5 Lug mid travel????
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoBunny, Nov 1, 2017.
  1. Mar 26, 2018 at 11:53 AM
    #181
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Do you guys all run like 4cyl autos? 4.10 on my truck would alow me to rub 35 with the speedo reading right. 3.55 is what i need to run 30s and my speedo read right
  2. Mar 26, 2018 at 11:55 AM
    #182
    tony2018
    tony2018 Well-Known Member
    man. tempted to raise my dad's 5 lugger a bit now...
  3. Mar 26, 2018 at 11:59 AM
    #183
    TacoBunny
    TacoBunny [OP] Well-Known Member
    AZ
    1997 5 Lug 5VZ
    nope, im a v6 5 speed... its just nice having the bottom end torque, and these things are already fast so why not gear em to be faster in the rev range i actually use
  4. Mar 26, 2018 at 12:05 PM
    #184
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    But yout speedo is still off. I thought about doing 4.10 till I realized how bad it will effect my speedo, at 70mph I already read 8mph to slow. 3.55 will correct that for me. But i guess if you dont mind it being off and able to use your tac to figure out how many miles you traveled then its ok.
  5. Mar 26, 2018 at 12:10 PM
    #185
    TacoBunny
    AZ
    1997 5 Lug 5VZ
    precisely why i bought an UltraGuage
  6. Mar 26, 2018 at 12:11 PM
    #186
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    I have 8.4 rear end with 4.10 waiting to go on but its a 6 lug so ill have 2 different lug patterns until I get 4x4 pickup spindle. My little 4 banger struggles to get 31s turning even with LCE stage 2 clutch and light weight flywheel.
  7. Mar 26, 2018 at 12:12 PM
    #187
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Your also putting more miles on the truck the. Your actually driving, atleast under gearded it doesn’t put as many lol
  8. Mar 26, 2018 at 12:16 PM
    #188
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Thought heavy fly wheels was better for bigger tires, i think thats wahat lce or urd said
  9. Mar 26, 2018 at 12:21 PM
    #189
    BikerinBlak909
    SoCal
    96 LT 5 lug
    With the oem flywheel it struggled even more n burned up the clutch a few months after putting the 31s on. Heavy flywheel are better with bigger tires when wheeling/offloading. Right now its my DD n doesn't see much dirt. When I get the LT kit it will see more dirt n then I will swap the flywheel but keep the stage 2 clutch
  10. Mar 26, 2018 at 12:30 PM
    #190
    TacoBunny
    AZ
    1997 5 Lug 5VZ
    Heavy Flywheels hold your engines rotational inertia which keeps RPMs up
  11. Mar 26, 2018 at 1:22 PM
    #191
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I run a stage 1 clutch with 30s and the stock 3.15 gear and never had a problem turning my trires, i can actually still smoke them if wanted
  12. Mar 26, 2018 at 1:32 PM
    #192
    BikerinBlak909
    SoCal
    96 LT 5 lug
    You also have a v6 vs my 4 cyclinder
  13. Mar 26, 2018 at 1:43 PM
    #193
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Ah yeah that might be it lol
  14. Mar 26, 2018 at 5:53 PM
    #194
    TacoBunny
    AZ
    1997 5 Lug 5VZ
    i got a full refund... i guess im going back to the original plan with the doetsch kit
  15. Mar 26, 2018 at 7:12 PM
    #195
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    That moment when you sell your doestch kit to me to get another kit then have to get the doestch one again lol
  16. Mar 26, 2018 at 7:14 PM
    #196
    TacoBunny
    AZ
    1997 5 Lug 5VZ
    Whoops:facepalm:
    hey, at least i could hook you up with a deal:thumbsup:
  17. Mar 26, 2018 at 7:19 PM
    #197
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Lol yeah thanks for that, im just wait now for the funds to order some tc cross shafts. Cause last time i tried taking cross shafts out of a uca i bent one lol
  18. Mar 26, 2018 at 7:49 PM
    #198
    TacoBunny
    AZ
    1997 5 Lug 5VZ
    wait... HOW?? mine are still straight even after rattling around for 2 weeks
  19. Mar 26, 2018 at 8:34 PM
    #199
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Using the wrong tool lol. 30 ton shop press vs cross shaft = bent
  20. Mar 26, 2018 at 8:51 PM
    #200
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Oh yeah btw the doetsch kit requires longer shocks, i have the part number for the doetsch shocks you will need. There like 100$
