l
    Doetsch spindles, V6 coils, Fabtech AAL, 4Crawler 2" body lift, Daystar coil spacers, Bilstein 5100s (rear), 15x7 U.S. Wheel Stealth Stars, 225/70r15 Destination LE2s, 4x4/Prerunner grille, Kobalt low-profile toolbox, Pioneer AVH-X1600DVD
    BUMP, but only if we won't need different ucas :D
    And when you guys say v6 coils, do you mean 5lug v6 or 6lug v6?.. Or do 5 & 6lug v6s have the same coils? :confused:
  15. Jun 16, 2015 at 1:47 PM
    alexkontos17
    alexkontos17 Well-Known Member
    Alex
    Orlando
    97 tacoma
    I've looked all over and it doesn't look like there's any aftermarket upper or lowers for our trucks unless you go LT. My concern with the v6 coils is the weak lower ball joint bracket that everyone claims they break.
  16. Jun 16, 2015 at 1:48 PM
    alexkontos17
    Alex
    Orlando
    97 tacoma
    But if I get that issue solved in goin v6 coils too :D
  17. Jun 21, 2015 at 6:31 PM
    tacomatt602
    Phoenix, AZ
  18. Jun 21, 2015 at 8:59 PM
    alexkontos17
    Alex
    Orlando
    97 tacoma
    I did a little reading on em and it looks like most people that use em on off-road rigs like moog. But the bracket I'm talking about is actually what mounts the lower balljoints to the lower control arm. Here, I think one of these pictures was taken by joels98taco, but this is what the lower ball joint bracket looks like when it breaks and then another of what it looks like mounted to the lower balljoint
    samisim0 likes this.
  19. Jun 21, 2015 at 10:30 PM
    tacomatt602
    Phoenix, AZ
    Ohhh gotcha, I missed the "bracket" part. Well..... The search continues!!
  20. Jun 22, 2015 at 1:55 PM
    alexkontos17
    Alex
    Orlando
    97 tacoma
    But new balljoints are definitely not a bad idea
