5 Lug Lift
Discussion in '5 Lug' started by jtj2000, Aug 24, 2017.
  1. Aug 24, 2017 at 1:08 PM
    jtj2000
    jtj2000 [OP] Member
    Jonathan
    AAL and front spacer 5 lug
    I already have a front spacer and some sort of block in leaf springs that gave some lift. Time for new tires and figured this would be a good time to lift it as well. I have seen many ideas but not sure how well they work on internet. I want to lift BOTH front and rear to fit larger tires. Open to any ideas that worked for you guys. Thanks!
  2. Aug 24, 2017 at 1:37 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    What gen are you and what tires size are you thinking?
  3. Aug 24, 2017 at 1:40 PM
    jtj2000
    jtj2000 [OP] Member
    Jonathan
    2nd Gen 2007 and i would like 31s or something with a nice look
  4. Aug 24, 2017 at 1:41 PM
    jtj2000
    jtj2000 [OP] Member
    Jonathan
    it was either the procomp or fat bob lift with the spacers and leaf adjusment in the back. Just wanted some more heighth. Just starting to get into truck mods as it was my first car lol
  5. Aug 24, 2017 at 1:44 PM
    Clearwater Bill
    Billy
    Largo Florida
    Wheels matter.
    On OE wheels you can run 235x75x15 with no lift, no rubbing, no problems.
    It's a 2" dia larger tire, so you get 1" of ground clearance lift.
    Get into wide wheels, weird offsets/backspacing and you start encountering fitment challenges.
    And you start adding complexity to a vehicle that in the end is still only 2wd base vehicle.
    I love mine. Perfect for my purposes. If you want more, a Prerunner or a 4wd may be a more practical choice.
    5 Lug Fury likes this.
  6. Aug 24, 2017 at 1:45 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    The biggest we can go is a 3 in spacer then it goes into midtravel and long travel. You can also do a 1 in body lift but that'll show some gaps between the body and the frame. The rear is really easy to lift some people do another but different size aal, a whole new set of leafs, or a shackle flip.
  7. Aug 24, 2017 at 1:46 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    I mean I'm going 33's lol but like you said you have to be careful with bs and offset. Our trucks are very capable for a 2wd but there will always be something you'll have to drive around.
  8. Aug 24, 2017 at 1:48 PM
    jtj2000
    jtj2000 [OP] Member
    Jonathan
    OE is a brand of wheels that fit larger tires the best? Thanks for all the help guys I did not want to buy the wrong thing lol
  9. Aug 24, 2017 at 1:53 PM
    Clearwater Bill
    Billy
    Largo Florida
    OE = Original Equipment
  10. Aug 24, 2017 at 1:55 PM
    jtj2000
    jtj2000 [OP] Member
    Jonathan
    ohh so stock rims?
  11. Aug 24, 2017 at 2:02 PM
    jtj2000
    jtj2000 [OP] Member
    Jonathan
    and where can you find a good 1 inch body lift @5 Lug Fury ? interested to know how you got 33s on
  12. Aug 24, 2017 at 3:09 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    I don't have 33's yet but im in the process to getting mine on. @SamGoingHam has already done it along with a few others. Im planing on 3" spacer 1" body lift and minimal trimming of the fenders. I have to get a different set of rims because the bs and offset has to be right. Note that with 33's a regear will be needed and the components will wear a little faster but its so worth it if you truely offroad.
  13. Aug 24, 2017 at 3:13 PM
    jtj2000
    jtj2000 [OP] Member
    Jonathan
    what spacers and body lift are you getting and where from? @5 Lug Fury
  14. Aug 24, 2017 at 3:22 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
  15. Aug 24, 2017 at 3:24 PM
    jtj2000
    jtj2000 [OP] Member
    Jonathan
    awesome thanks! what rims were you looking out? and i was planning on doing mine in october so please pet me know how it goes. Thanks for all the tips
  16. Aug 25, 2017 at 10:21 AM
    SamGoingHam
    SamGoingHam IG: SamGoingHam
    Sam
    Phoenix, Arizona
    2014 TACO 5LUG LOCKED
    I'm running Cragar wheels with 33x12.5x15. With the stock rims I ran 32x11.5 easily, rubbing at full turn.
    3in Readylift & 1in 4Crawler BL. Chopped about 2ins off the front fender. Probably doing the rear as well. Gear changed from 3.58 to 4.56 with a locker.
  17. Aug 25, 2017 at 11:17 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    I thought you did an eBay spacer...Readylift is only 2.75"
  18. Aug 25, 2017 at 11:25 AM
    SamGoingHam
    Sam
    Phoenix, Arizona
    Yeah, I swapped it for a 3in. Just got tired of having to explain it to people so I just call it a 3in Readylift now.
