5 lug Leveling Kit
Discussion in '5 Lug' started by JMCTacoma, Jan 11, 2011.
  1. Jan 11, 2011 at 10:53 PM
    JMCTacoma
    JMCTacoma [OP] Member
    08' Tacoma Reg Cab Base Model
    Few: Custom Bike Rail Rack, Thermometer, Bed Tie Downs, Custom Emblems, 5% Rear Tint, 35% Side, LIFT soon
    Need your suggestions, I have a base reg cab, and I have been doing some researching, I am aiming to just lift the truck up a little to match the height of the rear would a leveling kit fix this (suggestions?). Or should i go straight to a ready lift kit? has anybody just done the leveling kit?
  2. Jan 11, 2011 at 10:59 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
  3. Jan 12, 2011 at 5:06 AM
    comiesutra
    comiesutra Well-Known Member
    Greenwood, IN
    '10 4X4 Silver AC SR5 Manual
    MonsterKnobs.com shift knob, Sony MEX-BT3900u
  4. Jan 19, 2011 at 12:23 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    save your money wait for the mid travel kit if you even think you might take it offroad. A midtravel front with longer shackles in the rear will go a lot farther than spacer/aal. Also shackle lifts are better than aal.
    If not then a spacer in the front is fine and then run 235's or 30 inch tires.
  5. Jan 20, 2011 at 11:18 AM
    JMCTacoma
    Thank for the info! Im thinking at this point i might just go the spacer route, Im already running 235's and I like the look of it. how big of a spacer would I have to go to match the stock height of the rear? I was thinking 2" ?
  6. Jan 24, 2011 at 1:37 PM
    Trifenix
    so cal
    99 LT 5 lug Taco
    yes 2 inches would just about level it out.
  7. Jan 27, 2011 at 4:59 PM
    Ezriderga
    Ezriderga Well-Known Member
    Georgia
    '06 Tacoma xtracab BB
    I leveled mine by using 1" lowering blocks in the rear. Got rid of that awful gap. This is the only pic I have right now. Lower pic before; pic in snow after
  8. Feb 15, 2011 at 12:06 AM
    norcal4banger
    norcal4banger 11-98 MUD
    Jack
    Far Northern California
    2005 4 Cylinder 2WD 5 Lug RC Tacoma
    I ordered a 2.75" front only a few days ago. Will install this weekend and post pics. I'm sure I'll be looking a little ass heavy but we'll see
  9. Feb 16, 2011 at 5:46 PM
    JMCTacoma
    Sweet, cant wait for the pics, just curious, Which kit did you decide to go with?
  10. Feb 16, 2011 at 8:36 PM
    norcal4banger
    Jack
    I actually only ordered the front strut spacers. nothing for the rear. They just got delivered and I can't wait to do it. I'm sure I'll end up having to do AAL though.
  11. Feb 16, 2011 at 8:36 PM
    norcal4banger
    Jack
    Oh and from fat bob's garage :)
  12. Feb 17, 2011 at 2:13 PM
    tootall
    tootall Well-Known Member
    Todd
    Maryland
    10 5 Lug Reg Cab Magnetic Gray
    Secondary Filter Removed, AVS In line vent visors, pop n lock, extang tri-fold tonneau, Fat Bob's 5 lug lift kit, Intermittent wiper stalk, mdshooter.com sticker
    fat bob FTW! got my 5 lug lift kit from them.
  13. Feb 19, 2011 at 2:55 PM
    mcleod90
    mcleod90 150,000 miles and counting
    sean
    modesto ca
    05 double cab
    did you get it installed yet? i was also thinking about just get the front spacer. but i wanted to see how it looked first.
  14. Feb 19, 2011 at 5:13 PM
    norcal4banger
    Jack
    Nope get it done monday :) :) $350 installed and aligned. However, the shop i'm taking it to are also doing a 1" block in the rear so I would post a pic of just the front spacers but since they're doing the rear now too it would really show how it'd look with just spacers. the shop owner said and I agree with him, that with only the 2.75" in the front it'd make the front about 1" taller than the ass.
  15. Feb 19, 2011 at 5:56 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    ya i was wondering because the guy that is going to install mine said that i should just put the spacers on the front so that way i keep the factory ride height in the back so its not as stiff with a AAL.
    but i figured it will look weird with the front to high so i told him i wanted to bring the rear up a bit.
    you going to put some bigger tires or are you going to keep you 235's
  16. Feb 19, 2011 at 9:14 PM
    norcal4banger
    Jack
    Well I literally just bought my tires. So depending on how much the place I got em from will buy them back and sell me bigger ones for will determine if I get bigger ones. I think my 235s will look kinda goofy but we'll see. Plus I think my 4 banger wouldn't have fun pushing a bigger tire.
    As far the rear goes the guy I went to said that I should definitely do the rear just not AAL. He strongly rec'd a 1" block instead of AAL. make the ride a little smoother.
    What's the length of the front spacers you were checking out?
  17. Feb 19, 2011 at 9:17 PM
    norcal4banger
    Jack
    oh and my buddy and I are doing the it all in my garage now. He said he knows what he's doing and this way I could save $200. I wonder how easy it is to do, the directions are pretty intimidating
  18. Feb 19, 2011 at 9:35 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    i think he said it was 2.5"
    he said he could fab up a 6" suspension lift for me and install it for 1800. but i figured theres no point in having a 2wd 4 cylinder with a 6" lift.
  19. Feb 19, 2011 at 10:25 PM
    norcal4banger
    Jack
    Yeah with the tires it'd take to fill up the room in the fenders and stuff would but slow you down bad. as if we dont go slow enough :/ lol but that'd look pretty sweet
  20. Feb 19, 2011 at 10:26 PM
    Shemicals
    Shemicals Well-Known Member
    Concord - East Bay CA
    '07 5-Lug Black Sand Pearl Access Cab 2WD
    Build Page
    you cant lift it 6 inches.... not without replacing the frame....
    they gayed our frames that way
