5 Lug Long Travel 2rz Turbo Build
Discussion in '1st Gen. Builds (1995-2004)' started by MadTaco461, Jun 8, 2014.
  1. Dec 15, 2015 at 5:17 PM
    #181
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Wondering if I should just go to 12 psi from the get go.. Is a piggy back a must for 12?
  2. Dec 15, 2015 at 6:05 PM
    #182
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    I would say so. Thats quiet of bit of boost for these motors. You going to have to get even bigger injectors then the pink tops too.
    And more crap is just to go wrong dealing with tuning and stuff.
  3. Dec 15, 2015 at 6:06 PM
    #183
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Yeah I know but I really don't want to mess with tuning right now. And I have almost no room for an intercooler which would be a must at 12..
  4. Dec 15, 2015 at 6:09 PM
    #184
    gray223
    SE Missouri
    2014 Tundra Limited
    Your going to have pinging problems without a intercooler at almost any boost I would think. Unless your dumping alot of fuel to keep it cool. Maybe not if you have higher octane fuel.
    But maybe you won't have problems...idk for sure
  5. Dec 15, 2015 at 6:10 PM
    #185
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    I run nothing but 93.
  6. Dec 15, 2015 at 6:29 PM
    #186
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    I'd still run a small intercooler if you can. You could even put a cut out in the hood, like some Subarus have. No need for a fuel pump under 5psi. Do not ever buy a walbro. Only denso. I have a denso tt supra pump. Tial wastegate direct from them (no knock offs) f38 .5bar 7.25 psi spring. Thing is the spring will not necessarily register what it says. Mine actually only goes to less than 5psi. It can depend on the system it is in. But I can go to 14psi and more with it. I recommend a stand alone if you can afford one, I'm not sure though how your 4cyl would respond to one. Mine slightly conflicts with the oe ecu. I may go to a stand alone eventually. More control and I'll easily make more hp.
  7. Dec 15, 2015 at 6:33 PM
    #187
    j0shu4
    Superchargers run a good amount of boost with minimal ping. They inhale hot ass air. I love methanol too. You can run more boost. It's like running really cold fuel. If I boost a lot it goes quick, but I don't mind filling up the tank. Plus, windshield washer fluid is 1.99 a gallon.
    You'll be able to generate more power with an intercooler too. And or methanol.
    gray223[QUOTED] likes this.
  8. Dec 15, 2015 at 6:41 PM
    #188
    gray223
    SE Missouri
    2014 Tundra Limited
    Do you have a standalone? I was think of just getting an aem fic when I up the boost and its needed. I think I'll just start at 5psi get the pink injectors skip the fuel pump and just see how that goes.
  9. Dec 15, 2015 at 7:47 PM
    #189
    j0shu4
    You'll be fine like that. Oe injectors will handle that much. I have the fic6, it just does like this super quick sputter from time to time. Nothing major. ECU oe conflict learning.
  10. Dec 16, 2015 at 4:18 PM
    #190
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Bought those pinks
    MadTaco461[OP] and Speedytech7 like this.
  11. Dec 16, 2015 at 9:29 PM
    #191
    MadTaco461
    MadTaco461 [OP] BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Awesome, you'll like them.
    Gear Head[QUOTED] likes this.
  12. Dec 17, 2015 at 5:38 PM
    #192
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
  13. Dec 17, 2015 at 5:57 PM
    #193
    MadTaco461
    CA
    Kinda stock
    That seller has a crap ton of bad reviews. See if the part # matches up with what lce or urd sells. I'd try a different seller for sure if he sends you a bad one even though that is a good price on fuel pump. I haven't had any issues with my walbro but it was from urd.
    That pump is plenty of flow. You can upgrade to almost 1000cc inj with that pump.
  14. Dec 17, 2015 at 5:59 PM
    #194
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Wow, thanks for the heads up.. that's terrible. I'll see if I can find another seller
  15. Dec 17, 2015 at 6:01 PM
    #195
    MadTaco461
    CA
    Kinda stock
    Torspd and Gear Head[QUOTED] like this.
  16. Dec 17, 2015 at 6:19 PM
    #196
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Did you put a crankcase breather on both vents on the valve cover? I read somewhere that the rear has a check valve so it's not affected by boost
  17. Dec 17, 2015 at 7:49 PM
    #197
    j0shu4
  18. Dec 18, 2015 at 4:28 AM
    #198
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Walbros are great pumps. However. There offer a variety of options. So the right one needs to be used for the intended output.
    More importantly, MAKE SURE NOT to get a knock-off. They are one of the most recognized and reputable brand pump manufacturers on the market. Which means that there are plenty of bottom feeders trying to make a buck off of their name.
  19. Dec 18, 2015 at 2:59 PM
    #199
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Just bought the deatschwerks pump. Make it stop.. haha
    j0shu4 and MadTaco461[OP] like this.
  20. Dec 18, 2015 at 3:06 PM
    #200
    MadTaco461
    CA
    Kinda stock
    It's so many parts when you piece it together. You'll be boosting about the time I get my turbo back on. I collected for about 3 months before I knocked out the project.
    j0shu4 and Gear Head like this.
