5 lug maintenance
Discussion in '5 Lug' started by jmarquez808, Apr 29, 2013.
  1. Apr 29, 2013 at 3:23 PM
    jmarquez808
    jmarquez808 [OP] Large Member
    Jess
    Hawaii
    07 4x2 reg cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    im at 68,000 miles havnt done anything other then oil changes cabin air filter changes and cleaning/changing normal air filter. What else does our truck need, i have the service manual, i see a lot of draining and flushing maintenance recommended at 60,000 miles. Im planning to do the rear differential since it says every 60,000 then i read osm conflicting answers about how the rear diff will last up to 100,000 in many vehicles. Since mine is 2 wheel drive should i drain and fill this or leave it for a while. Never goes offroad obviously. Im sure following the manaual is the smartest idea. But i was just curious what everyone has to say from their experience . Im looking to do any required maintenance myself rather then paying the dealer 600.
  2. Apr 30, 2013 at 4:07 AM
    808TRDTaco10
    808TRDTaco10 Black Sand Mirror
    Justin
    Big Island--->Oahu, Hawaii
    10 AC TRD OR 4x4 BSP; 08 Reg Cab 5 spd 4x4
    TRD Off Road 265/75/16 Goodyear Wrangler Duratrac Load Range C | Toytec Ultimate Lift with Emu Dakar Leaf Packs | 3* Axle Shims, CB Drop, Sway Bar Relocates | AVS Vent Visors, AVS Bugshield | Scangauge II | Smoked Eagle Eyes Ebay LED Tails | Wet Okole Seat Covers | Weather Tech Floor Liners | Pop n Lock | OEM Bed Mat | Truxedo Lo Pro QT Tonneau Cover | TRD Cat Back Exhaust | Aftermarket Alarm System | Pro Coat "Electronic Rustproofing"
    When I got my 06 5 lugger a few months ago I changed the rear diff oil, spark plugs, and did an ATF drain and refill. I am supposedly the 4th owner of the thing and it had about 109k miles when I bought it. The fluids and spark plugs definitely looked as though they should have been changed sooner (I'm pretty sure none of the previous owners did any of that maintenance.)
  3. Apr 30, 2013 at 10:21 AM
    jmarquez808
    Jess
    Hawaii
    07 4x2 reg cab
    yah im bout to do the diff, but im original owner with 69,000 so we shall see if its even dirty, tho it is recommended every 30,000 so imsure there is a reason for that. never did the trans drain and fill before. Nice extended cab, big island kruza!
