5 lug spacers for a 2008 2.7L Tacoma
Discussion in '5 Lug' started by lnfravor, Jun 11, 2019.
  1. Jun 11, 2019 at 8:28 AM
    lnfravor
    lnfravor [OP] Active Member
    logan
    2008 2.7L White Tacoma
    3" lift on 31's with bart d trucker wheels
    Hey guys I have a 2008 white 2.7L Tacoma. I recently bought 31x10.5r15 kumho tires and some Bart d trucker wheels.i have 5 lugs. My lift is going to be 3”s from fat bob’s garage in Utah. I need spacers in order for the wheel to sit flush, if not I have to grind the caliper and I don’t want to grind to much. What size spacers would be best for my set up? We figured about a 19mm spacer to clear the caliper. Any suggestions would be very much appreciated.
  2. Jun 11, 2019 at 9:03 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    What's the bs and offset on the rims?
  3. Jun 11, 2019 at 10:11 AM
    lnfravor
    logan
    Backspace is 4.5 not sure of the offset.
  4. Jun 11, 2019 at 10:39 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Your rubbing on 4.5" backspace? Must be a super positive offset
  5. Jun 11, 2019 at 11:18 AM
    lnfravor
    logan
    Yea it’s rubbing my caliper pretty good. Spacer should help right?
  6. Jun 12, 2019 at 4:00 AM
    lnfravor
    logan
    I’m going to buy 1” spacers that will make the tires stick out more but keep the wheel from
