5 Lug Long Travel 2rz Turbo Build
Discussion in '1st Gen. Builds (1995-2004)' started by MadTaco461, Jun 8, 2014.
  1. Dec 5, 2015 at 8:49 AM
    #141
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Sounds good. I plain on picking up some stainless wire and welding it up. Don't think I'm going to worry about back purging. I ordered an ass load of parts last night
  2. Dec 8, 2015 at 4:59 PM
    #142
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Any issues reading your depo gauge with the smoked lens during the day? Read a few reviews on it with that common complaint. Looking at going with the AEM uego wideband and depo boost gauge.
  3. Dec 8, 2015 at 8:19 PM
    #143
    MadTaco461
    MadTaco461 [OP] BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I love my depo. I think it is crazy bright. Looks professional, but the sunpro next to it doesn't help. Day it is very nice, but for night I should really install the dimmer up to it. This is for afr though I haven't seen their other gauges.
  4. Dec 8, 2015 at 9:17 PM
    #144
    MadTaco461
    CA
    Kinda stock
    Gear Head, gray223 and Speedytech7 like this.
  5. Dec 14, 2015 at 1:39 PM
    #145
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Where'd you get your pink tops? I'm having trouble simply finding a set
  6. Dec 14, 2015 at 1:42 PM
    #146
    MadTaco461
    CA
    Kinda stock
    I got mine used from a guy off custom tacos. You could check junk yards. I think 01-04 have them.
  7. Dec 14, 2015 at 1:44 PM
    #147
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Yeah I made an account over there but that place is dead. Junkyards don't really have tacomas around here either. Can you keep an eye out for me?
  8. Dec 14, 2015 at 1:52 PM
    #148
    MadTaco461
    CA
    Kinda stock
    Sure, that place is dead. I'll keep an eye out. The online junk yards are the best you find on eBay. Just get them flow tested. A full set is about 100 used
    Gear Head likes this.
  9. Dec 14, 2015 at 1:54 PM
    #149
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Nice, I'll check out ebay this evening. I'm about to head to get the rest of my manifold tigged up so I should have the turbo mounted up this evening.
    MadTaco461[OP] likes this.
  10. Dec 14, 2015 at 4:51 PM
    #150
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Ebay has a couple good sellers that specialize in injectors of various sizes, all flow tested, refurbished, etc., for good prices.
    Gear Head[QUOTED] likes this.
  11. Dec 14, 2015 at 4:56 PM
    #151
    MadTaco461
    CA
    Kinda stock
    What injectors did you end up using?
  12. Dec 14, 2015 at 5:31 PM
    #152
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Have a link?
  13. Dec 15, 2015 at 8:49 AM
    #153
    j0shu4
    I got 440's.
    These are 550.
    http://www.ebay.com/itm/550cc-Toyot...ash=item2ca4914ca4:g:zkoAAOxy83JRG13L&vxp=mtr
    These guys are good.
    http://www.osidetiger.com/Pages/default.aspx
    440's
    http://m.ebay.com/itm/Toyota-1995-0...440cc-Fuel-injectors-/381363328444?nav=SEARCH
    Call that osidetiger place, tell them the pound or cc injectors you want. There's Prolly more too. Search ebay a bit. You'll find some. Got mine for $180.
  14. Dec 15, 2015 at 9:00 AM
    #154
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    How much boost are pink tops good to? I'm planning 7-8 psi to start but would like to bump up to 12 down the road. Also am I risking detonation at 7-8 with no intercooler?
    Also, I notice d that the links above are for a 5vz, are those injectors the same as the 3rz?
  15. Dec 15, 2015 at 9:01 AM
    #155
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  16. Dec 15, 2015 at 9:01 AM
    #156
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Depends on fueling and IAT's.
  17. Dec 15, 2015 at 10:39 AM
    #157
    MadTaco461
    CA
    Kinda stock
    I run on crap ca gas. You guys have 93 to work with. So you might not be as sensitive as me to knock. I have denso 550cc sitting for when I feel like tuning them. Denso are factory and spray like stock. I just went off what people say. You get what you pay. Certain things I spend money on just not to deal with the headache.
    Pinks are like 315 to 325cc. You might get up to 6 to 7 with them. Afr gauge you can run it to its potential.
    Torspd likes this.
  18. Dec 15, 2015 at 11:11 AM
    #158
    j0shu4
    What fuel management are you going to run?
  19. Dec 15, 2015 at 11:33 AM
    #159
    MadTaco461
    CA
    Kinda stock
    I already have a mapecu3. I think at @Gear Head doing stock ecu for a bit and slowly upgrade.
    Also to add to @Torspd list
    Fiveomotorsport.com
    they are flow matched reworked oem injectors where I got my 550cc.
    Not saying anything bad about cheaper injectors, but they do have a different spray pattern and lag time if you get aggressive with tuning or have a knock sensitive truck.
    Torspd likes this.
  20. Dec 15, 2015 at 12:10 PM
    #160
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Looks like I've got some not reading to do. I wasn't planning on piggybacking since everything I've read says I should be able to run 8psi with just pinks and a fuel pump. Gonna order aem wideband and boost gauge tonight
