5 Lug rear axle compatibility?
Discussion in '5 Lug' started by El Borracho, Apr 12, 2012.
  1. Apr 12, 2012 at 4:05 PM
    El Borracho
    El Borracho [OP] New Member
    5 Lug SR5
    Hi guys,
    I need a whole new rear axle assembly for my 2001 xtra cab 5 lug. Will an axle assembly off of a a single cab work, or do I need one off of an xtra cab model? I have found one off of a single cab 5 lug, but want to make sure it will bolt up to my truck.
    Thanks,
  2. Apr 12, 2012 at 4:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome! If its a similar year, you should be fine.
  3. Apr 12, 2012 at 4:16 PM
    El Borracho
    5 Lug SR5
    Thanks! It's off of a 2001 single cab five lug, and mine's a 2001 xtra cab 5lug, just wanted to make sure.
  4. Apr 12, 2012 at 6:19 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    yes it will work. :D
  5. Apr 12, 2012 at 6:21 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    I believe the only difference you may encounter is automatics and manuals had a diff gear ratio.
  6. Apr 12, 2012 at 6:22 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    i think all 5 lugs have the same ratio theres a sticker on the axle i think which should tell you all the info about it.
  7. Apr 12, 2012 at 8:02 PM
    El Borracho
    5 Lug SR5
    You guys rock, thank you all for the input. It's greatly appreciated.
  8. Apr 12, 2012 at 8:13 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Now tell all your friends with Tacos to join TW and stop trolling!! :D you'll love it here....the ballons float down here :eek:
  9. Apr 24, 2012 at 9:02 PM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    True, X's are I think a 10th higher then regular 2nd gen 5 lugs and the thirds dont quite fit in the same housing as the regular axles. I would assume yota did something screwy with the gearing from S's to regulars on the first gens.
  10. May 1, 2012 at 1:40 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Make sure you get right gearing. Autos and manuals are different.
