5 Lug Long Travel 2rz Turbo Build
Discussion in '1st Gen. Builds (1995-2004)' started by MadTaco461, Jun 8, 2014.
  1. Dec 15, 2015 at 12:19 PM
    #161
    MadTaco461
    MadTaco461 [OP] BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    8 psi is just a number floating around. But yeah the afr gauge will tell you how hard you can run that guy. I just upped the boost until I hit mid 11s afr as my highest point.
    Before the afr gauge I only ran 5psi because I didn't know what was going on. It just a peace of mind because every motor is a little different.
  2. Dec 15, 2015 at 12:40 PM
    #162
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Look into the innovative scg-1. It's an ebc, wideband all in one. Afr and boost gauge. What I'm running.
  3. Dec 15, 2015 at 1:25 PM
    #163
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    The reason I'm so set on a specific number is because I'm running an external wastegate so I have to pick a spring. With an electronic boost controller does the spring really matter since it's changing the pressure that the wastegate sees anyways?
  4. Dec 15, 2015 at 1:31 PM
    #164
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    I would just run at a safe number like 5 pounds and see what happens and adjust from there. Thats what I'm going to do.
    What fuel mods (injector size, fuel pump) and piggyback where you running with 5 psi? I plan on just starting there and maybe staying for awhile if no need for piggyback or bigger fuel pump and injectors. I'll be getting an afr guage either way.
  5. Dec 15, 2015 at 1:41 PM
    #165
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
  6. Dec 15, 2015 at 1:48 PM
    #166
    gray223
    SE Missouri
    2014 Tundra Limited
  7. Dec 15, 2015 at 1:53 PM
    #167
    MadTaco461
    CA
    Kinda stock
  8. Dec 15, 2015 at 1:57 PM
    #168
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Cool. So if I'm understanding correctly that will get me to my 7-8 psi goal on the stock ecu and to bump to 12psi I'd need a fuel management solution, and bigger injectors?
  9. Dec 15, 2015 at 1:57 PM
    #169
    MadTaco461
    CA
    Kinda stock
    I had pinks, no tuning, no afr gauge, and walbro fuel pump. It was running rich, but I didn't know what was going on
  10. Dec 15, 2015 at 1:58 PM
    #170
    gray223
    SE Missouri
    2014 Tundra Limited
    So the stock fuel system and ecu won't handle it? Does it make a difference I have a 5vz?
  11. Dec 15, 2015 at 2:00 PM
    #171
    MadTaco461
    CA
    Kinda stock
    Maybe slightly lower since you are a bigger engine 6-7. 12 going to need at least 440cc injector. I'm maxing my pinks out at 9psi, but that is with a tune because I can log afr.
  12. Dec 15, 2015 at 2:04 PM
    #172
    MadTaco461
    CA
    Kinda stock
    Stock ecu will handle it. Do the fuel pump for sure.
  13. Dec 15, 2015 at 2:06 PM
    #173
    gray223
    SE Missouri
    2014 Tundra Limited
    Im just wondering if I will need bigger injectors at 5 psi. And it would probably be more efficient if I had a piggyback to tune instead of using the stock ecu only right?
  14. Dec 15, 2015 at 2:26 PM
    #174
    MadTaco461
    CA
    Kinda stock
    I haven't tried it but I've heard that is how far the stock injectors go. You get that itch to go past 5psi real quick. I swear by those pink injectors because it is right when that turbo feels fun.
    Gear Head likes this.
  15. Dec 15, 2015 at 2:29 PM
    #175
    gray223
    SE Missouri
    2014 Tundra Limited
    Ya probably. It would just save money so I wouldn't have to spend a lot all at once. Or I could do some searching for used stuff.
  16. Dec 15, 2015 at 2:37 PM
    #176
    MadTaco461
    CA
    Kinda stock
    $100 for some pinks you won't regret for low power boost. It's a good cheap power mod. The stock ecu is very friendly with them.
    gray223[QUOTED] likes this.
  17. Dec 15, 2015 at 4:14 PM
    #177
    j0shu4
    Spring is for the minimum pressure. Boost can go way over it. An ebc adjusts after you reach your minimum spring pressure. Also, make sure you get a good wastegate. Either precision ot tial. Do not skimp on that.
  18. Dec 15, 2015 at 4:21 PM
    #178
    gray223
    SE Missouri
    2014 Tundra Limited
    Is a oil cooler necessary before turbo? What about if it's water cooled as well?
  19. Dec 15, 2015 at 4:35 PM
    #179
    j0shu4
    Water and oil is better but not necessary. If it's a dd, + water is better. I have water and oil. No need to use a turbo timer that way or let idle before shut off. No need for an oil cooler either but it wouldn't hurt any. 100% need to run an intercooler.
  20. Dec 15, 2015 at 4:48 PM
    #180
    gray223
    SE Missouri
    2014 Tundra Limited
    Thank you. Plan is run oil and water. Will be using an intercooler also. Think I will switch to pink injectors, run a 5psi wastegate spring, no piggyback, see what afrs are like. Just wonder if I will need to upgrade fuel pump? If so how many lph?
