5 lug lift kit
Discussion in '5 Lug' started by dgrover, Sep 20, 2015.
  1. Sep 20, 2015 at 8:18 PM
    dgrover
    dgrover [OP] Member
    Doug
    Virginia
    White 2006 2.7 Gen 2
    Blacked out badges, toolbox, tint
    What would be a good 2 - 3 inch lift kit? I have a 2006 2.7L gen 2 I plan to put 32" tires on it and I would also like to lift it. What would be a good kit for that?
  2. Sep 21, 2015 at 6:07 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    For gen 2 5 lugs it's basically either a space/aal (add a leaf) or to go mid or full travel (which can cost some $$$)
    For spacer/aal theres:
    fats bobs
    Ready lift
    dgrover[OP] likes this.
  3. Sep 21, 2015 at 6:14 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  4. Jun 26, 2016 at 12:24 PM
    dgrover
    dgrover [OP] Member
    Doug
    Virginia
    Would blocks or adding a leaf be better? does adding a leaf make the ride stiffer?
  5. Jun 26, 2016 at 1:50 PM
    SlowComa666
    SlowComa666 Well-Known Member
    San Antonio TX
    2014 SR5 Access Cab 2WD
    blocks only work to lift if the leaf springs are above the axle, if they are under you are lowering with blocks
