5 lug, SUA to SOA. lolwut?!?!
Discussion in '5 Lug' started by ryanjboutin, Nov 24, 2011.
  1. Nov 24, 2011 at 6:47 PM
    ryanjboutin
    ryanjboutin [OP] Weapons grade dickhead.
    Las Vegas
    2013 4x4 TRD OR
    Mid travel, 33's, typical shit.
    I'm sure it can be done, right?
    I have 6 lug leafs installed and I have 6 lug u-bolts and plates on the way from cr250mw2.
    Any pro off-road suspension guys know if this is going to totally fuck my drivetrain up?
    **Reminder: I've never lifted a vehicle or driven off road.**
  2. Nov 24, 2011 at 6:48 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    What are you ultimately trying to accomplish Ryan?
  3. Nov 24, 2011 at 6:56 PM
    ryanjboutin
    Las Vegas
    2013 4x4 TRD OR
    Lift the back without having to buy a huge expensive leaf pack.
    I'm also going to throw my stock arms back on up front and find somehow to lift it.
    I want to try it out.
    To be honest, I think I want to move away from being lowered. :eek:
    I just had to take some of my drop off to accommodate hauling my bike, and now I hate not being low enough. Might as well not even be lowered. :(
  4. Nov 24, 2011 at 6:59 PM
    KPT
    09 Prerunner
    Have you right about throwing your stock leafs back on and getting a fat bobs garage 5 lug lift? Lots of trucks running that that look really good. You can run 31s no problem iirc.
    Check out the builds of neslerah and stupid hurts.
  5. Nov 24, 2011 at 7:02 PM
    ryanjboutin
    Las Vegas
    2013 4x4 TRD OR
    I don't have my stock leafs anymore.
    They were only two, the ones I have now are three leafs.
    I know of the Fat Bob's lift, but isn't it just a spacer lift?
    I was thinking of putting 235/75-15's on the stock rim, or find some lower profile 18's to put on my X-Runner wheels. Just not sure if 18's would be ghey or not. They are way wider though.
  6. Nov 24, 2011 at 7:04 PM
    KPT
    09 Prerunner
    Yeah the fat bobs lift is just a spacer, but it's pretty much your only option other than
    LT for a 5 lug.
    I know you can fit 235/75/15s at stock height.
  7. Nov 24, 2011 at 7:06 PM
    ryanjboutin
    Las Vegas
    2013 4x4 TRD OR
  8. Nov 24, 2011 at 7:08 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    IIRC taking a 5-lug to SOA requires fabbing spring perches on the axle...you may also need to fab some shackles on the frame in the right locations.
  9. Nov 24, 2011 at 7:08 PM
    KPT
    09 Prerunner
  10. Nov 24, 2011 at 7:11 PM
    ryanjboutin
    Las Vegas
    2013 4x4 TRD OR
    Hmmmm. I actually have extended travel shackles from Defined Engineering on my truck right now, http://www.definedengineering.com/products.html
    What if I just got the 5100's for the rear? (Direct bolt on for 5 lugs too.)
    Wouldn't they be long enough to reach from the upper mount to the spring plate?
    haha
  11. Nov 24, 2011 at 7:13 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    If you have the extended length shackles from Defined they are taking away lift which you are trying to achieve.
  12. Nov 24, 2011 at 7:15 PM
    jandrews
    I'm sure you could find some variant of Bilstein with the right travel for your application. Still doesn't get you SOA though. I think you'll also have to have shock mounts fabbed onto the axle...
  13. Nov 24, 2011 at 7:15 PM
    ryanjboutin
    Las Vegas
    2013 4x4 TRD OR
    True, that's why I bought them when I lowered my truck. :thumbsup:
    They got me down another 1/2".
  14. Nov 24, 2011 at 7:16 PM
    ryanjboutin
    Las Vegas
    2013 4x4 TRD OR
    Why do long travel drivers switch to SUA?
    I never understood this.
    Should I just keep my trucks natural SUA?
  15. Nov 24, 2011 at 7:16 PM
    theduck911
    Max
    Locked and Geared!
    Kinda assumed that:p
    Well maybe switch them out for stock height shackles now?
  16. Nov 24, 2011 at 7:18 PM
    ryanjboutin
    Las Vegas
    2013 4x4 TRD OR
    I think I still have my stock ones, not sure though.
    I just wanted to see if my SOA idea would work.
    Front is going to be stock control arms and a spacer for now, I guess.
    I really don't understand how to lift the rear without a super arched leaf pack.
    Will longer shocks really do the trick for an inch or two?
  17. Nov 24, 2011 at 7:21 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Ryan, just sell it and get 1st gen 4x4. :)
  18. Nov 24, 2011 at 7:22 PM
    ryanjboutin
    Las Vegas
    2013 4x4 TRD OR
    You had me at 1st gen. <69
  19. Nov 24, 2011 at 7:22 PM
    theduck911
    Max
    Locked and Geared!
    Shocks will not give you any lift, but you will need them to deal with the extra lift otherwise you might over extend your shocks.
    It could work but I wouldn't use the 6-Lug pack, as this would give you a crazy rake, I would use a 5-Lug leaf pack.
    All you really need is:
    - Spring Perches (to be welded on)
    - Maybe new front and rear hangers (Or see if you can cut them off a stock 6-lug from junkyard)
    - New Shocks (5100s would be fine, or are the 5-Lugs eye-to-eye?)
  20. Nov 24, 2011 at 7:24 PM
    jandrews
    SUA allows more rear axle uptravel at the cost of clearance. For desert stuff clearance isn't really a worry, absorbing big hits is. Going to SUA handles that kind of suspension deformation better.
    Shocks do not support weight, the leaf springs do.
    Rear lift in your situation is difficult. Arched springs are the easiest solution. If you wanted to get more creative there's the option for fabricating mounting locations on the axle for suspension components, OR (and I have no idea if this works because I don't pay any attention to 5-lugs) you might be able to find a 4x4/Pre-runner axle and its attendant leaf springs and bolt all that shit under there.
    The concern if you lift so much is that you'd be altering your driveline angle BIG time. You might have to do some custom driveshaft/axle shimming work to get everything to behave without severe vibes.
