5 lug lift re-du
Discussion in '5 Lug' started by chrismxpx, Sep 25, 2015.
  1. Oct 29, 2015 at 8:22 PM
    #41
    chrismxpx
    chrismxpx [OP] Well-Known Member
    98 rwd tacoma
    Yeah that shop also said after having my truck for 2 months im sol and cant fix my truck when the downey stuff broke. Im only using them for the warranty on shocks i drove on for less than 100 miles
  2. Oct 29, 2015 at 8:24 PM
    #42
    chrismxpx
    98 rwd tacoma
    Im trying to find leaf springs for it but i cant find much
  3. Oct 29, 2015 at 8:53 PM
    #43
    theblindchicken
    theblindchicken Well-Known Member
    Christian
    Long Beach
    '74 K10
    HID's, LED Dash swap, LED reverse lights, 15"x10" 5 slot mags, sliding rear window, 20gal aux. DS fuel tank,
    What shocks are those? Looks like the bushings were incorrect.. Is there a metal sleeve to take up the gap between the bolt and the bushing?
    The broken leaf is on the raised side or the sagging side?
    Can you post pictures of both sides of the rear suspension? (Leaf springs, shackles, upper and lower shocks mounts)?
    Where's your approximate location?
    You dont necessarily have to find a whole spring pack. You could take the middle one out (from the good side) call around for any spring shops (usually for trucks) and see if they can make a pair that are similarly arched, width, length, and strength as the leaf you pulled out. This will give both of your packs equal strength instead of only replacing the individual spring.
  4. Oct 29, 2015 at 9:55 PM
    #44
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Is your main spring on both sides still good? what I did when I neded to replace my springs was get a set of used springs from a 2010 and rebuilt them from that. Main spring from my 97 everything ells from the new leaf pack. Also did spring over axle at the same time.
    chrismxpx[OP] likes this.
  5. Oct 30, 2015 at 6:03 AM
    #45
    chrismxpx
    98 rwd tacoma
    The beoken leaf is on the right side which is the raised side. im in knoxville tn. I think they are monroe. This shop down the road installed them i didnt see any metal sleeve
  6. Oct 30, 2015 at 3:12 PM
    #46
    theblindchicken
    Christian
    Long Beach
    '74 K10
  7. Oct 30, 2015 at 8:50 PM
    #47
    chrismxpx
    98 rwd tacoma
    You guys are awsome. I have got alot of help from yall without any negitive feedback
  8. Oct 31, 2015 at 12:39 AM
    #48
    theblindchicken
    Christian
    Long Beach
    '74 K10
    That's what we're all here for. Help each other out when they need a hand or just hang out and have a good ol time.
    Best of luck with the repairs, sir. Keep us updated.
    chrismxpx[QUOTED][OP] likes this.
  9. Nov 2, 2015 at 1:54 PM
    #49
    chrismxpx
    98 rwd tacoma
    So i get my truck back from the shop.... (2 days for rear shock) and they say that my truck is made from 3 different trucks and the rear shock mounts are for circle track trucks and thats why they broke..... they also tried charging me labor for reduing the even tho i put less than 100 miles on em... so glad to have it back still need to fix the steering its getting alittle worse
  10. Nov 10, 2015 at 6:12 PM
    #50
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Damn 5-lugs!
  11. Nov 11, 2015 at 5:04 PM
    #51
    chrismxpx
    98 rwd tacoma
    After alignment the truck is feeling smooth. Comfortable on the interstate
  12. Mar 30, 2016 at 8:05 AM
    #52
    chrismxpx
    98 rwd tacoma
    New problem. Lower ball joints are both torn. Less than 2k miles and the inside of boot on both has rips and now pops when reversing and turning hard
  13. Apr 8, 2016 at 8:57 PM
    #53
    adamengbrecht
    adamengbrecht New Member
    Adam
    '99 ext cab 5 lug
    Hey do you think those qa1's could be used with a stock lower control arm? Did some measurements and not sure if it would fit with a 9" coil
  14. Apr 8, 2016 at 9:59 PM
    #54
    theblindchicken
    Christian
    Long Beach
    '74 K10
    The stock lower arms dont have the correct mounting to use the coilovers. You may be able to fit it if you used one of the eye hole through bolts like the stock mounting points. Would be all the front end weight sitting on two small bolts though.
  15. Apr 8, 2016 at 11:01 PM
    #55
    adamengbrecht
    Adam
    '99 ext cab 5 lug
    Yeah I've looked into that and I found some bar pin eliminators from jeeps that looks like it could work if i reinforced the lower a bit where the coil would sit. just not sure if there's enough room for a coilover in there
  16. Apr 9, 2016 at 12:26 AM
    #56
    theblindchicken
    Christian
    Long Beach
    '74 K10
    Wouldnt hurt to go check the extended and compressed lengths of the coilover. Would wanna cycle the stock arms to see how far it'll droop and fully compress.
    Might be a different distance between the frame and the mounting point of the shock or coilover.
  17. May 2, 2016 at 6:34 PM
    #57
    chrismxpx
    98 rwd tacoma
    I am about to just buy new lca since they include the bushings and prob use a adapter on it also
  18. Dec 7, 2016 at 9:57 AM
    #58
    spencerjg72
    spencerjg72 Well-Known Member
    2004 toyota tacoma 5 lug base model
    LCE built motor +40 street piston set Chromoly H-Beam Connecting rods Lightweight flywheel (11lb) 2RZ Head Stage 3 KIt Pro Head stud kit Stage 3 Camshaft set Street Series water pump Adjustable Camgears 2RZFE Flex Fan (16in)
    what length shocks were they you used for the qa1
  19. Dec 8, 2016 at 1:29 AM
    #59
    spencerjg72
    where can i find different lca with the eyelet mount on it for my tacoma
  20. Feb 28, 2017 at 7:43 PM
    #60
    chrismxpx
    98 rwd tacoma
    I will look up my order and give u the specs
