5 Lug on 31"s
Discussion in '5 Lug' started by Hunters Taco, Jan 28, 2016.
  1. Mar 9, 2016 at 10:54 AM
    #41
    tacostache
    tacostache Active Member
    2013 Base Model
    intake and headers
    Is there any rubbing with 31's no lift?
  2. Mar 9, 2016 at 11:06 AM
    #42
    SleazyPetey
    SleazyPetey Popeyes > KFC
    Pete
    Northern Virginia, USA
    2013 Regular Cab
    I'm sure there's going to be a lot of rubbing. I know rubbing is possible with the lift on. Another important factor is size of the wheels
    tacostache[QUOTED] likes this.
  3. Mar 10, 2016 at 8:08 AM
    #43
    Regularcabjordin122
    Regularcabjordin122 Well-Known Member
    Jordin
    Escondido, CA
    2013 white regular cab tacoma
    Pro Comp Alloy Wheels 16x8 4" of backspacing. BFG Rugged Trail tires 265/70/16 Icon 2.5 Coilovers Total Chaos upper control arms Custom leaf springs built by a friend of mine Bilstein rear shocks K&N Drop In Air Filter Crawford Performance Eco-Block Q3. 30" Baja Designs Hi-Power light bar mounted in the bumper
    A LOT of rubbing, I ran 31's with no lift for about a month, and I rubbed....EVERY SINGLE DAY...every single drive hahaha. @tacostache
    tacostache likes this.
  4. Mar 10, 2016 at 8:34 AM
    #44
    tacostache
    2013 Base Model
    intake and headers
    Yeah I figured. I don't really have a need for a lift so I might just go with 30's. Similar to @KDogg311 setup. Thanks for the help!
  5. Mar 10, 2016 at 8:37 AM
    #45
    Regularcabjordin122
    Jordin
    Escondido, CA
    You might still rub with 30's in there. But let us know what happens!
  6. Mar 10, 2016 at 2:44 PM
    #46
    cjchevy
    cjchevy New Member
    cj
    2008 Black Tacoma 2.7L- 5 lug
    Rolis12 likes this.
  7. Mar 11, 2016 at 8:13 AM
    #47
    SleazyPetey
    Pete
    2013 Regular Cab
    Also, if you decide to go with 31's with no lift, do the black box mod
  8. Mar 11, 2016 at 1:52 PM
    #48
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    Beyond the physical lift, the lift benefits the overall ride of the vehicle, addressing body-roll issues with the stock shocks and suspension, as well as beefing up the rear springs which are about as weak-sauce as they come, once you've carried a few loads sufficient enough to sack the suspension out.
    You don't need to do the suspension first, but i think once you've upsized tires, you'll find out you need to revisit the suspension question.
  9. Mar 12, 2016 at 6:03 PM
    #49
    tacostache
    2013 Base Model
    intake and headers
    Thanks for the tip! I'll definitely keep that in mind :thumbsup:
  10. Apr 1, 2019 at 5:54 AM
    #50
    VA5lug
    VA5lug Member
    Eric
    Northern VA
    2013 Magnetic Grey 5lug RCSB
    235/75r15 Hankook Dynapro ATM, Better Built toolbox, Cragar 15x7, Fog lights.
    It works that well? Could you send me the link of the model that would fit on a 13 5 lug?
  11. Apr 5, 2019 at 11:06 AM
    #51
    ekansdilos
    ekansdilos Member
    I have no lift on mine, it will rub with a passenger. and anything in the back. or any bump really. thats why im working on lifting with the procomp lift kit
  12. Apr 7, 2019 at 6:43 PM
    #52
    Steven07
    Steven07 Well-Known Member
    Steven
    2017 Gray SR5 Tacoma
    3in front lift, 2.5 rear lift
    i have the lift plus a 1 in body lift. i got 265/70/16 and the rub at full lock on the sway bar. but thats it.
