5 lug lift
Discussion in '5 Lug' started by Kobykhoward, May 9, 2019.
  1. May 9, 2019 at 11:25 AM
    Kobykhoward
    Kobykhoward [OP] New Member
    2006 4cyl 5 lug double cab
    I purchased the pro comp leveling kit, wanting to know what size shocks do i need to get. They are soft and need replacing anyways. Also im buying new rims and tires and looking for help on what size tire i can do with out black box mod. And rim size should i go with. Trying to stay on a budget.
    Thanks
  2. May 9, 2019 at 11:36 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    I'm assuming the kit is 2.75" in the front and 2 in rear. Bilstein 4600 on the front and 5100s in the rear is pretty much the standard for 5 lugs. For rims I suggest 4in backspace and -13mm offset such as cragar soft 8's. I really really really really really suggest doing the black box mod if your worried about cutting the plastic you can get 6 lug liners that don't have the bulge. The black box really limits the tire size you can do.
    taco.the.track likes this.
