5 Lug mid travel????
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoBunny, Nov 1, 2017.
  1. Jul 14, 2018 at 9:35 PM
    #241
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Well I don’t plan to run a body lift so I won’t have that problem lol
  2. Jul 14, 2018 at 9:37 PM
    #242
    z_thompsonpa
    z_thompsonpa Well-Known Member
    Patrick
    Austin, TX
    2000 Toyota Tacoma Ext Cab SR5 Stepside (5-lug)
    Doetsch Tech 3.5" Spindle Lift Fabtech FTS-7078 Front Shocks Bilstein 5125 Rear Shocks Daystar Front Coil Spacers Fabtech and ProComp Rear AALs 15x8 Black D-Window Steelies 4.0 BS Energy Suspension Front Poly Sway Bar Bushing & Endlink Kit Powerstop Brake Rotors Amber Corner Blinkers & Clear Fog Lights 2001+ Power Mirrors Keyless Entry & Alarm Pinch-weld mod Big 3 Electrical Upgrade w/ 1000A Battery Custom Led High Mount Brake Light 2001+ Rhino-Lined Fender Flares Gentex auto-dimming mirror w/ Compass and Temp 3rd gen 4Runner Map Light Console
    I have 2 AALs, and Bilstein 5125's. You can hover over my badge at the bottom as well.
    It has some squat... I think I had like 4 inches in the back and 3 in in the fron beforehand. Now I have 5 inches in the front and 4 inches in the back. I have to get some shackles now... lol
  3. Jul 14, 2018 at 9:40 PM
    #243
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Hows the ride with 2 aal? I thought about doing tht but it seems like it will be really stiff. So i decided im gunna save up for alcans
  4. Jul 14, 2018 at 9:44 PM
    #244
    z_thompsonpa
    Patrick
    Austin, TX
    At first it was real stiff, but it has sagged in the last year. I would say I am happy with them the way they are now.
    I want to box the rear and do the spring over at some point, so I might try to wait til then to upgrade to a true leaf pack.
    http://www.trail-gear.com/PDF/120165-1-INS.pdf
  5. Jul 14, 2018 at 9:48 PM
    #245
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I would stay soa and just upgrade it that way. @5 Lug Fury went soa and ran into a number of issues with axel wrap.
  6. Jul 14, 2018 at 9:50 PM
    #246
    z_thompsonpa
    Patrick
    Austin, TX
    I had axle wrap before my AALs. Not sure about @5 Lug Fury, but it's because mine are 18 yo and worn... lots of towing on this truck in its 280k mi lifetime.
    I guess what I am saying is that you can get axle wrap either way, its just more of a problem with spring-over than spring-under. I dont think you would have any issues with some brand new alcans and spring over setup. There are many Prerunner and 4x4 Tacomas with that kind of setup.
  7. Jul 14, 2018 at 10:08 PM
    #247
    z_thompsonpa
    Patrick
    Austin, TX
    I also had another idea regarding the heim rod end conversion on the strut bar. Instead of going with heims... I was thinking Johnny joints or Creeper joints might be a better idea. You would still have to get them customized, but I might explore this some more.
  8. Jul 14, 2018 at 10:28 PM
    #248
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I wonder if @Luv my yota can fab something up.
  9. Jul 14, 2018 at 10:34 PM
    #249
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Yeah it was mainly because I removed my overload spring making them pretty soft.
    z_thompsonpa likes this.
  10. Jul 14, 2018 at 11:00 PM
    #250
    z_thompsonpa
    Patrick
    Austin, TX
    I guess I was having more of a wheel hop than axle wrap before adding the AALs, but I think they are kind of related. I didn't remove my overloads but I definitely thought about it. That's good to know.
  11. Jul 15, 2018 at 12:49 AM
    #251
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    Sure can, It would only be limited by imagination! I love hiems and can get them in very large sizes but roller bearings are very slick aswell. That said Total Chaos gets away with greased poly and nobody complains, they have an option for big ballers to use adjustable heims though too. How much do you want to spend really, as either will do the job but one is much more precise, they both need to be cleaned and lubed though. I’ve made custom suspension for years & w/leaves I’ve seen mucho axle wrapo, leafs are great but in a perfect world they should have been phased out by now, shoot Deaver leafs slapped leaves on the real Bonnie and Clydes ride, I visited their shop & that shop is as old as leaf springs too. Tech that truly came from horse and buggy. Give me some ideas of what you guys need and the problem that needs solving, and I can get the 5 lug trucks kicking again. BTW I am not bashing either companies both are excellent and have great reputations and I use their products.:thumbsup:
  12. Jul 15, 2018 at 12:58 AM
    #252
    Luv my yota
    00 turd lift 33's
    :burp:Lol, night owl too?:alien: Sperrunner.
    Sperrunner likes this.
  13. Jul 15, 2018 at 7:27 AM
    #253
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Usally yeah lol
  14. Jul 18, 2018 at 3:50 PM
    #254
    z_thompsonpa
    Patrick
    Austin, TX
    @Luv my yota , I roughly measured the dimensions of the existing bushing, but didn't write it down. Basically what I was thinking is if you could find an existing weld on "rock end, johnny joint, creeper joint, etcc" that fits the same dimensions, you could just cut the old bushing off and weld the new end on. Only thing would be keeping the length the same, or maybe you make it adjustable.
    It would be building off this idea, but using the Johnny Joints (or equivalent) instead.
    I'll get the dimensions and post them here when I get a chance.
  15. Jul 18, 2018 at 10:39 PM
    #255
    Luv my yota
    00 turd lift 33's
    Cool I’m willing to help.
  16. Jul 18, 2018 at 10:42 PM
    #256
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Why you only ever on late at night :rofl:
  17. Jul 19, 2018 at 11:58 AM
    #257
    Luv my yota
    00 turd lift 33's
    :tumbleweed:Yep, I cant help it anymore. Its the only time its 79 degrees and a/c bills are horrendous. I get shit done at night. I can’t even think straight w/day temps @ 120.
    BikerinBlak909 and Sperrunner like this.
  18. Jul 19, 2018 at 1:51 PM
    #258
    5 Lug Fury
    Kenny
    Knoxville, TN
    I live in South Florida. You have to change your shirt from getting the mail during the day. Night time is the way to go
  19. Jul 19, 2018 at 4:53 PM
    #259
    z_thompsonpa
    Patrick
    Austin, TX
    It hit 105 here today, and I have to install some tierods. I can relate to that strategy.
  20. Jul 20, 2018 at 10:47 AM
    #260
    TacoBunny
    TacoBunny [OP] Well-Known Member
    AZ
    1997 5 Lug 5VZ
    Now that im seeing those coil overs i might want to end up going that route those look nice and with plenty of room for more lift
