5 Lug mid travel????
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoBunny, Nov 1, 2017.
  1. Mar 24, 2018 at 5:25 PM
    #161
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    Is there a longer strut bar? The oem bar isn't gonna fit on those
  2. Mar 24, 2018 at 5:52 PM
    #162
    TacoBunny
    TacoBunny [OP] Well-Known Member
    AZ
    1997 5 Lug 5VZ
    Nope, just arms... That's all the kit came with I took off the strut bar
  3. Mar 24, 2018 at 6:25 PM
    #163
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    i wonder if you have to assemble the kit yourself, like you need to find alm the parts on there website and order. Its not just a complete kit on its own. But if thats the case then its kinda dumb
  4. Mar 24, 2018 at 6:50 PM
    #164
    z_thompsonpa
    z_thompsonpa Well-Known Member
    Patrick
    Austin, TX
    2000 Toyota Tacoma Ext Cab SR5 Stepside (5-lug)
    Doetsch Tech 3.5" Spindle Lift Fabtech FTS-7078 Front Shocks Bilstein 5125 Rear Shocks Daystar Front Coil Spacers Fabtech and ProComp Rear AALs 15x8 Black D-Window Steelies 4.0 BS Energy Suspension Front Poly Sway Bar Bushing & Endlink Kit Powerstop Brake Rotors Amber Corner Blinkers & Clear Fog Lights 2001+ Power Mirrors Keyless Entry & Alarm Pinch-weld mod Big 3 Electrical Upgrade w/ 1000A Battery Custom Led High Mount Brake Light 2001+ Rhino-Lined Fender Flares Gentex auto-dimming mirror w/ Compass and Temp 3rd gen 4Runner Map Light Console
    already been said... but I was going to say that maybe it was meant for stock spindle and upper ball joint mounted on top of the uca. the strut bar looks like it goes in the two holes closest to the coil seat, though, since the lower arms are longer
    I would definitely hit them up. Did it come with any installation instructions?
  5. Mar 24, 2018 at 7:00 PM
    #165
    z_thompsonpa
    Patrick
    Austin, TX
    I was looking closer at @TacoBunny 's photos.. maybe like @Sperrunner was saying... lower ball joint bracket on top of new LCAs.
    I was also thinking you could swap the orientation of the lbj back to stock, or play with different variations of those two settings... use process of elimination until camber looks right again. then observe the setup for any red flags, of course
  6. Mar 24, 2018 at 7:13 PM
    #166
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    But even with that control arm set up its not really giving any more travel its just simply lowering the mounting point of the spindle so iys just giving lift like the spindles. The doestch system is better cause you actually get a little more travel
  7. Mar 24, 2018 at 7:16 PM
    #167
    z_thompsonpa
    Patrick
    Austin, TX
  8. Mar 24, 2018 at 7:27 PM
    #168
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    The doetsch uca and coils come with bump stops for the uca to give more travel
  9. Mar 24, 2018 at 7:37 PM
    #169
    TacoBunny
    AZ
    1997 5 Lug 5VZ
    Thanks for the options guys, I'll give it another go Tomorrow and let you know if añanythi changes
  10. Mar 26, 2018 at 12:10 AM
    #170
    BikerinBlak909
    SoCal
    96 LT 5 lug
    Was looking at your picture for awhile. Try mounting the lower bj bracket on top of the lca with the lbj on top of the bracket pointing up. May put the lca close to the ground though and added leverage to the lbj bracket causing it to snap easier
  11. Mar 26, 2018 at 12:13 AM
    #171
    BikerinBlak909
    SoCal
    96 LT 5 lug
    Part# 9.9123 3/8" tall
    Part#9.9102 5/8" tall
  12. Mar 26, 2018 at 12:17 AM
    #172
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Problem is though the uca isn’t long enough to reach the top the spindle, that uca is like stock length but the lca is atleast 3” longer
  13. Mar 26, 2018 at 12:24 AM
    #173
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Looking at it agian even if it you mounted the lbj to the top side of the lca you lose lift but the spindle if it sits in its proper angle sits still way to for for the uca to reach. I almost feel like it needs either the oem spindle or its own spindle made by that company
  14. Mar 26, 2018 at 8:35 AM
    #174
    TacoBunny
    AZ
    1997 5 Lug 5VZ
    Thanks for the suggestions, I tried everything but nothing worked, at the end of the day I just returned it to stock. I'm calling the shop today to get a refund
  15. Mar 26, 2018 at 8:42 AM
    #175
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    You should explain to then what is wrong with it and see what they have to say about that. Im curious on what there thought process was on making that lift
  16. Mar 26, 2018 at 10:20 AM
    #176
    z_thompsonpa
    Patrick
    Austin, TX
    Yeah, I understand your frustration with the company/product, but it would be nice to know what they have to say about it. It may be as simple as using the stock spindle, or maybe they are unaware of their design flaws. It would be helpful for others that may want to install this kit. (provided there is a way to install it..)
    TacoBunny[OP] likes this.
  17. Mar 26, 2018 at 10:25 AM
    #177
    TacoBunny
    AZ
    1997 5 Lug 5VZ
    ill let you guys know, but on a much better note... i finally got my 3.91 diff installed!!:D
  18. Mar 26, 2018 at 10:26 AM
    #178
    SpeySquatch
    2016 TRD OR DCSB
    I had this Fabtech 3" spindle lift with a part number: FTS4130-7 on my 5-lug, but did not buy UCAs.
    It was a single cab 4-banger and was fun as hell
  19. Mar 26, 2018 at 11:05 AM
    #179
    z_thompsonpa
    Patrick
    Austin, TX
    Awesome! I got my 4.10 installed and drove it around the block a few times. I can already tell I am going to enjoy it. I still need to bleed the brakes, though. My bleeder gun broke, so I am in the process of making my own pressure bleeder. I am also finishing up a radiator install... waiting on some oil cooler adapter fittings. Since radiator was custom mounted, I went ahead and installed the 4crawler 2in body lift kit I have had for about a year now sitting around. I emailed Bilstein, and they said to expect a call this week. (can't wait) When I finally figure out my front end mid-travel, I'll have so much wheel gap, I am thinking about going with 33s, but definitely 31s. hard to say... maybe 32s haha
    TacoBunny[QUOTED][OP] likes this.
  20. Mar 26, 2018 at 11:10 AM
    #180
    TacoBunny
    AZ
    1997 5 Lug 5VZ
    id probably go 31 with the 4.10. my 3.91 kinda makes me wish id've gone with a 4.10. I just love that i can cruise at 80 and be right at a healthy 3k rpm!! Its definitely more enjoyable but ive only got 29s im gonna move up to 30s eventually but i feel like itll be better once i start doing engine mods. I dont think i want to go the turbo route... im looking into a centrifugal supercharger :D. I found a Universal bracket that i can get cut to fit the 5vz. Dont get your hopes up for the near future unless i get another job, one of those puppies new is 3k in total. i love that im
